I’m not terribly happy about it either, but my choices were either voltage-sensitive moon or no moon at all. I did end up bumping up the level a bit though (0/30), so it now ramps from about 3.3 lumens at 4.22V down to somewhere around 0.05 lumens at 3.6V (will have to measure that when I get my battery drained though).
In-between, it spends most of its time in the 0.2 lm to 1.5 lm range, as far as I can tell, which will have to be good enough for now. But I did at least omit moon mode from the low-voltage step-down, since at that point it’s basically the same as “off”.
I considered making it change based on voltage, but the curves are rather non-linear, doing the math on the MCU consumes a lot of space, a table would also consume a lot of space, and it’s not even terribly effective near the bottom end of the voltage range… it still gets extremely dim even with the ceiling set just barely above the floor.
Maybe I could use a small table if I free up some bytes elsewhere, but I’m not sure it matters to me that much.
Yes, I’m using the TOP mechanism. I called it a ceiling. However, I’m not using phase-correct PWM here, it’s fast PWM. The “TOP” thing works in either mode, but phase-correct turns off entirely with PWM=0 and at 1 it’s too bright. I agree that the documentation is particularly convoluted about all this.
FWIW, the cypreus.c firmware got updated quite a bit today. Also, my Ferrero_Rocher/Ramping_UI_table.c firmware makes use of PFM for smoother ramping on the lowest modes, if you’re curious to see another use of PFM.
It’s an interesting concept, but it seems to have very limited usefulness in a flashlight driver.
