I think I found a small typo in “MTN_momentary_temp.c”.
// MUX 01 corresponds with PB2, 02 for PB3. Will switch back and forth
0x02 is actually PB4, right?
Is there an off-time version with strobe?
OK, several small changes and this is where I’m at now: v009.c
It’s still definitely not right.
There are a lot of things I want to tweak, but none of them should be causing these issues… in intermediate versions it felt almost like PB2 was floating, but of course it was not - I checked multiple times with a DMM.
I’m starting to feel like I’m going backwards. I understand better than ever what all this stuff is supposed to be doing, but less than ever why it’s actually doing what it’s doing. It’s all hacked up copy-paste stuff, so maybe significant re-writes would help. In the context of a flashlight where the brightness is controlled by a potentiometer none of the original battery monitoring code makes a ton of sense. I think removing it and starting with a clean slate may be the smart move now.
I guess I’d better disable voltage monitoring again and test to see whether I get full duty cycle with that disabled. Either way the answer is still probably to remove all voltage monitoring code, troubleshoot any remaining problems, then add voltage monitoring back in.
The only one I’ve seen is the one I made in the last couple days… but it’s kind of, um, deviated from its STAR roots. I wrote it to use on my Cypreus, and it’s a tad bit heavy on the blinkies. I haven’t made any which are more appropriate for general purpose use.
I’d suggest copying the strobe bits back into STAR, but the strobe functions are pretty trivial and the code is pretty far from where it started. I suspect my version would only be useful for ideas, not for actual code.
It’s an analog-to-digital signal, converted on cheap hardware, and it’s pretty much guaranteed to be noisy and +/- 10% off spec. It’ll be even noisier if the MCU is doing anything during the conversion. So, it’s safe to assume that you’ll need to scale the values and run a lowpass over them to get any reasonably-sane output.
As for LVP, I think you’re correct that you need to just turn it off until the other functions are working.
Also, it might be helpful to declare all your global variables as volatile. Since the source file isn’t used as a module by other files, declaring globals as static has no effect. Volatile, however, tells the compiler to assume the variable is being changed by other threads or interrupts, and should never be trusted or cached.
I see something else which could be causing issues too…
while(1) {
if (ADCSRA & (1 << ADIF)) {
// Start conversion for next time through
ADCSRA |= (1 << ADSC);
It looks like you’re re-starting the conversion again before it has a chance to finish. The re-start should probably be inside the if, not after it.
You could also just busy-wait on the result, since the code isn’t doing anything else at the time. For example, this is how I block until I get a voltage reading:
uint8_t get_voltage() {
// Start conversion
// Wait for completion
while (ADCSRA & (1 << ADSC));
// Return the raw value, caller can decide what to do with it
return ADCH;
I’m not sure if the ADC is as noisy as you think. It’s definitely noisy, but my small experience with MCUs and ADC’s tells me that ADC noise is not the core of any of the actual problems. The driver should behave with no smoothing, it should just be a little rough. I think, heh. I definitely plan to come back and do something about the noise.
Thanks for the poitners on declaring as volatile. I’ve had that explained to me before, but lost track of it. I’ll go through and clean it up.
That final point of yours about the structure of the loop is right on the money. That is clearly a bad setup, I see it now that you have pointed it out. Either blocking for it or moving it inside the if conditional seem equally good to me for this setup. For now I’ve moved it inside the if conditional.
Most recent results:
# With VOLTAGE_MON undefined in v009 the pulsing goes away AND I’m able to turn the output all the way up with my pot. And all the way down.
# No change after moving:
It was still a good point though.
We’ll come back to that thought though, it’s time to hang up the hat for the day. Thanks for your help ToyKeeper.
To mostly eliminate the noise, it works well to do something like…
if (ADCH > PWM_LVL) { PWM_LVL ++; }
else if (ADCH < PWM_LVL) { PWM_LVL --; }
It works pretty well as a lowpass filter, and adds a nice ramp effect when the value changes really quickly.
Or you could, you know, resolve the cause of the noise. But sheesh, who wants to do things properly?
Yup, thanks! I'll change that comment.
I never added strobe to any of mine. I believe RMM has a strobe option in his versions which I never included back in mine, and of course the other guys here have added their own strobes.
This is what RMM did in the "int main" routine, changed this...
[quote] set_output(modes[mode_idx]); [/quote]
to...
[quote] if (modes[mode_idx] == 254) {
// Strobe. The program will stop here, you will lose the voltage monitoring feature
while (1) {
set_output(255);
_delay_ms(20);
set_output(0);
_delay_ms(60);
} else {
} [/quote]
A mode of "254" will become a strobe then. I can add this to STAR and STAR_off_time if it works well enough.
As for strobe, what is the most effective one? Does the 20 ms on and 60 ms off work effectively? Does anyone know if this can be done via PWM by dividing the clock (really slowing down the PWM)?
It’s not necessary to lose voltage monitoring just because the light is in a blinky mode. In mine, I just light up, wait, turn off, wait, then proceed with the main loop (which allows voltage monitoring to happen), then it happens again next time the loop comes around. Instead of using modes[mode_idx] as a code to enter strobe mode, I use mode_idx itself (with #defines to decide how to map indexes to behaviors). The modes[mode_idx] value represents the strobe speed. This way, you can have strobes of different speeds without using mode space in the ROM.
Here is what I’m using, an off-time firmware with strobe modes:
http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/files/head:/ToyKeeper/cypreus/
That’s the one which has deviated the furthest from STAR though. Its predecessor, ToyKeeper/s7/s7.c, is closer (but is on-time based). Also, they both use party strobes (freezes motion) instead of tactical strobes (for stunning people), so you’d need to change the duty cycle.
From what I’ve heard/read, the most effective tactical strobe is 10Hz with a 50% duty cycle. So, something like this should work:
#define OWN_DELAY
#define SOLID_MODES 4
#define TACTICAL_STROBE_MODES 2+SOLID_MODES
const uint8_t modes[] = {
MODE_LOW, MODE_MED, MODE_HIGH, MODE_TURBO, // solid modes
50, 25, // 10Hz strobe, 20Hz strobe (1000 / 2 / X == strobe speed)
int main(void)
while(1) {
if(mode_idx < SOLID_MODES) { // Just stay on at a given brightness
PWM_LVL = modes[mode_idx];
sleep_mode(); // the WDT will wake us up for voltage checks
} else if (mode_idx < TACTICAL_STROBE_MODES) { // strobe mode, fixed-speed
PWM_LVL = 255;
_delay_ms(modes[mode_idx]); // requires OWN_DELAY
PWM_LVL = 0;
#ifdef VOLTAGE_MON
if (ADCSRA & (1 << ADIF)) { // if a voltage reading is ready
#endif
As for using PWM to do strobes… it should be possible down to 2Hz (I wrote a script to do the math a while back), but it would require setting the CPU to its absolute slowest clock speed. I haven’t looked up if that can be done from inside the program or if it needs fuses set. So, it might interfere with the PWM on regular modes, and the only real benefit is that it would use slightly less power.
Oops, I just realized/remembered that STAR doesn’t know at compile time how many modes there will be. That certainly makes it harder to use the mode index to decide what kind of behavior to use.
Hi, I really like a feature, rmm’s tk61 super driver has, the momentary turbo from off mode. It works until you leave the long press. Richard gave me some tips on how I can add this to star firmware but my skills dont let me to accomplise that.
Can anyone assist me on that?
Adding momentary turbo from off shouldn’t be terribly difficult, but it has a cost that you lose the ability to map long-press-from-off to something else.
I added it to my todo list, but I’m not sure when it’ll happen.
For now, there are a couple of similar options:
Would either of those work? There’s basically STAR momentary, my version of STAR momentary, a smooth ramping UI, or a stepped ramping UI (like an Olight Baton).
Thanks TK, will I find these in your repository?
Yes. STAR itself is in the JonnyC directory, and the others are all under ToyKeeper/Ferrero_Rocher/ .
I still need to make the red/green battery indicator bits easy to turn off at compile time; these were designed for a very specific driver. They work on other attiny13-based e-switch drivers though. The most likely thing to need changing is the PWM levels, since that’s very hardware-dependent. It’s calibrated for a FET by default.
Edit: Actually, looking at the code today, I have lots of misc cleanup to do… and need to apply upgrades from some of the files to the other files. I mostly stopped after getting things working, and didn’t finish the “polish” to make it really clean for others to use.
Edit 2: I just did some significant cleanup, mostly merging code between the three Ferrero Rocher firmwares to make them more consistent. It should be significantly easier to turn off the red/green indicators now, at least. Also freed up more space on two of the three.
Hello all!
I really like the Star (On-Time Memory) program. It is simple and functional. However, I would like to see one additional feature: the ability to reduce the mods in the normal and reverse cycle. I mean the following:
Short press (from off) (ML), Low, Med, Off
Long press (from off) Turbo, High, (Med), Off
In this way I do not need to go through unnecessary mods.
Is this addition difficult to accomplish?
I think this is impossible. Long/short press functionality while on has been implemented by a member here in STAR off-time, but I believe it is impossible from an off state.
I meant, of course “Star momentary driver” program.
I apologize for the error
No worries! Unless I am misunderstanding what you want to do, the momentary program already does have that functionality.
Function may be already in the program, but I do not find it there. So, I just may have to study more about the program.
