Test/Review of Efest 18650 2200mAh (Black) 2014
Official specifications:
  • Weight: 50g
  • Length: 65.40 mm
  • Diamter: 18.44 mm
  • Top: Button top
  • Bottom: non-procted
  • Typical Capacity: 2200mAh
  • Min capacity: 2200mAh
  • Max discharge current: 22000mA
  • Max charge current: 22000mA
  • Max continuous discharge current: 22000mA
  • Cycle life: 300 times
  • Discharge cut-off voltage: 3.0V
  • Voltage: 3.7V
  • Full Charge voltage: 4.2V
  • Discharge temperature range:-10°C—60°C
  • Charge temperature range: 0°C—40°C
  • Storage: 1 year:-20°C—25°C, 3 months:-20°C—45°C, 1 month:-20°C—60°C
This is a normal (i.e. not high current) 18650 cell. I believe the 22000mA in the specifications is a typo.
There is good tracking between the two cells at lower current and the capacity is fairly constant up to 7A.
Conclusion
Up to a few amperes the battery looks good, but both capacity and current capability is rather low by today’s standards.
Notes and links
The batteries was supplied by Efest for review.
Compare to 18650 and other batteries
It works , but it’s so-so ? Not quite up to today’s speed.
The battery is fine, if:
  • You can get it to the right price
  • Your application only needs 2 to 3A.
  • You do not need the longest runtime possible.
It’s worth what it’s worth , if it fits someone’s need$ .
Those words are mine. Thanks for the review HKJ.
Depending on price, these could be some decent daily driver (5A and below) batteries
At 7 and 10 amp the batteries sag WAY too much
Awesome review…thanks!!!
