What's the best zoomie at any price?
One of my co-workers that I’ve converted loves zoomies. He’s looking to step up his game and get a more powerful zoomie. Currently has Sipik SK68 and SK98. What should be the next one for him to get and is there an ultimate zoomie?
Update with summary from posts below and some other searching:
Zeusray $9.99 $7.99
XM-L2
solid pill for better heat management
580 kcd Lux
1 x 18650 Battery
Available: http://www.dealmetic.com/product.asp?ID=FL05518
Review: Review: Zeusray CREE XM-L2 zoomable flashlight
UniqueFire UF-1405 $37.36 $27.35
Runs 2 x 18650 or can run 2 x 26650 for longer runtime
58kcd at 4.5m
Available: http://www.gearbest.com/led-flashlights/pp_71429.html
Review: Uniquefire UF-1405 - A worthy zoomy?
JAX Z1
$ 59.79
1 x 18650 Battery / 1 x 26650 Battery
AR coated Lens
43 KLux @1m/Kcd
946 metres range
Available: http://www.banggood.com/JAX-Z1-Cree-XM-L2-U2-Zoomable-1100LM-5-Mode-LED-Flashlight-p-940891.html
Review: JAX Z1 XM-L2 zoom
JAX Z1 Extension tube for $6
WOLF-EYES Seal Hunter
$226.76 $149.99
131kcd
Available: http://www.banggood.com/WOLF-EYES-Seal-Hunter-CREE-XM-L-U2-1000lm-Zoomable-LED-Flashlight-p-919779.html
Review: Wolf-Eyes SEAL-picture heavy
Best and ultimate at what?
BTW - this is a brilliant zoomy, regardless of the price:
Very high output, compact and small enough to fit in your pocket. Nicely made, even has good tint.
Worth noting, larger LED’s (XM-L or XM-L2) won’t throw as well as smaller LED’s, but offer more lumens. This means on flood they are brighter, but won’t light things up as well at a distance.
The SK68’s tend to use an old XR-E emitter, it’s tiny and not many lumens, but throws light very well.
Out of my zoomy collection, this is along with the Zeusray linked above, is my favourite:
http://www.fasttech.com/products/0/10000890/1075602-pop-lite-t33-cree-xp-e-r3-220lm-white-led-zoom-fla
Not the highest output, but a nice mix, it does however throw very well. And it uses a TIR not a aspheric optic.
The best zoomie in terms of throw may be the Uniquefire UF1405, but I doubt that you want to go that big. The Jax Z1 is very polular and of awesome build quality and a bit smaller. But any XM-L(2) zoomie improves tremendously when a dedomed XP-G2 on a DTP copper board is swapped in and the driver upgraded to 3.5A. So you need to specify things here, must it be a small one etc.
I think for me the best overall zoomie is still the Uniquefire UF-T20, provided that it is modded with a dedomed XP-G2 at 3-3.5A.
If the zoomie has to be smaller, I like the Cofly KX-A036 the best: good quality, cheap, very moddable and nicer than the Zeusray a lot of people are raving about.
For an AA zoomie I was very pleased with the Cofly KX-H10, better performance and quality than the other AA zoomies around (and I like the coloured plastic window :-) ).
From what I hear, the expensive zoomies do not perform much better than the cheap ones.
Good point. I intended to leave the criteria vague as I just don’t see many zoomies past the $20 range, other than the LEDLensers. I’m personally a lumen whore, so I don’t see many multi emitter zoomies other than the $500+ LedLenser ones, like the X21R.2.
Are there other multi-emitter zoomies?
Barring multi emitters, are some zoomies significantly better throwers than others? I know the onestopthrowshop has a SmallSun ZY-C10 that they sometimes sell rated at 107Kcd. Has any one put together a table of aspherics and their lux values?
that Poplite looks like a led lenser p7.
Only p7 uses 4xAAA
Trouble is modded lights can be vastly different to stick lights.
A good zoomy can have the ability to throw similar to a reflector of equal size. But without the spill beam.
Throw really comes down to the emitter size and its surface brightness. This means lower lumen less like the xp-e often work well for throw. But you won’t get the same level of output in foods compared to an xm-l.
Not seen any other multi emitter zoomies sadly.
I originally considered the Trustfire Z1 (not the CR123 one) for my first LED flashlight. link
That Jax Z1 that djozz posted looks pretty badass though.
I really don’t like zoomies though so I haven’t really looked at many of them to know whats good.
I have a few values that give an idea. These are the maximum lux-values that I have obtained, with dedomed XP-G2 on copper at 3-3.5A (the sk68clone a dedomed XP-E2 at 2.2A):
Sipik sk68 clone, effective lens diameter 20mm: 39 klux@1meter
Uniquefire UF-T20, effective lens diameter 32mm: 108 klux@1meter
Uniquefire UF-1406, effective lens diamer 45mm: 235 klux@1meter
Uniquefire UF-1405, effective lens diameter 62mm: 407 klux@1meter
As you can see the lux-values go up quite lineair with the surface area of the lens, as predicted by theory. You can do fancy expensive things with wavien collars to get more, I do not have those.
DEFT-X https://omglumens.com/DEFT.php :bigsmile:
Around 1000 Kcd.
the DEFT-X is not a zoomie, it is a fixed thrower. Therefore it can make use of a reflecting collar, that would interfere with a zooming function.
I have bought a couple of these and find with an easy mod they have a very good output and a good throw
http://www.banggood.com/Ultrafire-CREE-XML-T6-1800LM-5-mode-Zoomable-LED-Flashlight-p-75196.html
The driver in both of mine is a F13 driver like these
Driver Ultrafire F13
The driver has a second ouput (but not marked in this) which has a good output, the main down side is a hollow pill, trying to get a mate to make me a middle for the pill
I just moved output over and swapped in a XP-L on noctigon (21mm) and it easily has more output and a smaller hotspot square than the Zuesray I would say at least 25-30% more lumens.
It also takes a 26650 battery and only costs £5.22
That’s awesome! Exactly the kind of thing I’m looking for! Thanks!
If your friend’s smart about handling li-ions, the li-ion dealmetic zoom is a good bet.
I wonder how stock Jax Z1 vs stock UF-1405 with XM-L2 would compare…
vs
Yeah, he only uses protected 18650s from reputable vendors and charges them on his desk while he’s working so he can keep an eye on them. Never drains them to cut off.
Of large ones, I like the insides of the Uniquefire UF-T20 and the outside of the Yezl t9. The Uniquefire UF-T20 is well made with a nice short focal length glass lens, XM-L2, etc. but it is pug ugly. I like lights made by soldering together pieces of copper pipe, but I don’t like an NC machined shape to look like it was patched together from plumbing surplus. It feels bad in the hand too.
The Yezl is my most beautiful light, with a smooth elegant unusual shape and fine detail, but both the fancy drivers quit the first week, and the thin long focal lens is only good at extreme throw and extreme flood. With replaced drivers and lenses they are my best lights.
In a smaller size, it is the SK-58, though most others have their niches. The TrustFire Z8 has lovely stainless steel threads and enough aluminum for cooling. I like an UltraOK SK-68 for more than two amps, because of the cooling. The Coast HP1 and others of its type have high optical efficiency even in throw mode, unlike simple converging lens zoomies.
I agree about the Zeusray for intermediate size. But there are other good lights in its class, such as the SK-73.
What is a wavien collar? I don’t see how one can get better throw, with the same area, than a lens. That is, it does not appear to be possible, to me.
The JAX Z1 looks good, except for price and what looks like a thin long focal length lens that will give an unnecessarily small spot with little improvement in throw.
The UniqueFire UF-1405 looks like it would work well, but is ugly and sharp cornered, like the UF T20.
The Uniquefire UF1405 is probably the ulitmate right now. Massive throw, but it’s huge.
For a smaller light I would go with the UF-T20 I love that little light.
Of course either of them benefit greatly from a de-domed emitter and better or modded driver.
