Wight, do I understand correctly that the new design can be used normally for a single cell light without the LDO or as a 2 cell (like a zener but with the LDO instead) with the LDO?
Just making sure the driver works the same without the LDO, I’d like to do this but again my lack of knowledge leaves questions and uncertainties.
Down to 4 of the first version, need to order some of these and make sure I still have LDO’s from my Knucklehead experience. And which ones they are if I do…
No, not correct. I placed some strike-through where I quoted you for the benefit of those that skim. The LDO version requires the LDO. This thread is really still about the AxxDD-SO8 drivers which do not require an LDO (but are are Zener ready). v024 is the current version of the A17DD-SO8, here it is on OSH Park.
RMM asked about selling them, I think he’ll be doing that fairly soon.
I am willing to make me these boards, I have the components but not the FET. And Mouser and Digikey are too expensive. I found these on Ebay, will they do the job? :
I think it’s probably OK for most single cell single emitter applications, but none of the specs are really that good compared to the one I specified in the OP. I think that besides being targeted at a different application this is probably an older FET (based on the use of LFPAK instead of LFPAK56?). PM sent.
EDIT: Changed my mind and added strike-through. Rds(on) is just not looking good here, and nothing else is that good either. It might work acceptably or it might not. It’s definitely not a good choice.
Oh goodies are coming, my boards will be delivered sometime this week.
i took the liberty of adding a little personal touch on the silk screen to the insides, while the credits given where its due, Thanks again Alex for making these beautiful pieces.
I have ordered them in 2Oz Copper instead of 1Oz, Immersion gold, 1.6mm FR4, black soldermask. to my liking.
I am also missing the FET , for now the best (economical) option was the aliexpress seller but It still a slightly lower spec’d FET not sure if this would be an exact replacement for the PSMN3R0
Crap, I had no clue that zener mods were that bad with e-switch lights.... Yikes! Sure it was mentioned (I guess?) but totally missed it. Thanks wight for starting that thread and new board design!! I'll be sure to susbscribe and follow. Hhmm... Means the Y3 MT-G2's had that issue? Oh boy... Deleted - no harm intended Tuff to keep up with all the driver goin's on's...
When you look at the Vgs graphs the Vgs advantage of the FET you selected (PSMN6R0-30YLB) becomes even more clear in my opinion. AFAIK lower gate charge is desirable, also lower input capacitance sounds like a good thing. Dissipation (the 58W number) doesn’t really matter in this context, we should not dissipate anything significant in the FET. The Rds(on) seems like it may end up 10-15 milliohms higher in the Vgs range we actually use. That may not be ideal, but I think it’s acceptable.
Hey wight, was perusing mouser and found the PSMNOR9-30YLD with an even lower Rds(still below 2mOhms at 3V) but it runs the price up. Maybe a GB for a bunch and adding normal postage to that might be reasonable.
When I did the GB for the tiny 10 postage was pretty cheap. Photo envelopes were only $.50 and postage and paypal fees worldwide were only $1.15. These are more expensive FET’s so it makes more sense to do a GB for a bunch than ordering onesie-twosie. Still, it would makes sense to try them out and see if they’re worth the added expense.
This looks like a good FET. I don’t see any downside other than the price; I think all specifications are either acceptable [with no impact on performance] or better. The low Rds(on) through 3v looks especially interesting. Only testing will tell us whether it’s worth an extra $1/ea in general, but I’d say that this FET has better specs than PSMN3R0-30YLD.
