Very good
Using Google translate reminds me of the old joke about an early computer translation program for English <-> Russian translation. At a demo of it someone put in the old saying “Out of sight, out of mind”. After translation to and back from Russian it came back “Invisible, insane”. Computer translation programs still leave MUCH to be desired.
The only good mode-changing is by separate button or rotating head. I want the dang thing to be in the SAME mode every time I turn it on since I will use momentary quite often. Also, since Olight drives their XM-L2s at 4 amps, this one - in order to have 1,020 lumens de-domed - would have to be pushed about that hard, and since Olight doesn't lie about their specs, I have no worries.
thats awesome!
I got a good deal to.
That name was really well-thought-out.
And Rey you should make another groupbuy with dedomed LED in a thrower for us.
I saw your post. This is a very good price.
You brought the good news, but did not say the coveted coupon code.
Maybe you do good and publish a coupon code?
I think we’ll all be thankful. Your price is the lowest for today
s. On gearbest coupons are not needed
It is no longer valid.
Javelots arrived, close up shot of the dedome.
You can also read DBCstm’s review here.
Awesome!! Please send mine quickly!!!
tomorrows newsletter from banggood should include a deal for the Olight-M2X-UT-Javelot
I'm finding myself liking it more and more.
At first the twisty action required at the head to change modes was kinda bothersome...I can't change modes one handed. But the more I mess with it the more I like it. The driver is actually quite sophisticated and well regulated. The body of the light is small, as befitting a single 18650 light. But the head is the size of an HD2010, with an even larger reflector than the 2010 due to a thinner bezel. It's a very decent thrower, holding current lower than I would have thought but still putting the light downrange.
I've found that if the normal mode selection is left in High, then there are no lower modes for the tactical switch (H-H-Strobe). If the head selection is in low, then the tactical switch at the tail has L-H-Strobe. If the head selection is left in Med, then tactical has M-H-Strobe. So there are options, easily set up without a lot of programming required.
Nice light, quality build, already de-domed. With a Sony C5 or a Panasonic BD, either way it's doing right close to 200Kcd and the same ~2.94A. What's not to like?
The close-up above is a nice one! Shows a super clean de-dome. Mine has some dome left under one of the bond wires, and the wires seem slightly pushed to the side. This just shows me that O-light is indeed doing the de-doming themselves.
Since other retailers are posting here I might as well mention we're running a deal on these as well, just PM me for info.
Calvin, this is YOUR thread...post whatever you like! :)
Thanks for bringing this one to our attention. Pretty dang sweet little light to be sure!
I ordered from ILLUMN, just couldn’t resist Calvins deal.
Thanks Calvin.
Can't wait to get your impressions on it. :)
It’s supposed to be gift wrapped and parked under that blasted tree… just taunting me day in, and day out.
Did you notice in the group buy thread for the BLF SE X6 that a hair dryer works to remove tape without tearing the "paper" on the custom box? ;)
