That’s what it sounds like to me as well.
RMM is out of stock for the M12 flashlight, maybe on his new order he is able to specify the inclusion of the DTP feature? I plan on sending him an email to confirm this.
I may have been mistaken when I said that the M12 had a DTP MCPCB. I had checked the M24 and it did, and I think that I checked one of the M12s as well, but I don't know for sure now if I thought I had checked it but just got mixed up with the M24. Unfortunately I don't have any more M12s to check out.
If I mixed it up, I apologize in advance.
Don't think anything lost Richard - you are out-of-stock now, so maybe something to ask/check in the next run. I know I was sort of surprised the M12's weren't, but I would think these are high qual copper boards anyway, and probably don't have much loss's, accept for 6+A which is hard to get to anyway... In djozz's tests (https://budgetlightforum.com/t/-/25978), he showed even the cheap copper board at 3A has no difference, and at 4A, it's about 4% or so.
No problem Richard. It’s a great light either way. I have added 22awg wire to the tail sping, and will reflow the led to the dtp mcpcb once one comes in. I’d like to find a blank to fit in place of the stock driver so I can run a better driver without having to remove all of the components from the stock one.
I received this in an email reply from Richard:
“If you’re running at stock levels there is no gain, but if you are going to crank it up then a DTP is a big advantage.”
I plan to keep my M12 at stock levels (no mods), so it’s good to know the lack of DTP will not be an issue.
Does the stock M12 have reverse polarity protection?
+1 agree - probably so small, not measurable or within the error tolerance range.
I would assume so - not sure if they spec it that way, but from look'n at the pic of the driver in post #1, appears to be a diode to the right of the MCU - that's probably responsible for the reverse polarity protection.
Thanks Tom E. I would hate to fry a $65 flashlight because of a careless battery insertion.
From what I have seen, the lesser known Chinese manufacturers don’t seem to write much in their product advertising about the electronic features on their flashlights, such as over discharge protection, low voltage warning, and reverse polarity protection. But the well known manufacturers, such as Fenix, list all the electronic features.
My several days old M12 draws 1.9 amps ( 18650 B batteries) at the tailcap, and they claim circuit eff to be above 92%, is that means that the emiter is overdriven?
It reaches 93k lux at 1 meter with same batteries
1.9A from a single cell is not overdrive at all, in fact it is pretty low; that’s about 8 watts to the LED.
How does it compare with your other xm-l2 lights in overall output?
I am talking about the M12 sniper 2x18650 version,cause i saw ppl talk about it too, if eff is 92% maybe the emitter runs at 3500ma or smth, not 3000ma, or its just the driver eff isnt 92%
My modded Yezl beats it by far, but its dedomed too, still waiting for HD2010 and Olight to arrive
With 19650 PF class barreties it sometimes cant stand the rifle`s recoil, those batteries are a bit short
@ Tom E:
you told us, you`ve tried to resistor mod the original driver. Could you please tell me the results, and which resistors you have tried?
I have bought a used one, but already dedomed. Was reading 120kcd, after the tail spring mod 140 kcd with an 18650 25R.
That`s ok, but maybe i can get some improvemet by higher amps and better focusing?
Mac
I recently bought a M12 from MtnElec, and it has a different UI. It is 4 mode, with memory, and a hidden strobe that is accessed with a momentary half press quickly followed by another half or full press.
I got my M12 from Mountain Electronics in december.
Modes are High, Mid and Low, with hidden strobe.
I dedomed the Led, but got 120Kcd only. Funny thing is, the light seems to be underdriven.
I Haven’t measured the amp draw yet, but even on high it doesn’t even get warm……and yes, I did put Arcit Silver under the MCPCB, but it hardly rediatres any heat from the front……
So, it looks like the driver is missing the High mode.
From the measurements I would guess te led gets 3A at most. At most……
Anyways, tomorrow or sunday I will modd the switch spring, se what that will bring.
I use the latest Keeppower 26650 IMR 4200 so the battery is not to blame
Nico
Oh boy, can't recall. Think I went look'n in my notes too. Is there a post I mentioned this in?
The MtnE listing of the M12 describes that UI. My M12 was before Maxtoch mad some changes (I believe), so guess they changed the modes too?
Nicolaas -- the battery will make a hugh difference. Best 26650 now seems to be the EFEST 3500mAh, but the KP 4200's sound pretty good from GearBest. I mentioned in the OP the top cell I had charged to v4.22 got 4.0A, but with some light modding. Also, no telling now since the driver was changed - to what extent, dunno.
@ Nicolaas:
Mine is a 3 mode (with hidden strobe) too. I am measuring 3,63 A with fully charged KK 4000, about the same with a 25R.
Doing the spring mod ist really PIA. The problem is to get the tailcap out. |(
Make sure you use enough oil (WD40 or something like that) on the tailthread for at least 1 day.
If you couldn`t get it out, please tell me.
@ Tom E:
You only wrote, no success with different resistors. hmmm
I`ve ordered the DTP MCPCB. Still hoping to find the missing 40- 50 kcd.
Mac
I already had the tailcap out, cleaned the threads and re-installed.
I also bridged it when the tailcap was out: not noticeably brighter so modding the tailcap spring will probably not
bring much, if anything, but it needs to be done anyway.
I’ll have to check the amps the led gets, will post results.
EDIT: modded the tailcap spring and light is noticeable brighter, and naticeable more heat coming OTF.
but……clumsy me, now the switch doesn’t work anymore, always on
O well guess I’ll buy a couple of new ones and do it again. This time I will take the spring of first and solder the wire
to the spring and after that re-solder the spring to the contact plate :bigsmile:
Nico
My guess is your copper braid/wire has touched the switch retaining ring or the inner wall of the tailcap. Try to solder the copper braid more nicely without it sticking out from the spring.
Don’t have time today to re-solder, but did take some quick lux readings. With MNKE 149Kcd, with Keeppower IMR 4200 I got 155 Kcd.
This translates to approx 82Kcd with dome on.
The little difference could be due to the Led needing to be a bit further into the reflector.
Anyways, a driver bump to 5A would already bring around 200Kcd, so not bad.
Greetz
Nico
