Uniquefire UF-1405 - A worthy zoomy?
640 posts / 0 new
bibihang
bibihang's picture
Last seen: 2 days 21 hours ago
Chazzy wrote:
I botched the dedome on this XP-G2 S2 2B |( but it still gets 422kcd measured at 10m from 2 stacked R150s 3.6A at tail.
Hi Chazzy, your mod is interesting but there are something I don’t understand about.
Assuming the stock driver delivers 1.60A to the emitter before modded. By stacking two R150 on top of the R120 it should give you about 4.16A to the emitter (neglect the losses) isn’t it? If you measured 3.60A at tail that would be translated into a whopping 6A to the emitter! Shocked
Chazzy wrote:
Here’s the one with the 3A Nanjg 1A dedome next to stock 439kcd.
In your case 3.0A + dedomed XP-G2 S2 2B = 439kcd
In my case 3.5A + dedomed XP-G2 S2 2B = 310kcd only
That is almost 30% of difference. Sad I used my HS1010 to measure and convert the reading from 4.5 meters. May I know at what distance did you measure the lux reading?
luminarium iaculator
luminarium iaculator's picture
Last seen: 2 days 16 hours ago
100 members=100 different lux meters=100 different readings
So be sure that maybe your 310KCD would show 450kcd in some other lux meter Smile
bibihang
bibihang's picture
Yes I am aware of that. Smile But do we still call 30% of difference as error? Sorry I have never compared my lux readings with a lot of people before so I don’t know how much of difference would one consider as error.
M4D M4X
M4D M4X's picture
I have a XP-G2 on noctigon coming from Hank…
can I use the stock driver?
if yes – which values did you stack on the sense resistors?
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
RaceR86
RaceR86's picture
Last seen: 5 years 11 months ago
Like mentioned earlier, stock driver is well regulated to a level far below what is healthy for two cells. So I decided to try and use that just keep it cheap and simple., and also to see what it was good for. Stock output were no good. Especially not considering the size/capabilities of the light.
I modified the driver to output well above 5A to the emitter outside the light, but it generates a ton of heat, and once it heats up (which happens quickly) output also declines. I decided on 4,8A to be on the "safe side" (added the equivalent to an R080 on top of the stock resistor). I did not consider this safe, but the driver have managed two 20 minutes continuous indoor runs at max output, and about 20 minutes of outdoor use. So it seems good based on limited testing.
The further the driver is pushed the earlier it falls out of regulation. Considering that its regulated down in the  4-5V range, that is no issue. My light is still pushing out the same 4,8A to the emitter (tested with XM-L on cooper) when I had two cells at 4,77v. The warmer the driver gets, the more output it drops. Thanks to all my potting, and lots of solder from driver to pill, Im down to 4,7A @ 30 seconds. If it had no heatsinking it would fall down to 4,5A in less than 10 seconds.
After mod tailcap readings start from just under 3A and goes upwords to 3,4A+ depeding on cells used and how low voltage goes.
I used an XP-G2 S2 2D. The natural high performance choice for de-doming IMO. I also changed to stock centering ring for one that fitted XP-G. That means my centering is perfect. My light can over focus, so I can also get my focus perfect for the highest lux readings.
My light meter is calibrated, by me. To a level well below the highest readings meters on BLF. People can check some of my lux numbers here if you want anything for comparison. But my current calibration is slightly lower now. The other day I compared a light with someone with a high reading lux meter. I had to add 15% to my reading in order to get to that level. That was more than I had estimated and thought. But I don't like being too much above many of the manufacturers that are on the conservative side in comparison to the often seen high BLF numbers. And im not going increase my calibration to a level where Im responsible for pushing (over inflated) numbers higher than anyone else.
As for max potential. I could have pushed the stock driver further, maybe it could actually survive or handle 5,6A? But if its got some ripple, the emitter could be in danger. I also could have rebuilt the pill, which would not have been too much work. Put in a 5Amp FL-2 style driver. I could have squeezed an extra 0,1-0,2A out of that. 5A driver was my original plan when I ordered the light. But settled for slightly less. Since that gave me a simple and cheap mod.
If I had been able to push my S2 2D from 4,8A to 5,6A I would be looking at a 7% lux increase . I know that since Ive measured the light output increase between those currents when collecting data for this thread. That would have resulted in a bump from 457Kcd to 489Kcd with my calibration assuming the driver did not fall quicker due to heat. Probably not worth to push it that far. The light does get very hot after 20 minutes on highest setting indoors. I use the light outdoors, mostly in the cold, so technically I would not mind a hotter light. And I don't really use these types of lights for long. Too narrow beam for me. Its fun though. Smile
I hope that was enough details about the mod and makes things clearer? Feel free to ask any questions.
Oh, I can add some more about the light itself. Switch compartment on my light is small. Uses a tiny switch, not room for a large one switch. I plan to improve the switch assembly and swap the switch. If I put in cells that were a bit too long (protected) my light would not even work since the crappy switch assembly did not handle any pressure. One of the O-rings on the head on my light went bad too.. Not too surprising though. I have recently built over 16 UF-T20 lights. Lets just say they were not all the same. Bad switches in some, bad soldering. Some of those even had differences in how far they would focus. I had to find parts from the lights that could overfocus, and swap with lights that did not focus completly in order to get the best out of all the lights....  After playing with so many Uniqefire lights, Im not a fan of their build quality or consistency in parts, lenses or anything. Jax Z1 is in another league build quality wise, but that is not really budget or comparable with the UF1405. Considering the price I paid for the UF-1405. Just above 26$. That is fantastic value for such a capable mod host. Especially since the stock driver could easily be modded to outperform whatever you can make a linear driver do. Very impressed with the overall value considering the price. Although I would not recommend it as a stock light, especially not the unit I got.
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Chazzy
Chazzy's picture
Last seen: 11 months 6 days ago
Yea this is what is odd about it since it was 1A originally at the tail. These readings are all from a shunt modded DMM.
I’m sure if I did a proper dedome the lux would increase quite a bit but with all the amps going to it I’m thinking of putting a XML2 in there.
bibihang wrote:
In your case 3.0A + dedomed XP-G2 R5 1A = 439kcd
I measured at 10m but I find my lux readings similar to that of TomE’s with similar mods.
Even with a KK at 3.81V I’m still measuring 363kcd from 10m. But at 4.5m the lux goes down to 303kcd with the beam focused to 300m.
"Whoa that's a bright light!" ... Yea I guess.
For guys that don't know. Measure lux at the upper part of the beam where are emitter wires. Beam has best intensity around this wires. If you measure on lower and wider part of the beam(square)  you will get lower readings on lux meter.
bibihang
bibihang's picture
So you mean the distance used to measure the lux plays an important role, right?
But if I remember this correctly djozz measured his 1405 lux reading at fairly short distance too, yet he is still getting good result (400+kcd)?
luminarium iaculator wrote:
For guys that don’t know. Measure lux at the upper part of the beam where are emitter wires. Beam has best intensity around this wires. If you measure on lower and wider part of the beam(square)  you will get lower readings on lux meter.
Interesting, I never knew about this. Shocked Will go back and try again later.
Yes. I learned that from Saabluster(deft x maker) posts at cpf and it is true. That is only valid for aspheric types of lights while for reflector it does not matter since it has different beam projection. Around that upper wires parts square area light has most intensity(especially on edges) while in middle and lower part of the beam has lower intensity.
I just checked mine again 5800 at upper part and 5000 in lower part (7meters). 15 and more% difference. So yes it really matters where you measure.
djozz
djozz's picture
Last seen: 3 hours 27 min ago
Reflectors need distance to collimate, i.e. close to the flashlight there's a hole in the beam. Aspheric lights do not have that, and they can focus. So as soon as the die is projected well at the measuring plane you're good to go. Only if you come very close to the flashlight (within a meter or so?), the focussing gets the lens in a significant different distance to the led compared to infinity, which alters the percentage of the light that is getting through the lens and the optical path through the lens is affected in other ways. You may get abberant readings from the luxmeter then.
I have measured a UF-T20 from 1 meter, two meter and 5 meter, and get effectively the same throw number.
jmpaul320
jmpaul320's picture
Last seen: 1 month 1 week ago
gearbest is sending me one for review
Would you mind keeping the wrong flashlight?
Best wish, May
Tmart service team
Soumil wrote:
PLEASE HELP ME GEARBEsT! IM LITERALLY CRYING!
bibihang
bibihang's picture
djozz wrote:
Reflectors need distance to collimate, i.e. close to the flashlight there’s a hole in the beam. Aspheric lights do not have that, and they can focus. So as soon as the die is projected well at the measuring plane you’re good to go. Only if you come very close to the flashlight (within a meter or so?), the focussing gets the lens in a significant different distance to the led compared to infinity, which alters the percentage of the light that is getting through the lens and the optical path through the lens is affected in other ways. You may get abberant readings from the luxmeter then.
Yeah I think so, aspherical lens might behave a little different with the reflector. I wish I could try to measure mine at a longer distance but it is inconvenient for me to do so.
By the way I have fixed my LD-40 driver last night and I still only get 310kcd out of it though. Well I think I will just live with it, at least it is running with a buck driver which is always my preference. Smile
Stockton-Rob
Stockton-Rob's picture
Last seen: 1 year 1 month ago
Hiya fellas!
Ok I’m getting tempted to order one of them there UF-1405’s.
But from where? I respect Djozz’s opinion, looks like he got his from Gearbest, other got there’s elsewhere. So I’m slightly confused there.
And I’m definitely confused about all this 7315, Nanjg, Buck driver techno-speak too.
What’s wrong with a dedomed XP-G2 or and XP-E2 (both from Hank….in the past) and having it direct drive?
Eh?
Wassup with that?
Eh?
and the lord did utter….‘let there be light’……..and CREE said ‘how much?’
djozz
djozz's picture
Stockton-Rob wrote:
Hiya fellas! Ok I'm getting tempted to order one of them there UF-1405's. But from where? I respect Djozz's opinion, looks like he got his from Gearbest, other got there's elsewhere. So I'm slightly confused there. And I'm definitely confused about all this 7315, Nanjg, Buck driver techno-speak too. What's wrong with a dedomed XP-G2 or and XP-E2 (both from Hank....in the past) and having it direct drive? Eh? Wassup with that? Eh?
Hi Rob, haven't seen you here for a while. There is nothing wrong with a good direct drive, a few of my favorite mods do not have a driver, but 1)the xpe2 can not handle direct drive, 2)the UF-1405 has two batteries in series, the led will not survive direct drive, you need a buck driver or use one dummy battery, 3)there are great drivers now,  finetuned by BLF-members, that direct drive the led as if they were not there, but do add convenient lower modes by using PWM.
M4D M4X
M4D M4X's picture
Hi!
since my DMM is good again (tripped the 10A fuse with my 12 XM-L2 project) i gave the 1405 some time…
i put a R100 on the R120 and got from 0,85A to 2,2 A with black 5200 mAh Keeppower
everyting else is stock (the XP-G2 on noctigon is on the way to swap in)
my Luxmeter gives me around 77 kCd – could that be true?
my HD2010 (4,4A with a BLF17DD and dedomed XM-L2) gives 100 kCd in the same setup…
PLEASE NOTE
bibihang
bibihang's picture
Sounds a bit low to me. I measured 58kcd with stock 1405. Could it be the LED was overheated? What was your measuring distance?
M4D M4X
M4D M4X's picture
distance was 1m on both lights (lens to meter)..
heat – maybe…
LED is still stock with dome / on alu
PLEASE NOTE
Chazzy
Chazzy's picture
heat – maybe…
1m is too close for both those lights. Measure lux at a further distance and convert it to 1m by lux*m*m.
bibihang
bibihang's picture
1m is too short I’m afraid. I always use 4.5m of distance and that might still be insufficient for certain lights.
M4D M4X
M4D M4X's picture
thank you
I will try…
PLEASE NOTE
djozz
djozz's picture
Chazzy wrote:
M4D M4X wrote:
distance was 1m on both lights (lens to meter).. heat - maybe... LED is still stock with dome / on alu
I was told that also many times, so I started measuring at longer distances (standard at 5m now), but for an aspheric light that did not give significant different numbers from measuring at 1 meter.
Chazzy
Chazzy's picture
djozz wrote:
Chazzy wrote:
M4D M4X wrote:
distance was 1m on both lights (lens to meter).. heat – maybe… LED is still stock with dome / on alu
I guess I can’t focus the beam right at infinity. My readings still converge to higher lux numbers from 1-10m without altering the focus.
gamezawy
gamezawy's picture
Last seen: 2 weeks 1 day ago
i am facing a problem with the driver i have modded it with a resistor equal to R010 and i was getting 2.6 at the tail cap reading with a XP-G2
and suddenly the flashlight stopped working and then i found a component on the driver fryed, pics will tell, it is the component that the ( – ) to led wire is connected to it and there is another one beside it with the same name but it looks nothing happened to it
the one on the is the damaged one
so any solution ? what is this component ? and can i replace it ? if no any other driver ?
M4D M4X
M4D M4X's picture
looks like it desoldered itself due to too much current Wink
i would try to resolder that ripped off thingie (Transistor?)
PLEASE NOTE
gamezawy
gamezawy's picture
it cracked and opened in half not just desoldered and i smelled burning , look at the 1st pic
gamezawy
gamezawy's picture
well as i cant fix this driver and i know i cant find a 17mm driver that can take 2 cells in series so i will trim the bill and flat it then i will try to use a 26mm driver something like this TR-0124B 8.4V but i want a driver with a smaller height so can any one please suggest me a driver with 26mm diameter with a short height and can be modded to 5 or 6A ?
bibihang
bibihang's picture
I am using this 17mm LD-40 (or LD-4B as how IOS calls it) in my 1405. This driver delivers about 2.2~2.3A to the LED in stock form. I have replaced the the R100 resistor with two stacked R120 resistors and measured 2.45A at tail – which should be translated into >4.0A to the LED.
It works, but I must say the driver is really pushed to its limit already. The mode changing has became problematic after the resistor-mod, and the light cannot be left on high for more than 4 minutes, otherwise the light will becomes dimmer and dimmer over the time and finally shut off by itself. I thought either the driver or LED was burnt but after a few minutes the light works as normal again. I think the driver cannot handle the heat produced at boosted current like this.
I hope you will finally figure out a way to use a larger buck driver in there, because this is also exactly what I wish to have with my 1405.
lawenforcementguy
Last seen: 6 years 12 months ago
I have a similar problem, the modified 1405 I just bought from someone on this forum started smoking as soon as I turned it on and burned up the driver. It was almost a really bad situation as it burned the battery holder and almost burned the battery before I could get them out. I am now gonna rebuild it with a new driver and looking at the LD-4B linked above because it can be used with 2 batteries. I dont really want to cut/ or use a dummy cell as I need the run time of two batteries for my work. However, looking at the LD-4B driver you linked, I noticed it says,” *Suitable for 1-2-3 18650, 16340 or 18350”. Does that mean no 26650? And also since the input voltage is for,” *Input voltage: 3-16V “ could I add an extension and add another battery?
bibihang
bibihang's picture
Is your modified 1405 using the stock driver?
Your 1405 situation sounds like a short-circuit to me – a short-circuit which involves two batteries in series, definitely not fun at all. My advice to you is make sure your batteries are still healthy before you use them again, check if they still can be charged without overheating, and see if the batteries still can hold the charge for more then 24 hours without significant drop of resting voltage.
I stacked one R100 resistor on the stock driver and it has killed two of my emitters in a split second due to excessive output voltage – something is not right after the resistor was added. Now I label the stock driver as scrapped part so that I won’t forget and reuse it again. Everyone should be reminded that the stock driver of 1405 is not good for high current application. ohaya and wight have done some test and analysis this thread and it is found not suitable for current boosting. I know some members may have good result with the stock driver anyway but I think there is still certain risk associated with it. And I don’t think LD-4B is good for current boosting either.
To put it simple, we don’t have a reliable and high-current capable 17mm buck driver yet.
26650 has the same voltage as the 18650 (neglect the different chemistry), so yeah you can use two 26650’s with the LD-4B driver without any issue, given that your LD-4B is functioning properly of course. By adding another extension does that mean you will use three batteries? So the input voltage will be 12.6V? If that is the case I believe this is still falling within the specification of the LD-4B thus acceptable, but I have not tried and confirmed this yet so just take my words as a grain of salt.
Messing with lithium batteries especially in series could be a dangerous thing, please be careful with everything you do.
lawenforcementguy
I think it is the stock driver, its the flashlight from here: http://budgetlightforum.com/node/36357
Ran it less then a minute when it started smoking. Batteries used were 2 almost brand new 18650 EBL 2600 Mah.
Here’s more pictures, maybe someone can tell me what happened from these:
http://s113.photobucket.com/user/Kyuto_2006/slideshow/flashlight%20stuff
I tested the batteries, one is fine at 4.19 volts, the other one that was in the front is showing 0.0 volts.
