Gonna park some driver pics here for folks in the future that may be interested in modding this driver.
Two buck drivers. Large diodes labeled "SS34", Inductors "100", Sense Resistors "R150", Buck Controllers "LEDA 1406",
Here's a couple, much better pics. These are of Ledoman’s HD-016 driver from his review (Post#13).
Where most the action will take place:
The 3 pads with long traces going off to the right go to each of the 3 voltage indicator LED's.
The big trace in the center is B+ and connect to the 2 inductors. The biggish traces on each side are the other side of the inductors and also connect to the LED+.
Need to redo this one below.
Switch and voltage indicator LED's side of driver.
Hi ToyKeeper. The driver appears to have 2 different voltage dividers (Still trying to sort out). One MCU pin pad reads close to 1.5 volts and another at about 1 volt with fully charged cells. I don't have exact numbers here at work. I also need to measure with different input voltage levels. I can adjust the values in the FW as needed. I don't know of anyone pulling this off yet though. I just know the theory the wight taught me.
Yeah, I set those a tad bit different than requested. They’re actually about 1.6, 12, 46, and 100. But after adjusting the values on a visually-linear cube root scale with a maximum of about 1600 lumens, the resulting “perceptual” percentages are 25, 50, 77, and 100.
The low end may be a bit off since I’m not totally sure where “zero” is on this hardware, but I’m guessing it’s at about PWM=6/255.
That sounds like it’ll probably take a lot of trial and error, manually checking lots of different values and reflashing. And that’s if it works at all. It might deliver a constant voltage due to the buck driver, and it could possibly be too low to measure accurately (the attiny13a’s reference voltage is 1.1V). In any case, it likely won’t be easy.
ImA4Wheelr, did you measure both of those voltages as changing with different Vbat? Just based on what you wrote I’d expect that one of those two voltages was probably a reference voltage to compare the other voltage against. (If so, the ATtiny13A will not need that.)
I think that the easiest course of action is simply to make up a new voltage divider and work with what we know.
^ Haven't had a chance to try different voltages yet. Just trying to understand some basics about this driver.
The traces don't make sense to me yet. I can't completely track the PWM traces going to the Buck Controllers. I expected 2 separate pads to control PWM for each driver because the stock light operates them independently. But only one pad seems too activate both of the drivers simultaneously. So far, this diagram is about all I think I know about the stock MCU pin pads. The voltage readings are from ground. Doesn't that the Vcc seem high?
The indicator LED's are always connected to positive power. It appears that the MCU must a path to ground to turn them on, but when I try to ground those pads, the emitters do not light. They light when tested with a DMM though.
Something seems to have gone wrong. Now when I connect power to the driver, one led turns on and one of the sense resistors starts to smoke within seconds. Wondering if a Buck Controller failed.
It's late and I got to crash for work tomorrow. I think I will replace the Buck Controller is connected to the burning sense resistor and begin testing circuits all over again. Probably should reflow the MCU and see if the driver still works properly too. I'll decide tomorrow.
Yeeee Haaaa! We're in business. Finally, got this driver sorted out. It turned out one of the Buck Controllers had failed (Probably when I was poking and prodding around trying to figure this damn thing out). I reluctantly pulled the switch so that I could see the traces under it. That helped answer more questions. I still can't follow the traces for PWM, but process of elimination gave a clear indication as to which pads were for that. I think the traces are hiding under the vertical board. I have much better trace pictures that I will soon replace some the pics in Post 16 with. Here are a couple views of the traces under the switch:
We also seem to have a viable on-board voltage divider. It measured 1.43v at 7.61v input and 1.55v at 8.2x input. More measurements will soon be taken. The other "voltage divider" seems to decrease voltage as input voltage increases. So it doesn't seem like anything we will be utilizing in this build.
So, I'm at a point where I can now start modding the driver. I should have something to report some time before the weekend it up.
EDIT: To all the folks that said nice things up above. Thank you very much. I'll reply to those posts sometime soon now that I'm starting to see some light at the end of the tunnel.
Bad news ImA4Wheelr: The 1.4-1.6v range does not make for a simple mod. If there is not a rock solid Vcc available then it’s not useful at all to the ATtiny13A, which uses an internal 1.1v reference with current firmwares. ATtiny13A units without a fully regulated voltage supply cannot measure above 1.1v in other words.
I think I said it earlier, but the easy way out here is definitely just to build a new voltage divider. If you have a rock solid Vcc then the firmware could be modified to measure the stock voltage divider against that, but it would require (minor) code changes and (unknown amounts of) testing.
Good luck with figuring out anything strange relating to controlling the two buck circuits independently, I’m looking forward to that. Maybe there is a transistor which switches the availability of the PWM signal on or off for one of the circuits (so it would be controlled by a binary output from the MCU).
Having an on-board circuit makes this so much easier. I just need to change out resistors to get the appropriate voltages. I think it's good news.
The drivers were independently driven stock. The will both be feed the same PWM signal from the Attiny. One may end up putting out more current overall to balance the beam pattern, but they will both get the same PWM feed.
Thanks for the input wight. Always appreciated and valued.
Oh, I thought 1.1V was the bottom end of the attiny’s built-in voltage measurement range… When using the default 1.1V reference, can’t it measure anything between 1.1V and 5.5V?
If that’s the case, I think it should work… but the voltage values you use might be in the range of 10 to 30 instead of the default values of like 120 to 190.
This is incorrect. The ATtiny13A measures betweeen GND and Vref.
Vref may be taken from the internal Vref (1.1v) or Vcc (you’d want it to be tightly regulated of course, a Zener attached to a battery is not good). Some other AVRs allow for taking Vref from an external pin as well, but I don’t think the ATtiny13A does IIRC.
The voltage divider of interest consists of the 3 components (C2,R2,R3) on the top right of the below picture:
Using this diagram (Linked to Voltage Divider Calculator that wight introduced us to), the component ratings are as follows:
R1 (Labled "R3" on PCB) is 43.2k ohms (E96 marking of 62C)
R2 (Labled "R2" on PCB) is 10K ohms (E24 marking of 103)
There is a capacitor parallel to R2
VCC is wired as follows:
B+ into a 150 ohm Resistor
After the resistor the trace connects parallel to the following:
A zener diode (Labeled "W8") connected reversed biased. The is what regulates to a solid 5.19-5.20 volts out.
Capacitor
The other "voltage divider" looking grouping to the left (R4,C3,R5). The component in "R4" looks like it might be a multilayer inductor. I don't think this circuit impacts anything much as R5 is a 31.6k ohm resistor.
The other side of the above are connected to B-.
The trace continues on to a inline diode (can't make out marking on diode). It is in bay "D1" on the main PCB. This appears to be for reverse polarity protection.
The diode connects to the VCC pin of the MCU.
There is a Capacitor between it and ground (See far right of the pic below).
