Thanks for such a clear detailed description RBD! I understand how to wire a slave board up without a sketch. Now the question is, do I want to try adding resistors, or try the slave board method? Hmm . . . I think I'll try the slave board method, but I need to make an order. RMM stock those? I'll go have a look.
I do have some 105c's somewhere. You mean to use it as a slave board (removing everything else)? Or do you mean as a total driver replacement? I don't want to lose the battery voltage indicator if I can help it. (But then again, the 105c would have low voltage protection with it's switch to low & flash.)
Aren't you supposed to be getting those solar panels finished up fellfromtree?
If all you do is replace the FET/resistors with the 7135’s on the slave board you shouldn’t lose any other features on the stock board. The lvp on the 105C won’t be functional.
No worries Garry, just doing the sense resistor mod might satisfy your needs and doesn’t preclude the more complex slave mod so you could just take baby steps here. The leap of faith comes when you strip the FET and resistors and things start getting ugly. The good news is that there are firmwares available for mom switches to 105C drivers if it goes south on you.
Could you post consecutive images of the top and bottom please. Hard to tell but if you measure the resistance between the bottom left pin of the FET and the top left pin of the mcu and get ~270 ohms then I think you have your pwm trace. The question then becomes is that 270 ohm resistor needed for use with 7135’s? I think some of that row of chips in the middle has to do with powering the indicator LEDs on the back side but the traces on the lower half are shadowed.
Eh, it’s actually a 27 ohm resistor (27 + zero zero’s is what the marking means). I think many of us make that mistake on a regular basis. Someone else just mentioned the same problem in a PM to me and I know it happens to me. (EDIT: and it definitely happened to me this time :laughing:
IOW that’s definitely the PWM pin. 27 ohms doesn’t matter one way or the other, you can solder your PWM wire wherever is convenient.
Great! Thanks for the help! I'm actually working on this right now. This is extremely difficult work for me and I might have to postpone it because I have other chores I need to get to.
Thanks wight! I’m in deep water without a vest here so it’s nice to have back up. When the FET is removed it should be obvious which is the pwm trace I was just trying to see if I was seeing things correctly first. I mentioned above that the resistor might not be needed for the slave mod. Thanks for the correction on the “0”.
Remember Garry, you don’t need to bring + power to the slave. Just the pwm signal, led-, and gnd. The last two will carry the full current so decent wires (awg24 or better for 3A).
Attach LED - to the 7135 based driver in the normal place
Add a heavy jumper wire for GND between the existing driver and the 7135 based driver.
Add a PWM connection between the existing driver and the 7135 based driver (it goes to the righthand pin on a 7135 when the tab is away from you). EDIT: You may get the PWM from the FET’s gate pin if you want.
