If all you do is replace the FET/resistors with the 7135’s on the slave board you shouldn’t lose any other features on the stock board. The lvp on the 105C won’t be functional.
Ok, thanks. Not sure when I'll get back to this, but I'll try to post back.
-Garry
No worries Garry, just doing the sense resistor mod might satisfy your needs and doesn’t preclude the more complex slave mod so you could just take baby steps here. The leap of faith comes when you strip the FET and resistors and things start getting ugly. The good news is that there are firmwares available for mom switches to 105C drivers if it goes south on you.
Here is a pic of the backside of the driver. Not much going on as expected:
-Garry
Good thinking.
Could you post consecutive images of the top and bottom please. Hard to tell but if you measure the resistance between the bottom left pin of the FET and the top left pin of the mcu and get ~270 ohms then I think you have your pwm trace. The question then becomes is that 270 ohm resistor needed for use with 7135’s? I think some of that row of chips in the middle has to do with powering the indicator LEDs on the back side but the traces on the lower half are shadowed.
I don’t see why the 270 would be needed for that, I’d solder my PWM wire to the side of it which face the MCU.
Probing those two pins gives me 26.6 ohms.
-Garry
Eh, it’s actually a 27 ohm resistor (27 + zero zero’s is what the marking means). I think many of us make that mistake on a regular basis. Someone else just mentioned the same problem in a PM to me and I know it happens to me. (EDIT: and it definitely happened to me this time :laughing:
IOW that’s definitely the PWM pin. 27 ohms doesn’t matter one way or the other, you can solder your PWM wire wherever is convenient.
EDIT 2: Here’s a link to help with decoding SMD resistors. SMD Resistor marking
Great! Thanks for the help! I'm actually working on this right now. This is extremely difficult work for me and I might have to postpone it because I have other chores I need to get to.
-Garry
Thanks wight! I’m in deep water without a vest here so it’s nice to have back up. When the FET is removed it should be obvious which is the pwm trace I was just trying to see if I was seeing things correctly first. I mentioned above that the resistor might not be needed for the slave mod. Thanks for the correction on the “0”.
Remember Garry, you don’t need to bring + power to the slave. Just the pwm signal, led-, and gnd. The last two will carry the full current so decent wires (awg24 or better for 3A).
Really you don’t have to remove any components.
- Take the existing driver and detach LED-.
- Attach LED - to the 7135 based driver in the normal place
- Add a heavy jumper wire for GND between the existing driver and the 7135 based driver.
- Add a PWM connection between the existing driver and the 7135 based driver (it goes to the righthand pin on a 7135 when the tab is away from you). EDIT: You may get the PWM from the FET’s gate pin if you want.
- You are done.
Am I missing anything?
So no connection for "Led+" coming in/out of the 105c? I've already attached it. And in fact I used the existing wire that came with the 105c as the "PWM" line as I couldn't get my 20ga attached (too big). Not sure what gauge these stock wires are. Anyone know off hand?
-Garry
I forgot to mention that in my list. Small wires are fine for the PWM lead, no harm there. I don’t know what AWG the stock wires are, but they are fine for PWM.
No LED+ is necessary coming in/out of the 105c. It’s fine to use it, but all the 105c does is pass BAT+ directly to LED+ so it’s just extra connections and resistance. Not a big deal.
Side note: Note that while I’m very confident that you can get away with leaving the FET in place, eventually if you hook enough stuff up to an output pin of an MCU, whether that stuff is being used or not, the MCU will struggle to send out a strong enough PWM signal.
I'll remove the FET. I also got the Attiny13a removed too (that was tough!). I've not got all 22ga wire installed ready to mount to the existing driver. I even piggybacked another 7135 My first attempt at that ever! And I found that to be MUCH easier than attaching these darn wires! Just hope I didn't burn up any of the 7135s.
Im gonna have to quit for now. Thanks for the help!
-Garry
FWIW, and I don’t do as many of these as others, I’ve never burned up a 7135 or had a “bad” one that I noticed. I’ve torn legs off of them several times, but it’s always been pretty obvious that I had physically damaged the thing.
A heat gun makes all this much better!
Well I couldn't leave it alone, so it's connected!
Best at pic I can post until I get a chance to upload my high res macros. Not too bad of a job! Now I hope it works! Wait - let me test quick. Well it works, however I'm getting 2.35A measured in each mode (it still ramps down then back up between modes) with 2 unprotected cells in parallel at 3.99v. Ugh! Why'd I lose mode levels?
Ill probably post high res pics Monday. I'm done for now.
-Garry
I am unable to see the PWM lead in your picture.
I took a closer look at the stock driver. It appears to be setup for current sensing after all. It’s probably still just doing PWM to the FET and using an RC circuit to smooth the sense voltage out.
so err, sorry! If I’m correct I’d say that this is not really a common setup. I’m not sure that the best solution is not to re-assemble the driver and do a sense resistor mod. EDIT: hold that thought. I’m taking an even closer look now. EDIT 2: OK, I’ll stand by that for now. Forgive me but this driver is only so interesting and I won’t stare at it all day. It looks like what I wrote in strike-through text may be the case.
Well I already broke the old FET getting it off :( .
-Garry
