The perpetrator did not act alone.
We’ll get garrybunk straight in the end.
…rewind to post #1 and do the sense resistor mod.
Lesson learned: KISS
True but you still learn more from mistakes than you do from things you already know. In a situation where failure is not an option kiss is more appropriate but not for something like this where you can go back to square one with little risk.
wight wrote:
. . . I don’t think you have the ability to flash MCUs, but if you did you could use ToyKeeper’s STAR mod which features support for status LEDs. You’d just wire up the 105c to the status LEDs & their limiting resistors on the stock PCB.
Do you know which modified version of STAR has this support? I searched for discussion on the topic, but didn't find any.
Yes. It’s the version discussed in comfychair’s Roche F6 Hacking thread.
She may have implemented the status LEDs in one or more of her other firmwares, but I know that they are present in this one for Helios-’s Ferrero Rocher DD driver for the F6: http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/files/head:/ToyKeeper/Ferrero_Rocher/
^ Didn't search that thread. Searched the OSH Park and STAR threads. Thank you. :)
Got the new FET from RMM mounted. Now I'm gonna power up and check currents from battery pack and at LED wires.
Cruddy cell phone pic.
-Garry
Ok here are my measurements at 4.2v battery pack (2 cells parallel @ 4.01v)
off: 0.011A
low: 0.98A
Med:1.30A
High: 1.75A
Now meter in line with LED wires:
off: 0.000A
low: 0.81A
med: 1.33A
high: 1.81A
So I guess my LED measurements are higher because my battery pack wiring & connectors (maybe just my connectors I add to get inline measurements) are adding some resistance. Anyway, I'm pretty much back to stock output. What resistors would I stack / replace? Think my goal was about 3A on high (1.5A per emitter). I know I have R120's and think I have R500's. I have others but I'd have to look.
By the way, I'm correct that the 1.75A I measure gets cut in half for "per emitter" current, right?
Thanks,
-Garry
Iout = Vref / Rsense
Vref = Iout * Rsense
Rsense = Vref / Iout
Therefore for 3A output you want something like 0.033 ohms for Rsense. Three R100’s would be good. Four R120’s is 0.03 ohms for ~3.3A output.
By the way, I’m correct that the 1.75A I measure gets cut in half for “per emitter” current, right? - Yes.
Thanks. I'll try the (4) R120's and then measure again.
-Garry
Ok, I pulled the R100 and stacked (3) R120's (left other R120 in place). My resistors are supposed to be 0805 size from FastTech and they are 1/2 the size of the ones on this driver. Does that seem right? Is it ok?
Anyway, current on the LED wire is now:
Low-1.32A
Med-1.80A
High-1.96A
I'm wondering now if the LED leads are too thin. Holding the lead up to 24awg wire I'd say its close to the same size, maybe a size smaller (26Awg?).
-Garry
Or could I have burned up a resistor? Or do the new Low & Med currents show the resistors are all good?
-Garry
It may be that the thing has a maximum duty cycle it will not exceed. The new Med/Low currents do seem to indicate that the resistor mod is having an effect. Just not the end result you want for some reason.
0805 sized sense resistors should be OK with 4 in parallel. They are quite small compared to 1206 sized ones, I prefer to use 1206 when I can. Assuming the 0805’s are good for 1/8-watt or greater, there should be no problem with dumping around 0.3w across 4 of them in parallel.
EDIT: no harm in replacing the leads.
So would you suggest adding another R120 just to see if High increases? Or just replace the leads? Do both?
I need to get some 1206 sized resistors! These are too darn small!
-Garry
By the way, I'm done working on it tonight.
-Garry
I recommend replacing the leads first. If that helps, great. If not, I feel that you have run into a limitation of the software that came preloaded on that driver’s MCU.
Copy/paste from my post in another thread: FT carries 3 values of sense resistor for 1206. Use the dropdown menus. http://www.fasttech.com/products/0/10007371/1615805-1206-0-12r-smd-precision-resistors-100-piece
For anything else you’ll want Mouser/Digikey/etc
Thanks!
-Garry
The modes compressing like that indicate that something else is limiting current. You may be able to just short the sensor bank and still get under 2 amps (probably in all modes). We know that FET is capable of very high currents with low resistance.
I'm having trouble reading the traces. It appears that the top left pin of the MCU in the picture below is the PWM output. It feeds into a 27 ohm resistor (may also have a 10k ohm resistor going to ground) on the way to the FET's Gate. You could try to bypass the MCU's PWM by using a paper clip to bridge the Vcc (bottom right Pin in the pic below) to the PWM Pin. This will be equivalent to a PWM of 255. If current increases significantly, then the MCU may be somehow governing the current to just under 2 amps.
Adding more resistors does seem to be bringing up the lower modes more than raising high. The two LEDs will pass whatever current their relative Vf’s allow. If they’re exactly the same then 1/2 total each. The difference in current measurements isn’t loss in the wires but the additional current used by the rest of the circuit. Voltage drops occur all through a circuit but the current in every part of a given path is constant as long as you account for any branch circuits.
