Ok, I pulled the R100 and stacked (3) R120's (left other R120 in place). My resistors are supposed to be 0805 size from FastTech and they are 1/2 the size of the ones on this driver. Does that seem right? Is it ok?
Anyway, current on the LED wire is now:
Low-1.32A
Med-1.80A
High-1.96A
I'm wondering now if the LED leads are too thin. Holding the lead up to 24awg wire I'd say its close to the same size, maybe a size smaller (26Awg?).
It may be that the thing has a maximum duty cycle it will not exceed. The new Med/Low currents do seem to indicate that the resistor mod is having an effect. Just not the end result you want for some reason.
0805 sized sense resistors should be OK with 4 in parallel. They are quite small compared to 1206 sized ones, I prefer to use 1206 when I can. Assuming the 0805’s are good for 1/8-watt or greater, there should be no problem with dumping around 0.3w across 4 of them in parallel.
I recommend replacing the leads first. If that helps, great. If not, I feel that you have run into a limitation of the software that came preloaded on that driver’s MCU.
The modes compressing like that indicate that something else is limiting current. You may be able to just short the sensor bank and still get under 2 amps (probably in all modes). We know that FET is capable of very high currents with low resistance.
I'm having trouble reading the traces. It appears that the top left pin of the MCU in the picture below is the PWM output. It feeds into a 27 ohm resistor (may also have a 10k ohm resistor going to ground) on the way to the FET's Gate. You could try to bypass the MCU's PWM by using a paper clip to bridge the Vcc (bottom right Pin in the pic below) to the PWM Pin. This will be equivalent to a PWM of 255. If current increases significantly, then the MCU may be somehow governing the current to just under 2 amps.
Adding more resistors does seem to be bringing up the lower modes more than raising high. The two LEDs will pass whatever current their relative Vf’s allow. If they’re exactly the same then 1/2 total each. The difference in current measurements isn’t loss in the wires but the additional current used by the rest of the circuit. Voltage drops occur all through a circuit but the current in every part of a given path is constant as long as you account for any branch circuits.
I bridged the upper left MCU pin to the lower right MCU pin and current only increased slightly to 2.196A @ LED wire (still stock wiring). So what does this tell us?
Edit - 2 cells at 3.98v now.
Edit#2 - I get 1.88A prior to bridging. wiggled my connector from battery pack and got 2.24A after bridging now.
Ledoman suggested I take voltage measurements both at the battery pack and at the PCB (where battery wire connections are soldered). Perhaps he's onto something! Here are my results:
Low @batt: 3.87v @PCB: 3.67v
Med @batt: 3.80v @PCB: 3.48v
High @batt: 3.76v @PCB: 3.37v
I'm now going to unsolder the power cord from the PCB and solder thicker wires in place and remeasure.
Ok. If we assume there are also some losses in the circuit you might get voltage to the leds to low. As you probably know leds needs enough voltage to run at certain currents. In your case the voltage at leds might be below Vf (forward voltage). If this is the case there is no way to get desired current.
Also you need to know: more current means more resistance in the wires ie. higher voltage drop unless the wires are thick enough.
At DX forum discussing about some driver I've been advised there can be significant loss in the connector. It is much more powerful driver pulling up to 6A from the battery pack. At that current minimum 20AWG wire is needed. I've been advised to use Deans Ultra connector instead of tipical 5.5x2.1mm which can have resistance of 100 mOhm or more. Unfortunately Deans Ultra connectors are not waterproff.
Bingo! 2.74A after temporary swap of power lead to 18ga wire. Here are my results:
Low @batt: 3.85v, @PCB:3.79v, @LED 1.00A
Med @batt: 3.75v, @PCB: 3.66v, @LED 1.70A
High @batt: 3.64v, @PCB: 3.50v, @LED 2.74A
So now I don't know if the problem is the connector or the power lead wires themselves. Outer cable says 22 AWG and it looks like they could be 22ga. Think I'll still replace the LED wires.
I told you, I told you so . If you would like to know if the most looses are in connector then try to solder same type and lenght of cable directly and measure again. I would be very interested in the results as I'm in the same boat many times.
Alternatively I would use better and/or shorter cable. Where I can I use THIS one from DX hopefuly 20AWG. Still, connector is not good for very high currents as I've explained in my post above.
As you mentioned above, Deans Ultra is good for high current. It’s certainly not waterpoof, but I don’t think getting it a little wet would be a problem.
