For some measurements I took apart a Yupard version of the Aleto light. It's my spare parts version.
Enlarged
I'm not so concerned about finding more springs as much as the COST of replacement parts which can stand up to saltwater.
Ball Bearing diameter: 0.098 in = 2.48mm (on eBay: 12 pc, 20 pc - make an offer)
I think that may be a decent ball bearing substitute for sea water.
Spring:
OD: 0.103 in = 2.62mm (outer diameter)
ID: 0.075 in = 1.9mm (inner diameter was hard to measure - may not be exact)
Free Length = 0.110 in = 2.79mm (this is the overall length - uncompressed)
Wire Dia. = 0.014 - 0.015 in = 0.36mm
Coils = 3
Too bad these substitute springs cost too much...
from Century Spring (LA, USA):
12479 (SS = stainless steel) ~ double length, but could be cut (cf.
search form)
Lee Spring (in UK) - size may be close enough (
CIM025C 01 S) - passivated SS (
info)
111 Viton o-ring (3/32'' width) substitute (per flydiver's rubber plug suggestion) - So I cut a small piece of a sturdy Viton o-ring and placed it in the spring hole.
Seems to work... I'm playing with it right now... it clicks into place like it's supposed to, but not smooth. I should of sanded the tip and made it rounded where it will touch the switch. I'm thinking a softer o-ring would be better... this Viton is hard. Not sure how long this will last when turning the switch multiple times - it may wear it down. But it's a saltwater light now.
Oh wait, I should coat the magnet in the switch.
You know we wouldn't be having these issues if you guys just bought the light I reviewed above.
BTW I've done a bunch of editting to the original post. If you have Amazon Prime then here you go (
Amzn)
Disclaimer: actually I can't vouch for this Securitylng version - it's possible it could have a weaker driver ("2.2A"). Like I stated above, I measure about 2.8A at the tailcap with the original Brinyte DIV05.
