Test/Review of Efan IMR18650 2000mAh (Red)
Official specifications:
  • Spec: Lithium 18650-2000mAh 3.7V
  • Material: IMR
  • Capacity: 2000mAh
  • Nominal voltage: 3.7V
  • Lowest permitted discharge voltage: 2.5 V
  • Cycle life: 500 cycles
  • Max charging rate: 4.5 Amps
  • Max continuous discharge: 8C
  • Do not short circuit - High current will be discharged
  • Diameter: 18.2 +/- 0.5mm
  • Height: 66.34 +/- 0.5mm
  • Weight(g): 98g/pair
  • Operation Temperature Range: Charge(0~45°C ) Discharge(-10~60°C )
A high current 18650 battery.
The two cells matches fairly good and has nearly constant capacity up to 7A, both 10A and 15A looks like heavy overload.
Conclusion
The cells has accetable performance at lower currents, but its high current ability is not that impressive.
Notes and links
The batteries was supplied by Efan for review.
Compare to 18650 and other batteries
dat protection test graph.
TY for the review.
Sorry about that, I forgot to strip the last data point.
It is fixed now
Thank you for the review HKJ. Your cell reviews are such a great resource for our hobby.
I’m surprised at your calculated internal resistance. 0.26 ohms is way too much for a cell capable of discharging at 10A.
That is also a bit misleading, I do my calculation at the maximum current in the "protection" chart and because the voltage drops significantly at that current, I get a fairly high value.
