I am down for one also if your still taking people
I’m interested too depending on how much postage to Australia??
Any pictures of what it might look like when finished?
What battery configuration??
multi AA might be a nice change from whats normally available
Has this been mothballed or forgotten?
wow, this sounds pretty cool.
If it’s still in the works, I’d be in for one.
I think a D36 Host would be totally awesome too!!! (Hint Hint) The P60’s Bigger Brother!
I had one too many suggestions with this, and some may want to retrofit quads in there and before agreeing to the final design specs it just made me confused, and i was in the process of machining some new hosts,
As of now, 3 prototypes later, I am in need of a moment of clarity with this, as soon as i have another concept i will resume this once again.
subscribed!
Make it screw in not drop in, possibly will become new standard of P60, at least on BLF
Actually i have one working prototype that is a screw in, all aluminium though but with one xml2 led, this barely got warm to the touch at 3amp single mode driver i had at hand.
P60 reflectors would still be used, so its a great option imho, thanks for the suggestion.
Please work on it, will have better contact to host than wrapping with foil. May be I’m wrong, but imo you can sell it like hot cake.
Aluminium can be good enough for this model, although some may be still prefer copper version for their own reason.
Sometimes you just got to simplify, do what you are comfortable with. Suggestions are one thing, but it's your call ultimately, and I'm sure well' buy what you come up with. I'm thinking comfy's position of alum vs. copper has a lot of merit. If it's easier, cheaper for you as alum, I'd definitely go that way. As comfy has been saying all along, as long as the star is copper, everything after doesn't make much of a difference. Mass and a decent path to outer cooling (fins, etc.) makes all the difference.
I'm a bit spoiled now on e-switch lights - better UI, switch problems elimination, etc. Dunno if it can be accomodated, but again, just a suggestion .
Sinner,
Hope to see prototype photos soon. I’m in for at least one host. BTW, a screw-in pill + P60 reflector? I’ll be chewing on my Seraph in anticipation.
If it ends up being $20, I’ll definitely take one.
Keep up the good work
Will you make copper version on request?
Would be nice if it's legoable with solarforce...same size threads etc.
Would be nice if it comes to reality…
+1
+100
But for now…would be nice if have any progress
I registered here just for this thread. I would buy one if it cost $50, I’d buy several (3+) if they actually end up costing only $20.
PLEASE tell me this is actually happening.
I have some progress but nothing is for sure… Just the P60 host, Triples, Quads, What Nots… Will post a formal gb when everything is in order.
Welcome to the Forum!
