I’m not sure if the ADC is as noisy as you think. It’s definitely noisy, but my small experience with MCUs and ADC’s tells me that ADC noise is not the core of any of the actual problems. The driver should behave with no smoothing, it should just be a little rough. I think, heh. I definitely plan to come back and do something about the noise.
Thanks for the poitners on declaring as volatile. I’ve had that explained to me before, but lost track of it. I’ll go through and clean it up.
That final point of yours about the structure of the loop is right on the money. That is clearly a bad setup, I see it now that you have pointed it out. Either blocking for it or moving it inside the if conditional seem equally good to me for this setup. For now I’ve moved it inside the if conditional.
Most recent results:
# With VOLTAGE_MON undefined in v009 the pulsing goes away AND I’m able to turn the output all the way up with my pot. And all the way down.
# No change after moving:
ADCSRA |= (1 << ADSC);
It was still a good point though.
- v011 has batt_adc_ticks declared as volatile. It’s the only variable which should be able to change unbeknownst do the main loop. No change.
- I went ahead and commented out the entire mechanism that does anything to the output based on voltage monitoring, but left VOLTAGE_MON defined so that the ADC would toggle back and forth. Sure enough, the pulsing is gone - time will tell whether that was ADC noise or a screwup(s) in the LVP section I commented out. In the meantime I noticed that with this setup I still have upper and lower limits on what I can do with the pot. It won’t turn the output all the way down OR all the way up. I’m thinking that I need to do two readings each time I change Vref and discard the first reading.
We’ll come back to that thought though, it’s time to hang up the hat for the day. Thanks for your help ToyKeeper.
