Thanks. I care about the stopmask in the middle because it took me some minutes to make the size and position and then it was messed up…arghh!
I will email oshpark my question, wasn’t brave enough until now because I thought I maybe made a well known mistake.
Already read the hint with the vector text in another post from CK, I will try this next time…
@RMM
Why is there only one capacitor on the board?
File is here, just copy into your cam processor directory, then tell it to open the brd file, then run project…then zip all the .* (capital letter files) files (the .GBP and .GTP files are the paste files for OSHStencils), and upload that to OSHPark
There is not much need to go through the extra step of generating gerbers, unless drc errors are causing oshpark to reject your brd (or you want to change a part outline silkscreen without actually editing the part).
or OSHPark shows one thing but for some reason the fab house runs em differently
(like what happened to Werner)
I have uploaded a few .brd files I found in peoples shared project folders, OSHPark rendered them all funky, traces extra wide and shorting. blah blah…when I converted to gerbers, they came out just as I uploaded them…sometimes their stuff goes squiffy…not often but it happens
The fab makes occasional errors whether you use brd or gerbers. I’ve had equal fab errors with both.
I’ve noticed that too. Honestly, if you run drc on the boards, you’ll see the problems causing it. You can only have so many drc violations before you start getting problems. Gerbers mush everything together and can hide some errors. When starting out I can understand ignoring everything to just to get a simple pcb made before you really learn eagle. But it works against you, makes designs harder if you continue like that.
I dunno about all that. Generating Gerbers is definitely the tried and true way. Even Gerbers leave room for error, BRD files leave a lot of room for error.
As long as one isn’t using gerbers because oshpark is refusing the brd due to a ton of design errors. Most fabs don’t even accept brds, its supposed to be helpful that oshpark does. The brd isn’t sent to the fab, they generate gerbers with eagle 6.6.
I got answer from oshpark and its like wight has said it before, fab messed it up, their files look good. No big problem anyway but good to know it wasn’t my fault.
I used gerberfiles before for itead but I like how easy it is to just upload the brd file and see a preview…
Get a program called grbv and it will generate a 3D image of your board as well, you can even change the default skin to the oshpark one and see the way your design will look as well
Like RMM’s Moonlight Special V2 8x 7135
Top:
Bottom:
P.S. RMM when you zip the files, don’t include the revisions in the zip…only the files with capitol letter extensions
