What you think the runtime on low would be?
I am going to guess around 15-20 hours
What is the driver diameter?
I decided I don't want to risk the light selling out before the price drops more (if it does). That has happened down here on several lights I wanted from HD. I actually think this one is going to become popular and probably not drop in price. Glad I did. It is a real bargain.
Great News! dchomak was right. There is plenty of room for two 26650 cells with a shorter tail spring. You might be able to use the stock spring. Seems like it would be very tight and I prefer copper dome springs instead. This opens up a lot of possibilities. I think I will go with a bigger emitter in mine. Probably XM-L2 with a buck driver.
It's almost like the designer had us in mind. There is a pocket in the tail cap that gives plenty of room for that. Check out the unprotected KK sitting in the cap below.
So ImA4, loose any sleep last night worrying about not being able to get one these?
You posted at 7:14 AM, so that means you tossed and turned all night and got up early Sat. morning, or you went back out last night.
Either way, a true sign of a flashaholic! No wonder you fit in so well around here.
Yes, I left out 2 pieces of important information. The driver OD is 20mm as is the star.
I can not tell a lie. I picked one up on the way home last night, but was not sure I would keep it. Then I saw your tear down and knew I would keep it, but was going to wait to see if the price dropped more. Than this morning I decide "the hell with it", I'm opening the damn package. I know I could still return it after I opened it, but that just seems wrong. It's mine now and I'm happy.
interesting! ill stop by the lowes here in danbury on the way home tonight to pick one up
I have a ID card from the VA and my Doctor who is a big DIY said with it you get a extra 10% at Lowes.
Might have to try it tonight.
I’m grabbing one today too. Saw these last week at full price and passed… Definitely not this time.
How bright is low mode?
^ hmmm, I'm not the best person to answer this type of question, but I'll give my impression. It is nicely separated from High. Guessing about 20% of High. If I were only to have 2 levels of brightness, I would say this light is just about right.
Stock, this is a great light for a non-flashaholic. For most of the rest of us, it's a under driven.. It's driven better than most stock lights, but still under driven.
Mine will have about 7 brightness levels and push the emitter to around 7 amps on turbo. That's if I can find a good buck driver that fits. If not, I may go MT-G2 DD. I haven't tried a smallish MT-G2 yet.
Its just not fair that you folks get all these great deals on lights, I’m still gutted that the Defiant wasn’t available here in the UK
Any chance of a kind person shipping me one of these Lux Pro 2D please?
Cheers,
Woody
The one I just got back from had none, just the sign.
Had them run the SKU and they are all gone.
Good part is there are 4 others not too far, so we’ll get one tomorrow or Monday.
Good to see they are selling, I told the wife “Boy that BLF has some buying power”
Later,
Keith
9:19AM Friday
10:08 Saturday
I would be willing to do that for you, but I would think the shipping would kill it for you. Any idea how much?
If it would help, I have some of the older Defiants. I could also perhaps send to lower the cost of shipping per light.
I went and got one on my way home from work tonight. Excellent little light, low is a bit too high and it seems to have next-mode memory but for $13 its a great buy, especially with the machining quality.
I wish I had known that. I just went and bought two. Now I got to return them and buy them again to get my 10% off!
Of course, these will be modded.
I also like the LuxPro LP1200C because it has a reflector that is half OP and half SMO, so it would be good for an MT-G2. It uses 6xAA, so 6 Eneloops and an MT-G2 at 3 amps Zener mod, would be great for that light.
When I revisited my store this morning, I finally located the original display of these lights. Remember up until now they came thru with an XP-G. This new deal has the XP-G2. Here is a pic of both versions and the bar codes on each package is identical. That means both will ring up at 12.97, but what we all want is the newer XP-G2. Just make sure the one you grab is the right one.
The one I bought had a driver potted with a small amount of a Fujik-like material.
^ That pill looks different than dchomak's. Does your light have an XP-G or XP-G2?
