Thanks for the video wight lot of moves i probably will try out sooner rather than later, on the second to the end i saw your
pomona test clip…… please don’t stop there the flashing how to part is still a bit fuzzy to me.
It would be really nice to have some how to on that, or if i have overlooked some guide on that, here on blf please someone direct me.
I understand i need 3 parts
I asked Tom E and these where his recommendation, thanks again Tom
Everything is very affordable about 20$ but unfortunate the 30$ shipping from digi-key to Sweden kind of makes it less so
But where do i find the drivers for the usb programmer and driver firmwares and how to set up modes and tune those, that is the big question now, and again if there are already some how to’s i have missed please direct me.
Nice videos. If a picture is worth a thousand words, then a video is worth the commercials, then a video is worth pixels times as many, then a video is worth more. Some different techniques to try.
You’re all welcome. (And thanks for the complements folks.)
I struggled with soldering for a long time - but I don’t feel like the struggle was at all necessary to become proficient. The struggle was all because I hadn’t learned to solder correctly, it was not part of the learning process. If you find that the soldering is not as easy for you as it looks in my videos, please post about where you’re getting hung up.
For me the biggest sources of problems tended to be excessive use of force and/or applying heat for too long. IMO generally both of those problems are/were actually symptoms of either a technique or equipment problem. Nobody uses too much force or heats for too long just for the heck of it…
Go do it! If you want to start with something disposable then strip some of the worthless 2-amp DD drivers, you’re probably saving a pile for no good reason. (I know I am.)
What aspect do you have trouble with?
Which boards? If you have the parts what do you need a list for!? Check posts #36 & 38 in the driver thread for A17DD-SO8 parts from Digikey and Mouser. I’d go with Mouser because the shipped cost is significantly lower.
I’m using ~392° Celsius. I rarely adjust, check, or pay attention to the temp knob.
As to the flashing, DavidEF’s link is exactly where I would have sent you. Hoop drew on all the scattered BLF resources I normally refer back to, as well as probably a couple of things I missed. Be very gentle with your SOIC clip, do not pull on or attempt to bend the contact pins.
You’re probably right. The iron only requires gentle pressure; it’s the same for the tweezers and component. In the videos I think the only time I applied any pressure was with the solder wick, which I’m not always very good at using. I should have added flux instead of pressure. The rest of the video I’m really just placing the iron against things.
If heat isn’t moving from the iron to the target then maybe it’s time to clean and re-tin the iron or maybe add some flux to the area the joint needs to be in.
I most often lose components when they escape my tweezer death-grip. There’s no reason for that much pressure on the tweezers but I’m impatient, stubborn, and over-eager enough to have the problem regularly.
Thanks wight for trying to find some more affordable options, but unfortunately the italian ebay sellers price would be 58$ delivered to Sweden
But thanks to chouster i think we have found the cheapest price yet for the pomona test clip in the EU only 29.51$ delivered, nice now i have to check if tme have some of the driver components so i can order them at the same time, thanks again chouster you saved me 30$
So in the EU the final cost for the MCU flasher kit amounts to
Pomona test clip 29.51$ delivered
I want also to build the A17DD-SO8, so from my understanding all the parts are from the nanjg 105d like the resistors, capacitor and the attiny except the FET and otc that i have to buy separately? How about the 105c, are the components the same as the 105d?
Dude alex, I know you don’t think you need one, you think your way is easy enough (right? I know I did for years) but get yourself a few decent work holders, I promise you it’ll make your life a hundred times easier!
I know, I know, the pieces didn’t move around much in the video’s but dude I swear to you, start using work holders (helping hands or a jewlery clamp) and you won’t believe you used to think it was easy to not use them.
I highly recommend the same for beginners too, nothing more frustrating when your new and trying to learn than your work piece rotating around on your or sliding further and further away!
