This looks super awesome… Thank you so much for sharing your work with us. What components do I need to start building these?
Only one 7135 is controlled individually. 7x and 1x. The one which is by itself is actually the 7135 next to the “B” in “BLF” - everything else is part of the 7. Unfortunately making one of the topside 7135s into the single would have involved sacrifices for the rest of the layout. It’s less obvious here because I removed the 7135’s Pin2 from the footprint, but remember that there is a pin connected to GND which goes all the way from the tab to the “front” of each 7135. I don’t worry about putting covered traces under this, but I do not place vias under it.
I also use the stock bevel tip for my iron (a Hakko FX888). I got finer tips, but never got around to installing them.
Thanks!
Don’t forget that with a small code tweak you can stack an FET on top of this thing (although with only on/off control, no PWM).
EDIT: Actually the single is next to the “F” in BLF. Sorry!
Thanks & you’re welcome!
In order to build these and get the 7+1 functionality (dual PWM / low moonlight) you’ll need the ability to flash an ATtiny13A, that is your biggest expense if you do not already have it. In order to flash drivers you’ll need 2-3 things, a USBASP and a way to attach it to the MCU (ATtiny13A). I’m using a Pomona SOIC-CLIP from Mouser, some colorful wires from eBay, and a USBASP from eBay.
For the actual driver hardware you may transplant an entire Nanjg 105c, Nanjg 105D, or Qlite. For offtime you’ll need to add a single 1uF capacitor, X5R or X7R is recommended but you can probably get away with putting almost anything in place of that cap.
With the stock 19.1k and 4.7k resistors from a Nanjg/etc stepdown and shutdown values for low-voltage warning and protection must be adjusted (for a 3v stepdown and a 2.8v shutdown maybe use 138 and 129?).
Here are some links:
- Mouser cart for QTY=10 stock Nanjg 105c components except the 7135’s & springs: http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=6cb7b1d609
- Mouser link for Pomona SOIC clip: http://www.mouser.com/ProductDetail/Pomona-Electronics/5250/?qs=q2OAyjihNMzqkARxZuX5AQ%3D%3D
- eBay female-female individual jumper wires from North America: 4pk 40-Wire Female-Female Jumper Wire; 40P Color Wires Ribbon Cable Arduino USA | eBay
- eBay USBASP from North America: http://www.ebay.com/itm/141381562380
- MTN link for 7135’s (so North America): http://www.mtnelectronics.com/index.php?route=product/product&path=25_76&product_id=60
- uhhhm I thought I had a source for those 5x5mm Nanjg springs, but I guess I don’t. If you don’t have a spring you’ll have to use a pillar instead: Either http://www.fasttech.com/product/1145100-5mm-2mm-brass-pillars-for-electronics-diy-10-pack or 5mm x 2mm Brass Button - but the MTN option will require some careful scraping as it’s a little big for the exposed area of the pad.
My advice is to consider bumping your cart to QTY=100 on all the <$0.10 components in order to maximize your savings and have some on hand. They get very cheap in QTY=100.
Yes. [Insert NASA joke here.]
Sweet! Just ordered 6. I’ve got enough loose 105C/Qlite components on hand to build 8 or 9. Also have what I need to flash attiny’s as well. So the newest STAR firmware should work?
Correct, the firmware on JonnyC’s GitHub should work. JonnyC merged the dual_pwm branch back into the main branch some time ago, so stick with the main branch.
The constants to focus on when setting up the firmware should be these two:
#define MODE_MOON 3
#define DUAL_PWM_START 8
RMM sells parts and board kits with star firmware as well as the moonlight special so I think he might also be able to flash just the mcu for this application and it would not at all surprise me to see this in kit form on his site soon for those of us still not set up to flash our own drivers. Hint, hint. Nice to see this. Has anyone ordered them yet?
Three people that I know of: I just ordered some a few minutes ago, DBCstm, and grantman321. All of us can flash, so we should be good to go.
RBD, you don’t happen to know where to get those 5x5mm 105c springs do you?
I’ve pulled bunches of em off Qlites, they’re hanging around here somewhere.
I’ve got 15 here that I didn’t throw away, yours if you want em.
International outdoor store has a selection but not the cylindrical spring that comes on a 105C. I actually like the “F” size more since it is more compressible than the stock spring.
Hmm, interesting call on the F spring. I’ve only got the E spring, but maybe I want some F springs now. Looks like it compresses flat.
The “E” is a bit soft for me and has a bigger foot but I used them in the butt plate of the Marvin the Martian Blaster.
A rare gem, I smile whenever I see the thing.
As far as the “E” springs, I haven’t actually used them and I don’t remember exactly why I wanted them.
I felt rather silly making it but sure learned a lot in the process. Now if only I could remember some of it.
I'm confused. Remember what?
Steve, Scott was trying to remember how much you owed him for his custom electronics work on your project.
Man, this is really slick. I just swapped out the driver in the Eagle Eye BLF light with a 105C and was wishing for more clearance around the bottom side. Now granted it looks like FT is going with a 105D (managed to see that thread) that would solve that, but this is so much prettier and actually being able to implement dual-pwm would be nice :) Awesome work!
Looks like Oshpark sent my order to the fabricator two days ago, so I reckon I’ll have them in hand in about a week to 10 days at the most.
While I’ve got everything I need to edit and flash firmware… I haven’t actually ever flashed an attiny before. I’m pretty confident I’ll be able to do the flashing itself with the USBasp, cable and breakout board I have…. but I have absolutely no idea what changes to make to the firmware, or if changes even need to be made, or how to make those changes. Is there a crash-course explanation on how firmware works and how to (or how not to) edit it anywhere?
I’m pretty psyched about the dual PWM and can’t wait to try it out. As far as my goal for the UI, I’m hoping for L-M-H with memory and a turbo stepdown after 120 seconds… So nothing too complicated I think. Will probably do off-time mode memory as well if I get around to ordering some capacitors.
