BLF Community Battery Pulls Overview Thread (Laptop packs and Tool Packs)
Bought this new open box Acer AS10I5E pack on Ebay for $19.95 free s&h. Received it and pack date was 7-2012. Inside were 8 NCR18650A green Panasonic 3100mah cells. Voltage was 2.20v for all eight cells. In process of charging 4 cell for 30 minutes and voltage is 3.29V. Repeating on the second set as I am writing. Looks promising for $2.50 per battery!
Update…did a discharge 1.5A to 3.0V and checked 2885mah with the hobby charger. Do figure that at 2.5V minimum discharge would be close to rated capacity. The battery pack was purchased from ebay seller INANDOUTELECTRONICS. Many members here purchased packs from this seller and have been pleased.
I tore into some DELL XX326 11.1V 60WH packs.
I started by trying to read data out of them with PackProbe. Only a few yielded any data, and what they gave was patchy. I pulled open the rest to see if I could figure out why they weren’t working. I could tell that all of them had one or more bad bank of cells. I could also tell that some of the spot welds had broken at some point, perhaps while I was twisting the packs to get the case open.
When I checked cell voltages in situ, I found that all of the packs I opened had bad banks. Some worse than others.
Hmm, that ain’t good, how does each bank look…
Huh, I guess those aren’t bad, the rest though…
Umm, weird…
–2.69v?!? That can’t be right, but the polarity on the multimeter is right.
I looked at a few more packs. Found some more reverse polarity cells, but not with as much potential. A bunch of flat cells, and when I tore out individual cells, I found 0v cells paired with ~3.5v cells in the same bank and more broken spot welds. Not quite sure what is going on, other than these being lousy packs.
Out of 18 cells from three packs, I only have 3 (Samsung ICR18650-28As) that are anywhere worth charging.
Update: The three cells I charged are pretty hammered. When charged to 4.2v and tested on my Opus, they all put up about 1,720 mAh discharge capacity at 500mA drain. These cells are designed for 4.3 discharge voltage, and according to HJKs tests, when charged to 4.2 they give up about 8% of their capacity, which would put them at ~2,600 mAh from 4.2v when new. Internal resistance as measured by my Zh-yu battery analyzer from Fastech is ~75mOhm (for comparison, on the same rig, some pink samsungs pulled from one of those $12 Acer packs with a dozen or so cycles on them now come in at ~60mOhm, and some Sanyo blue top from a 110-cycle Lenovo pack I got from Hagg911 measure 55mOhm).
thanks guys, i will get the OP updated as soon as i start feeling better.
Dell 4M529 Date Sticker: April 2010
11.1 Volt
7,86 Ah
90 Wh
got nine LGABC11865 (pale green)
J096D066A4
This thread needs to be stickied so it can be easy to find.
I tore apart some laptop battery packs last week. I’m new to this and this was my first tear down. I’m not sure what capacity these batteries are. Maybe one of you guys could figure it out?
Working Pull. Sanyo UR18650Y L43C Light Red, Green tip. Toshiba PA3534U-1BRS 10.8v 4000mAh. 6 cells Test 3.53v
Working Pull. Samsung ICR18650-26C Pink, White tip. Dell Type WW116 11.1v capacity 56wh. 6 cells Test 3.99v
Working Pull. Samsung ICR18650-22F Light Green, White tip. HP 485041-002 10.8v 47wh. 6 cells Test 2.53v
Non Working Pull (Wouldn’t Charge). Samsung ICR18650-20B Light Blue, White tip. High Capacity Power Products aftermarket for Sony Vaio, 14.8v 4000mah 8 cells. 2 cells Test 0.00v DEAD! 6 cells Test 3.77v
Non Working Pull (Wouldn’t Charge). Sanyo UR18650F Light Red, White tip. Gateway 600YGR 3UR18650F-3-QC-7 11.1v 5700mAh. 9 cells Test 2.59v
  • Sanyo UR18650Y spec'd to 2000mAh
  • Samsung ICR18650-26C spec'd to 2600mAh
  • Samsung ICR18650-22F spec'd to 2200mAh
  • Samsung ICR18650-20B spec'd to 2000mAh
  • For those UR18650F's I'd say they're 1900mAh granted they came out of a 9-cell pack.
Here's a post in the Buried Treasure thread that should help some bit when hunting for cells in laptop packs.
Thanks everyone for the patience, the OP has been updated.
I Just did my first laptop pull… My old Asus EeePC 1000HD with a busted screen kindly donated it’s battery pack. The battery pack name was PL32-901 and was rated at 8700mAh. It was easy to bust open and not much glue. Inside I found six cells which would be rated at 1450 mAh each.
Edit: As pointed out below the battery pack was 7.4V, not 3.4V, so they are 2900 mAh each.
Nice score. Those cells aren't 1450mAh, they're 2900mAh!
thanks for the post MIKE C and Otanacious is right, those are 2900mAH cells and OP updated
Oh? The battery pack had a rating of 8700 mAh on it. Divide that by 6 and it’s 1450. Is it common that battery pack ratings are not the same as cell ratings?
your math was a little wrong, you needed to divide by 3 not 6
I looked up what voltage those packs the EeePC use run at, and they state 7.4V, and 3.7V nominal in 2S is 7.4V. Also I assumed the configuration is 2S3P after seeing the pictorial proof and capacity rating. In the end 8700/3 = 2900.
Now I want to go out and hunt for those high Wh/mAh 2S3P packs since I've never tore one open yet
Of coarse! Didn’t think of that at all. Thanks.
I’ve updated my post that you link to. Thanks.
thanks Mike C
I did a laptop pull recently, a Lenovo 45N1173, 10.8V 8.7Ah - 94 Wh. I got 9 cells, all measured at 4.08V. I think it is Panasonic 2900mah.
i will get this added asap thanks
Nice thread guys! Sticky’d.
A few days ago I tore apart a battery pack previously installed in an ASUS K52J series. The pack was rated for 11.1V 5200mAh and the cells inside were LGs. Specific model: LGABB41865 2600mAh
2 of them show 0V, I will put them in the battery recycling bins.
2 of them show 3,66V.
2 of them start off at 3,5V and then drop and drop and drop until they reach zero. They reach 0 volts after 10 seconds of measuring. I have disassembled a few packs and I’ve never seen such behavior. I’m measuring the voltage using a Fluke multimeter. Anybody has any explanation for this weird cell behavior?
