I would be interested in a couple. Suggestion though....because of the mass there will be more than plenty to transfer heat. 6061 Aluminum should cut your costs way down...not just for material costs but also production time. It is easier and quicker to get a finish on 6061 than copper.
I would be in for 6061 rather than copper and I would only use it for a triple
Two for triple builds. Aluminum is preferred due to cost and weight.
At 50 pieces he quoted me $10 each on aluminum and i can do for say 30pcs of aluminum and 20 copper but it will be more than the cost of aluminium ? I'm not a machinist but is $10 fair or should i look into someone else
Seems like a good price.
Did you see how many cuts he would have to make
Will this also have the center hole drilled
I think 50 in AL would go fast, let the people who want copper eat cake
$10 is very fair. I thought about making my own but if I can buy them at $10 it just is not worth it for me to make my own or for anybody to try and lose some fingers.
I will take two to start.......NEXT...
The center hole will be drilled, ill eat cake i want copper for mine :)
I would like one either way on aluminum that way I can do a triple. Copper depends on the price
Thanks
Been wanting a smaller sized triple for a while!!!
Quad/triple only, at least two aluminums for me. I want that quad from an X6 a certain person has been making everyone jealous with
Put me down for 1 aluminium.
1 aluminum quad for me please. It would be really neat to have holes drilled and tapped for the screws that come with the X6 to screw the star to the heat sink. Might be a PITA for various builds though. At any rate I’m up for at least one for now.
I don’t recall at this moment all of the headaches that Dale experienced squeezing an MTG2 into his but the idea of this light with an MTG2 and a TIR is intriguing to me. Perhaps with this TIR Like Ouchyfoot did with his Convoy M1 then it could just be easier to get the M1 and a slug of copper.
-just thinking out loud. Carry on.
For $10, put me down for 2
In for 2 Alu. Please post a sample pic.
I should have a samply by monday,freeme u just hit 1k post :)
I'd be in for 2 aluminum ones.
Edit: Planning to use with the XP32 mcpcb.
I’m in for one aluminum. Prefer two piece for flexibility.
I would be in for a copper one to suit the 32mm triple with ledil optic. As long as it comes in under $30 I’m happy.
LSX ill be having few copper made i say around 15-20pc and thanks for mentioning the 32mm optic
Can u guys post what optic u are going to use ???
so maybe i can have some heatsinks done so it will fit the 24mm optic and another design to fit the 32mm optic
here is the 32mm Noctigon
http://intl-outdoor.com/noctigon-xp32-advanced-direct-thermal-path-copper-mcpcb-2pcs-p-808.html
20mm quad kit
http://www.mtnelectronics.com/index.php?route=product/product&path=68_69&product_id=416
just the lens
http://www.mtnelectronics.com/index.php?route=product/product&path=68_69&product_id=376
IIRC, Dale was more impressed with his triple (or was it the quadruple?) than the MT-G2 he did in the same light. He did also say that you have to purposely crush two 18350’s to make them fit in the tube.
