I wonder if OL would comment the same way if we were discussing MTG-2 leds and not XML-2?
Just thinking... if the U3's have such a high Vf but do have U3 output, they are still very suitable for <2amp single li-ion flashlights. Driving the XM-L2 lower than 2A sounds a bit odd in general BLF-thinking, but it makes a very efficient flashlight. The higher Vf is not very relevant because overhead voltage is burned off anyway by the driver and at these low amps the voltage is still low enough for the flashlight to stay into regulation for most of the battery drain.
Yes, yes it does.
Sounds very unnatural. Who would do such a hideous thing? Think about that poor helpless little emitter. It would be freezing. I take good care of them, put them on copper and make sure they run close to rated temperature. I help my emitters live up to their true max potential. Once they enter my house they have a bright future ahead of them. 0:)
My most efficient flashlight is a Uniquefire S10 with 2x7135 driver and a XM-L2 T6 0D, at 90 OTF-lm/W.
:evil: emitter torture! :evil:
EDIT: pointless question (deleted)
Not at the moment, but hopefully soon. I got them from RMM a couple of weeks ago. Not sure what to do with the 2A, I had planned to put it in a SupFire L5 and LD-1. Not anymore!
I appreciate your time and effort on testing these LEDs. You should have already spent a fortune in buying lots of emitters.
So I ordered a 5 amp adjustable power supply.
From the posted spreadsheet, it looks like between 3 and 4 amps is where the discernable vF change becomes clear.
From here on out I will be testing in that range to see vF and relative output before I use an LED…………
Ive done a new "test session". I`ve added more data to the spreadsheet. All new data in bold. Im not going detailed through everything in a post like last time. At least not now. But for me, several interesting finds on several of the latest and popular emitters. Feel free to check it out and leave a comment.
On top of that I can add a bit more data. Tailcap measurements from a bunch of different UF-T20 lights I put together for a local. (For the record, I mostly just make lights for myself). Cell voltage when I started doing the tailcap readings was 3,87V. I did not use the absolute lowest resistance DMM either, but its good. All results comparable and all purposely out of regulation to easy see the difference.
Flashlight specs: 10x7135 Qlite driver. Spring "bypass". New switches in all lights, all emitters reflowed by me. De-domed XP-G2 R5 1A in all lights except 3. Those had de-domed S2 2B (which as expected does not de-dome that well). All emitters ordered not too long ago (new).
LG HE2 3,87V | |
amp | |
S2 | 2,73 |
S2? | 2,65 |
3,4 | |
2,54 | |
2,98 | |
2,9 | |
3,03 | |
2,2 | |
3,18 | |
2,65 | |
2,66 | |
3,15 | |
2,9 | |
3,2 | |
3,14 | |
2,93 | |
LG HE2 3,81V |
I knew which light I had one of the S2 emitters in. It was also clear due to the worse tint. I easily located another light with a bad tint. I was 97% sure it was another S2. Very similar amp reading too. The third S2 I could not say for certain I was able to locate. I suspect it was the one at 2,2A due to combination of fairly bad tint and low amp. I later swapped out that emitter to another S2, which performed better.
I suspect de-doming of these emitters could help generate a larger difference in performance compared to normal. Either way.. It is what it is.
Anyone else got anything to share?
nice info,thanks.
Thanks RaceR86 again for the effort put in here. It appears the trend here is that the XPL is the new go to emitter for very hi current draw applications. It would be interesting to compare light output but with the smaller die of the XPL the same reflector could not be used. This is where a sphere would come in handy.
Thank you for the testing.
It is nice to see that it is highly unlikely to blow a led up with a single battery setup.
Thanks you RaceR86 for the tests and datas.
May be multiple emitter in parallel will become more popular, hoping battery technology will make big improvement too.
Thanks for more and more insightful data, RaceR! Who would have thought that led voltages, so relevant for single-cell flashlights, would vary so much. And there is no precise specification of Vf by any seller including Cree itself!
With a really powerful buck driver I would put my money on the XP-L based on what I have seen so far. Buying new XM-L2`s (from recent batches) and trying to push them to the more extreme currents seems a bit like gambling with bad odds. Unless you have verified how far the emitter can be pushed, which I now seem capable of testing quite well without frying any emitters. :) Sadly, most XM-L2s from recent batches does not seem that capable.
Not sure I understood everything you said. Smaller die on the XP-L? XM-L and XP-L have the same die size. Suitable XP locating/centering ring can make the XP-L`s fit perfectly in any reflector that you use XM-L if you need one.
I disagree.
If DD and low resistance cells could push XM-L2`s and XP-L`s to death at 5,5-8A+ that would be a good thing IMO. If the emitters were like that, many lights could maintain 3A much longer. Good for everyone who wanted a bright light.
Hot rodders could make single cell hotrods like say an HD2010 with spring mod with a 5200mAh cell push 6A to to an XP-L and maintain that for say 30% of the runtime before it started to decrease.
The" Vf safety net" we have are holding us back IMO. This is quite evident in the increasing increasing amount of "low resistanse mods" we are seeing. People just cant get "high enough" with regular cells. Not even with low resistance cells...
Id much rather see some lower Vf emitters. If the XP-L had a Vf of 3,2V instead of 3,43V @ 3A (25C) then I don`t think the XM-L2 would be used much.
When that is said, there is a place and use for every emitter/driver combo depending on what people want. Just need to find the best. :)
I was a bit surprised when looking at the highest and lowest amp readings. Still not sure if de-doming can change things a bit though.
I have seen and reported Vf issues before though. Check out OP in the L4 mod thread and scroll down to "Why did I use a bunch of time modding this light for probably zero visible gain?".
Cree have lots of precise data. You can see Vf here for any given emitter at any given current and temperature. My spreadsheet data is actually very close to Cree`s data. At least if you average out the numbers.... Lots of the numbers are within 1%. Problem is, +/- 5% can give large differences in flashlights.
Earlier in this thread I assumed the XM-L2s had Vf of 3,33V at 3A. And it does, at 85C. My testing is basically at 25C based on mcpcb temperature.
To give a few examples at 25C Cree says Vf are:
XP-G2 @ 1A : 3,16V
XM-L2 @ 3A : 3,43V (3,02V @ 1A)
XP-L @ 3A : 3,48V (3,06V @1A)
Added following emitters to the spreadsheet. They are in "bold".
EE X6 - BLF Special E. | XM-L2 U2 3C |
Intl- Outdoor | XM-L2 U2 3C |
Intl- Outdoor | XP-L V6 3D |
I tried to do a light output comparison between three emitters but my test setup were not good enough to get any useful data.
Any thoughts on the different voltages on the XML-2 3C leds?
Thanks for more data RaceR86.
In high hopes to build a ~2000lm XM-L2 build, I ended up trying to find a suitable LED… 6 XM-L2’s (U2, T6 and 1 U3) and 1 XM-L U2 later… Nothing survived past 7.6A! Even when below 4.2v. The U3 mentioned above did 7A, but died when hooked up to a stock HX-1175b1 (dumb). No real data other than vf/A on a really promising XM-L2 that died at 7.6A. Oh well…
I bought some of the T6’s mentioned above and a couple more U3’s. I may try a couple of the T6’s to do 8A, but will have to settle for less powah! I have a P-bin CBT-90 and SBT-70 screaming in the drawer… Pick ME!! Unfortunately the vf of the CBT-90 @ 18A is 4.3v, was hoping for less. It should be making between 2500-3000 of very inefficient LED lumens though.
I also bought a light meter, so I should be able to start measuring output as soon as I get a light meter built and calibrated.
But everybody has been doing low res mods for years. Many years.
And I still like a direct drive light. Hands down it is my favorite. So as far as I am concerned its still good.
Sure it was, really, funny to see a single XM-L light pull 8 amps from a low resistance setup with a good cell.
But the output was just not there compared to the XM-L2 led at lower amps. Back then we all vailed and carried on about whether it (XM-L2) would be the end of single cell lights. It was not.
And I still have enough Xm-L lights left over to test it. But nothing I measure is calibrated by any method commonly acknowledged or understood explainable on the forum. So I can only say that relatively speaking a XM-L light doing 5A is about equal to a XM-L2 light doing about 3,8A. For anyone caring that amounts to about 1360 lumens in my converted Ikea bucket of light.
As far as XP-L vs XM-L2 then the only tests (in a single thread as far as I remember) that has light output included are done by hpflexpro where they are equal. So of course it is brighter to have a higher amperage capable XP-L. I understand that. But it is a little marginal to me.
I can't believe I said that. I may have to find another hobby. Things are shifting in my world. Sorry for intruding. I'll sod off now.
I don't know how I missed this thread until now, but I hadn't seen it until today.
I do think that the newer batches of emitters are different than the older ones--and not just the U3 bins, but the T6 and U2 as well. I've seen the vF shift in the newer batches of T6 4C emitters as well. They just can't pull the amps like the old emitters could.
That said, the higher bins seem to put out more light at less amps, so all is not lost. I wish we could have more efficiency and higher amps, but I guess we will have to wait.
I now have a 10A linear power supply (extremely small ripple current--basically non-existent) and the newer emitters just can't be cranked up as high as the older ones. 7A is difficult with a lot of them, even with a very smooth output.
With a stock HX1175B1 you are almost guaranteed to blow any XM-L2 you hook up to it--especially a newer batch XM-L2. It puts out around 7.5A stock and has a lot of voltage ripple on top of that.
