Wow, that light turned out... really good. The low current draw is just phenomenally good for the output. Definitely need to pick one up when they become available again.
Some sort of Mirage ... [ Reflected light from the paint on the door , or simply the angle of the picture and a lens effect ]
Either the lens , or maybe a smooth spot on the paint on the door . Its the whitest white surface I have .... The wall gives a green tint [ used before ] which does not reflect the true tint of the beam ...
AA 2000mAh capacity = High 1 hour + , Medium 3 to 4 Hours or more , Low 40 hours +
14500 600mAh capacity = High 1 hour + . medium 3 hours + , low 60hours +
these are guess-ti-mates as there was no time [ folks wanted a review ] to check run behavior [ regulation etc ] , so room for some one else to explore and report .
Nice review! The outdoor shots seem to reflect it has a pretty decent tint.
Sounds like this one needs a 14500 to make a good EDC, besides saving weight.
I wonder if IMR’s will give the same results? Based on the results, it seems well regulated in both ranges.
After such a positive reveiw I can't wait for mine to come in the mail. I didn't pay the $2 extra and that may or may not have something to do with its delay. I have a uniquefire aa-s1 and I like the emitter in it so this light should even be nicer.
Looks like that LOW is a really nice low, and it's 2 lm with both NiMh and 14500 :O (but brighter in MED and HI). Interesting, LOW with 14500 should be a little bit brighter too, don't you think? :|
Itp has to be way more efficent lumen for lumen , But with an edc it’s almost always a question of which light I like better physically .runtime isn’t much of a concern for me on an edc since it’s always catching a fresh battery …oops I jus noticed you’re asking about a AAA vs a AA… I’m changing my vote to the tank light …AAA’s just don’t cut it
