So my light arrived…
batteries are charging so I can test it…
Impressions so far is not favorable so far as QC goes.
First thing i noticed…
box not even taped shut. Single peice of bubble wrap half covering light.
damaged anodizing
scratches on lense
impact marks and scratching on inside of reflector.
strange rattle when handling light.
Ok so Im not going to turn on electronics that rattle…
Pull the light apart…
No lubrication on any threads.
more damage to anodizing
scuff marks and what looks like a finger print on the led’s dome.
unscrew the pill…
located the rattle…
there is a random screw bouncing around on the driver… doesn’t match any other screw in the light so not sure where on earth it came from.
Batteries almost charged.
wonder if it will turn on!
Turns on ok…
High. Med. Strobe.
Bit floodier than I expected.
Dedome time
I just finished modding one of these and it turned out fantastic. I put a R50 over the resistor, added heavy gauge wire and used silver coated braid for the tailcap springs. I de-domed the emitter and put in on a noctigon. I also changed the centering ring out but I have no idea what ring I used. I always have a bunch of them so I just kept trying different ones until I hit on one that worked right. On the pill, I turned it upside down and lapped the surface with different grits of sandpaper until it was shiny. Then when I put it back in I used a combination of “omegathermal 201” and silicone carbide on the threads and around the bottom for much better heat transfer. Because of the vast discrepancies in testing I am not going to post my lumen count or KCD numbers. I’ll just say it’s Very bright and the beam is perfectly focused. At a quarter mile you can still see the round hotspot on trees. For me that puts the light into the super thrower category. Similar in lumens and throw to a fairly well modded TN31.
I remembered member LinusHoffman mentioned this is not a light for a beginner. I found out that is very true.
- The switch came unscrewed (or loosened during mail)
- The switch is very light - too easy accidentally to turn on. Needs washer mod.
- Absolutely tiny wire on the negative terminal - looks like AWG28! Needs some copper.
- High resistance steel spring - needs silicone wire mod.
- Pill has no hole to turn - needs some drilling
- HUGE HUGE thermal sag in the beginning. About 20% output drop in 10s. What were they using? Dang - the star doesn’t even touch the pill! It’s just sitting on top of the very strong epoxy-glue-like-gob. Needs emitter swap - XML2 on copper and proper thermal paste.
- Pill threaded to deeply in - emitter cannot focus properly. Barely touches the reflector. Needs focusing-refocusing by adjusting the pill depth until proper focus is found. CAUTION. Will blast 100+kcd straight to your eye if mod#2 is not done. Trust me
Honestly I was only looking to solder a copper line to the negative terminal - and ended up having to do all of the above. So, yeah, prepare some time if you’re modding this.
In the beginning this is not too spectacular a light. Just around 50kcd and not impressive considering its head size and people’s expentancy.
After initial braiding etc and shorting the resistor - it gets to 100kcd but drops quickly to 80ish - signs of huge thermal sag.
After emitter swap and final tuning, I managed to get 130kcd and it holds steady. Boy I must say this light is impressive. It’s not even dedomed, and I’m already so happy with the throw.
I'd love to see you post amps (taken anywhere you want) and throw #'s. We will gladly accept "18sixfifty" lumen and kcd #'s . I've been adding a disclaimer when posting #'s - simple CYA. I refuse to let a small minority's (1) objection stop me. Would be interesting to here if someone got over 400 kcd out of one of these...
Silver coated braid? I use 22 or 24 AWG silicone coated wire now, depending on the spring size and seems to hold up much better than braid - I gave up on braid a while back.
I can confirm both.
The Switch was barely attached and needed some force to go all the way down on mine.
Also switched the tiny wire to some copper strand
Yesterday, I changed the LED with this one .
The contacts of the board (even in original) touch the reflector - so I flattened some thick copper strand with my bench vise and soldered it with that.
Now the reflector can sit much closer to the PCB and this light throws well. It’s spot is now the same size as the Yezl Y3 - just a bit brighter because of “no sense resistor”-mod
unfortunately I dropped the light from my bench and now it has a big dent at the back - but it could be worse.
Finally received my Gray Courui D01 - 47 days after making the order. It is indeed a very nice looking light and is a good thrower in stock (no mods, not even focus adjustments or thread lubes or spring braids). My tests at 11 meters read 671 lux (81,191 cd) or 570 meters throw.
Here’s my Gray D01 beside my modified SupBeam K40. The K40 is its closest rival in external specs.
Here are the business ends of my Gray D01 and my K40. The D01 has a wider reflector than the K40. When modified similarly, i.e. same dedomed XM-L2, driver amps and AR lens, the D01 should throw better.
And here are the 1.5 meter beam shots of my D01 and K40. The K40 has dedomed XM-L2 T61B and ‘shorted’ sens resistors giving at least 6.1 Amps to the LED.
i wanted to own one of these baby but i dont want it in stock. so anybody selling dedomed courui?
or any modder who is willing to dedome 1 and i will buy it from them?
shoot me a PM.
I noticed mine's output looked quite "meh" until I shined it long distance outdoors. Then I was like "holy crap this thing throws!" Mine is still stock and I can't wait to see what it can do modded!
I ordered six Noctigon XP16s from Mountain Electronics last 11 March when I can’t find XP16 DT Copper stars elsewhere. The cost for the 6 XP16s was $8.45 and the shipping was $9.5. I needed the XP16s badly so I went on with the order. :~
