How to strip a Nanjg-105D for parts with a soldering iron:
How to assemble an A17DD-SO8 with a soldering iron:
Here is the equipment list I used:
Hakko FX-888 w/ T18-D16 chisel tip
a wet sponge (hence the sizzle noises from offscreen in the video) Kester 951 liquid flux in a syringe
3mm Goot Wick (CP-3015 via this listing)
Radio Shack .032” 60/40 Rosin Core solder
WeiTus No. 10 stainless tweezers (130mm x 13mm) from IOS/MTN < these are my favorite tweezers.
black stainless tweezers… maybe ESD13 or ESD14 from this VETUS set.
Really you don’t need all that stuff, but as you can see sometimes it makes things easier. I’d start with a cheap iron w/ a 2mm chisel tip or similar, 60/40 solder, and stainless tweezers. Anything else is gravy!
As far as techniques, mine are not always good.
Basic soldering advice: All of these components are pretty heat tolerant, but if you find yourself unable to make something happen, take a break from doing that thing. Eventually you can burn components by rubbing the iron on them long enough! I made some mistakes with the OTC at the end and really dumped a lot of heat into it. Ideally I would have given up for a while, then come back to it. I’d have removed it, cleaned up the area, and then soldered it in place again.
EDIT: It never really make sense to put this here. It just happened to be related because I was building an A17DD-SO8, so I plunked it down here. I turned the post into a new thread instead: iPhone ready - Nanjg stripping and A17DD-SO8 building videos
Thanks! Sometimes I am more shaky than others, but even with shaking it comes down to technique. IMO shaking can be dealt with pretty well when soldering boards like this.
I have a battery check mode already built in to an on-time clicky firmware, an off-time clicky firmware, and an e-switch firmware. However, both of the clicky firmwares are a bit complicated (I crammed in as many modes as I could fit).
The clicky ones go in a loop (read voltage, display it, pause, repeat) while the e-switch one simply displays the voltage once and shuts itself off. Since the reading can vary from measurement to measurement, it’s usually a good idea to watch it for a few cycles to get a more accurate idea what the actual value is.
Unfortunately the hardcoded voltage values generally need tweaking for each style of driver, which complicates things. I’m hoping to include some reference values for common drivers to make this easier.
Another A17DD-S08 in an Eagle Eye X6, this one powering a Quad XP-G2 S3 3C at 2340 lumens from a Panny BD. Home made heat sink that’s massive. Gosh I love it when a plan comes together! :bigsmile:
Wights FET driver (A17DD-S08) pushes 4 XP-L’s ridiculously hard. Not so much hard on the emitters, but cell draining and heat producing. So I used the XP-G2’s here for some limitations. It’s still pulling over 10A, but the Quad XP-L’s off this driver pull closer to 15A.
I must be getting old, I’m starting to realize there are times that 100% pedal to the metal is not appropriate. Sometimes 98% is called for.
I'm "only" getting 5.85A absolute max at the tail with a A17DD-S08 in an X6 powering an old, good XM-L2 U2 1A on a Noctigon, using 20 AWG LED wires, bypassed springs. It's really hard to tell, but out of the 3 types of BLF 17's I used: v1.0 original BLF - Mattaus, the C_K v3.1 version, and the A17DD-08, the only one I could get over 6A out of was the BLF v1.0 originals. I did not compare these head to head -- all were in different lights/builds, so I can't be certain of anything, but really thought I'd get over 6A in the X6 with the 20 AWG wires, and the lock down retaining ring - seems to have a really good ground (batt -) path.
Multiple LED's is the easy case with low Vf's. The single LED setup is the worse case, but is the best real world way to test the resistance of the driver that I know of. I may have to build up a BLF 17 v1.0 just to see if it can do better. Why I need higher amps is not because of the domed XM-L2 U2 1A, but I'm getting a max of only 3.7A in the X6 (w/A17DD-S08, 20 AWG wires) with a de-domed XP-G2 S2. I have a Convoy C8 with a de-domed XP-G2 R5 that gets 3.95A at the tail on a 7135 based driver.
I saw your post about the XP-G2 over in RMM’s thread. I’ve been assuming that you’ve simply got LEDs with a high Vf.
You don’t really have to put them head to head IMO (although that would be ideal). Instead just measure the Vf with your DMM. If you compare the two XP-G2 setups and find that the Vf is similar between the DD setup @ 3.7A and the linear driver at 3.95A… mystery solved.
After seeing all the smiley faces from Dale-mode mods I sort of assumed that the FET had become a non issue but if it turns out to be the case that the FET could be improved I would gladly pop for 10 of the more expensive ones to spread around for testing to see if there is justification for a GB for enough of them to bring down the cost plus shipping.
Again, let’s not jump the gun. The datasheets clearly show the current FET in a good light, and as far as we know “better” alternatives are all more expensive. IMO the thing to do here is test with what we’ve got vs what we’re trying to meet/beat: the Vishay 70N02. An extra dollar or so per driver really is quite a lot. I’m not saying not to test the more expensive FETs at all, but step one is to see what we’ve got now!
I had bought 3 Convoy M1’s for comparing components before. I can use one of these to put an A17DD-S08 in and compare side by side to the 70N03 version driver. Shall I do so?
Edit: More or less they’re already set up that way. One has the prototype of this driver, one has Richards Moon Qlite, and one has C_K’s Ver 3.1 driver. All I have to do to compare the A17DD-S08 to the 70N03 driver is swap emitters in the proto model. (It’s got an XP-G2 where the 70N03 has an XM-L2 U3 1A)
