I know how you feel mate
My S10 stopped working one day. It wasn’t the tail cap. So I decided to try to get the bezel off with hot water and a blowtorch. Didn’t move so I tried a few different clamps and pliers. Still didn’t move.
Went on eBay to buy a watch case remover tool. Waited a week for that to come. Tried it still no luck. Got pissed off. Pulled the vise grips out. Kept slipping and marking the bezel. So I did it a bit tighter than bam bent the bezel. Still didn’t get it off lol so it sits in some draw now.
Stuff like this forced me to make a rule not to buy lights that are glued together or are otherwise not mod-able.
Having older XP-G and XP-E lights that are ripe to be upgraded to XP-L, XP-G2, …but can’t get them opened up? Yeah, most frustrating. Olight & Fenix are a couple that make nice lights but hard to get open without damage.
I would use an angle grinder to put some notches in the top, find a large screwdriver or something similar to hold it in place and use some vice grips on it
I am curious why you did not reach out to olight and tell them the tint is unacceptable
mine does not have the green tint problem, they must have used a different reflector on it, though i have not used it in probably a year or so, its still in its original box
Take a Nanjg 105C with DrJones electronic switch firmware (or star momentary firmware from RMM). File down the edges of the driver. This will then sit at the end of the pill rather than inside the pill.
File down the pill so the driver sits closer to the switch hole.
Discard the stock driver and switch. Buy a replacement microswitch (I found some tiny ones on Ebay for cheap that work well. Was only a few $ for 50 of them too). Glue the replacement microswitch to the top of the driver with a large amount of arctic alumina.
Then glue the new driver onto the end of the pill. Should be good to go.
