I'd love to see you post amps (taken anywhere you want) and throw #'s. We will gladly accept "18sixfifty" lumen and kcd #'s . I've been adding a disclaimer when posting #'s - simple CYA. I refuse to let a small minority's (1) objection stop me. Would be interesting to here if someone got over 400 kcd out of one of these...
Silver coated braid? I use 22 or 24 AWG silicone coated wire now, depending on the spring size and seems to hold up much better than braid - I gave up on braid a while back.
I can confirm both.
The Switch was barely attached and needed some force to go all the way down on mine.
Also switched the tiny wire to some copper strand
Yesterday, I changed the LED with this one .
The contacts of the board (even in original) touch the reflector - so I flattened some thick copper strand with my bench vise and soldered it with that.
Now the reflector can sit much closer to the PCB and this light throws well. It’s spot is now the same size as the Yezl Y3 - just a bit brighter because of “no sense resistor”-mod
unfortunately I dropped the light from my bench and now it has a big dent at the back - but it could be worse.
Finally received my Gray Courui D01 - 47 days after making the order. It is indeed a very nice looking light and is a good thrower in stock (no mods, not even focus adjustments or thread lubes or spring braids). My tests at 11 meters read 671 lux (81,191 cd) or 570 meters throw.
Here’s my Gray D01 beside my modified SupBeam K40. The K40 is its closest rival in external specs.
Here are the business ends of my Gray D01 and my K40. The D01 has a wider reflector than the K40. When modified similarly, i.e. same dedomed XM-L2, driver amps and AR lens, the D01 should throw better.
And here are the 1.5 meter beam shots of my D01 and K40. The K40 has dedomed XM-L2 T61B and ‘shorted’ sens resistors giving at least 6.1 Amps to the LED.
i wanted to own one of these baby but i dont want it in stock. so anybody selling dedomed courui?
or any modder who is willing to dedome 1 and i will buy it from them?
shoot me a PM.
I noticed mine's output looked quite "meh" until I shined it long distance outdoors. Then I was like "holy crap this thing throws!" Mine is still stock and I can't wait to see what it can do modded!
I ordered six Noctigon XP16s from Mountain Electronics last 11 March when I can’t find XP16 DT Copper stars elsewhere. The cost for the 6 XP16s was $8.45 and the shipping was $9.5. I needed the XP16s badly so I went on with the order. :~
My D01 in stock form measured 671 lux at 11 meters. This computes to 81,191 cd or 570 meters throw.
Well while waiting for my XP-G2s and 32mm Noctigons, I decided to reflow the stock XM-L2 in 20mm Noctigon, direct-wire the sense resistor and add copper braids last night. That simple mod gave me 953 lux at 11 meters or 115,313 cd or 679 meters throw. It is about the same with my TangsFire HD-2010 with dedomed XM-L2 T6 1B.
Are you able to measure what current it’s pulling? (If so please also mention the cells you are using.)
You can probably increase current beyond what you have now with a better FET, but w/ 3x strong cells and everything braided… I wonder if the emitter will die?
