I seem to remember reading extensively about this problem several months ago. The conclusion drawn at the time was that the green tint was a result of the AR coating.
It is quite noticeable on my S10 (XM-L); less so on my S15 (XM-L2). Comparing the two lenses there is definitely more of a purple hue visible on the S10. I don't have the S20.
if the bezel is non-removable anyway that doesn't seem to be much point in trying to work out how to change emitters or drivers to cure the problem.
Sorry to hear yours has been so stubborn DBSAR. I guess Olight really doesn't want customers messing with them. As you say, not much good in terms of making repairs if anything ever goes wrong.
I have never owned a Olight. I have been thinking hard, lately, about that new rechargeable one. But, I can’t mentally handle that green tint. I have it on a few lights from SF that suffer from this affliction! That’s enough. I have designated those as hard use lights, and to wife & vehicle usage only.
So, I guess I am a official member of the TEGT (That’s Enough Green Tint) Party.
Thanks for the heads up. I had no idea the reflector could cause so much “damage”.
I bought an Olight S20 off eBay a few months back. Got a real good price, too! It has a smooth reflector (which I like better than OP) and the tint seems to be perfect to my untrained eye (well, untrained, yet I consider myself to have a good sense of color). It is a nice neutral white with no yellow, green, purple, or any other color tint. I just tried it to make sure. I pointed it at a piece of white printer paper and turned it on in moon mode - then lo - then med - then high. In none of the modes did it have an unpleasant color. I used to always prefer cool white for the brighter looking output, but this light has changed my mind. Now, I think I prefer the cooler side of neutral white or maybe the neutral-er side of cool white.
My S20 had a bad tint as well. +1 for using a narrow color bin Olight/4sevens.
The bezel on my s20 was stupid tight, but I didn’t see any glue. I did have to use a vice to remove it though. My light got just a little buggered up, but now sporting a neutral in the 4A range.
I put the light long ways in the vice, with a piece of rubber on the bottom and the bezel. I tightened the vice down and used a wrench wrapped in a belt to turn the light. I had to further tighten the vice until the bezel finally broke loose. It did leave a few marks on the bezel but not too bad.
I have two - a first gen XM-L with the soft white switch that was quite green when I first received it. With use (probably about two recharges worth), the green has actually lessened and it appears more yellow for reasons I don’t understand. It was awful to start with. Last night, after reading this thread, I grabbed a sheet of rubber and simply unscrewed the bezel with only hand power. The s.n. is C179248
The other is a second gen XM-L2, with the hard black switch. It has an OP reflector similar to the first, but a visibly coarser texture. This one was much less green right from new, and calling it ‘neutral’ would not be much of a stretch. I was also able to simply unscrew the bezel with hand power and my trusty rubber sheet. S.N. on this one is D10110767.
While I’ve certainly used them, I can’t say I’ve used them very hard. Mostly its been night stand duty, sleepy trips to the bathroom and trips out to the shop and back after dark, but so far neither has misbehaved. The only oddity I’ve noticed is that an iPad will shut the newer one off you get it right up close. I don’t know if it’s RFI or if its the magnetic attachment on the cover that does it.
After reading this, I just tried - and succeeded in unscrewing the bezel off mine with just my bare hands! Not even a rubber sheet needed here. Smooth reflector, XM-L2, SN is E05040005. I’m not gonna try to get the GITD O-ring and AR lens out right now because I’m at work with no tools nearby to fix something if I screw it up.
