The original link was eBay of UK - dunno how to order from there - my regular eBay account doesn't seem to work. So, searched regular eBay.com and found those other listings. I'm hoping they are all the same - seem to be. Not sure how eBay works internationally...
My gray Courui has finally landed in the USA, making a stopover for an internal ‘makeover’ by Brad, a.k.a. 18sixfifty, before making its final journey back to a country not far away from China!
Just wanted to share my new buck driver project. At this point I’ve got a stable running driver but fitting it in the courui is just to much work, I’m going to leave this one as is but not do any more, its just to much work and money to do these lights. I’ll be designing a new board for a more universal application…
This is a pic I thought would be a lot more cool than it was (its also very short range for my usual high power thrower beamshot’s, only 150yds). Also extremely hard to get this shot, I took it from a rail road bridge 60’ above the water with no solid floor.
This light is a DX courui running BU_CK with an XM-L2 U2 1A dedomed at 7.7A from NCRB’s (no higher power from ICR’s, exactly how it should be). it makes 523kCd!
All in all probably not worth the cost in this light for under 100kcd more output (using my 17dd_PIC I was getting 450kcd at 6.4A) but it was the first BU_CK I had running so it did serve its purpose.
Soldered this back to where is should be, but this is not bright as my gray one. I noticed this blinks about once in 5sec, very fast blink barely could see it. any ideas why gray medium is as bright as this black high?
That’s the way it came. A few posts back, there is an explanation with the same picture. That is the part he is saying he soldered back to where it should be.
Mine draws 2.11 Amps out of 3 90% full TrustFire 2400mAh (unknown age).
2.11 Amps trough a extremely thin wire in the end-part of the light… changed it immediately.
Feels a bit too light for it’s size, I think.
To open it, just like the Kings? Remove switch, push with screwdriver?
I placed an order for a black one on Oct 13, got an email that the light was shipped on Oct 16. It is Nov 21 and it is not here yet. Should I be worry?
Not yet, unless you live next door to Gearbest. I’ve ordered three of these lights now. The first, I ordered for myself. I paid the two dollars extra for tracking, and was really displeased with what I got for the two dollars, so I didn’t get tracking on the other two. But, here’s how mine have been:
First light - ordered 9/23, received 10/20 - almost a month (with tracking)
Second one - ordered 10/23, received 11/05 - about a week and a half! Woo-hoo! (without tracking)
Third light - ordered 11/02, received NOT YET, STILL WAITING 11/21! (without tracking)
So, there ya have it. Shipping times are not consistent or predictable in any way, but will most likely be over a week at least.
How did I miss that? For some reason, I read that completely wrong! I saw Nov where he said Oct, so I was thinking 5 days! Yeah, 5 weeks is a long time to wait. Sorry about that!
Ordered 21st oct. Delivered today (so 1 month for me). Gearbest selected nl post to australia. I got black and it looks great. No issues at all (but haven’t pulled it apart yet). There was some solder on both positive and negative of battery side of driver, but its not a problem. Thanks gearbest!
So my light arrived…
batteries are charging so I can test it…
Impressions so far is not favorable so far as QC goes.
First thing i noticed…
box not even taped shut. Single peice of bubble wrap half covering light.
damaged anodizing
scratches on lense
impact marks and scratching on inside of reflector.
strange rattle when handling light.
Ok so Im not going to turn on electronics that rattle…
Pull the light apart…
No lubrication on any threads.
more damage to anodizing
scuff marks and what looks like a finger print on the led’s dome.
unscrew the pill…
located the rattle…
there is a random screw bouncing around on the driver… doesn’t match any other screw in the light so not sure where on earth it came from.
Batteries almost charged.
wonder if it will turn on!
Turns on ok…
High. Med. Strobe.
Bit floodier than I expected.
Dedome time
I just finished modding one of these and it turned out fantastic. I put a R50 over the resistor, added heavy gauge wire and used silver coated braid for the tailcap springs. I de-domed the emitter and put in on a noctigon. I also changed the centering ring out but I have no idea what ring I used. I always have a bunch of them so I just kept trying different ones until I hit on one that worked right. On the pill, I turned it upside down and lapped the surface with different grits of sandpaper until it was shiny. Then when I put it back in I used a combination of “omegathermal 201” and silicone carbide on the threads and around the bottom for much better heat transfer. Because of the vast discrepancies in testing I am not going to post my lumen count or KCD numbers. I’ll just say it’s Very bright and the beam is perfectly focused. At a quarter mile you can still see the round hotspot on trees. For me that puts the light into the super thrower category. Similar in lumens and throw to a fairly well modded TN31.
