$10 is very fair. I thought about making my own but if I can buy them at $10 it just is not worth it for me to make my own or for anybody to try and lose some fingers.
I will take two to start.......NEXT...
The center hole will be drilled, ill eat cake i want copper for mine :)
I would like one either way on aluminum that way I can do a triple. Copper depends on the price
Thanks
Been wanting a smaller sized triple for a while!!!
Quad/triple only, at least two aluminums for me. I want that quad from an X6 a certain person has been making everyone jealous with
Put me down for 1 aluminium.
1 aluminum quad for me please. It would be really neat to have holes drilled and tapped for the screws that come with the X6 to screw the star to the heat sink. Might be a PITA for various builds though. At any rate I’m up for at least one for now.
I don’t recall at this moment all of the headaches that Dale experienced squeezing an MTG2 into his but the idea of this light with an MTG2 and a TIR is intriguing to me. Perhaps with this TIR Like Ouchyfoot did with his Convoy M1 then it could just be easier to get the M1 and a slug of copper.
-just thinking out loud. Carry on.
For $10, put me down for 2
In for 2 Alu. Please post a sample pic.
I should have a samply by monday,freeme u just hit 1k post :)
I'd be in for 2 aluminum ones.
Edit: Planning to use with the XP32 mcpcb.
I’m in for one aluminum. Prefer two piece for flexibility.
I would be in for a copper one to suit the 32mm triple with ledil optic. As long as it comes in under $30 I’m happy.
LSX ill be having few copper made i say around 15-20pc and thanks for mentioning the 32mm optic
Can u guys post what optic u are going to use ???
so maybe i can have some heatsinks done so it will fit the 24mm optic and another design to fit the 32mm optic
here is the 32mm Noctigon
http://intl-outdoor.com/noctigon-xp32-advanced-direct-thermal-path-copper-mcpcb-2pcs-p-808.html
20mm quad kit
http://www.mtnelectronics.com/index.php?route=product/product&path=68_69&product_id=416
just the lens
http://www.mtnelectronics.com/index.php?route=product/product&path=68_69&product_id=376
IIRC, Dale was more impressed with his triple (or was it the quadruple?) than the MT-G2 he did in the same light. He did also say that you have to purposely crush two 18350’s to make them fit in the tube.
Sounds good nitro. I want to do the exact same set up as Dale has done in the intl-outdoor 32mm interest thread, but in copper. I will 100% be in for one and possibly a second depending on the final price including freight. But it would depend a little on the time frame we are working on here so I’m keen to hear updates as they happen.
just to show it again this is what im shooting for in copper for the intl-outdoor 32mm board not nice looking as the quad heatsink due to the large 32mm board
Looks good to me. I haven’t checked the size requirements on mine so I will just assume they are correct for what we are wanting to do.
I made the triple one and it worked out fine. Based on that, I also made the quad. Seeing as how I don’t have a lathe or all that fancy equipment, mine isn’t as fancy as the updated diagram.
The Quad makes 2500 lumens with XP-G2 S3 3C emitters. The Triple can make 4040 lumens with XP-L V6 2C emitters. With the Ledil Cute-3 the XP-L doesn’t need to be de-domed, so there’s no tint loss or lumens loss. V5 2D emitters give me ~3800 lumens and V4 3D emitters made ~3300 lumens.
Yes, I have made 3 triples, with the last one having an aluminum sink exactly as pictured. And one Quad, with a more primitive sink but essentially the same as the one pictured.
While I do very much like the X6 with the Quad, the triple is just exceptional! The larger TIR lenses and the style of the lens, it looks awesome and just works.
FET drivers of course, and the best IMR cells I could use. Wights A17DD-S08 is single sided and fits into the X6 like it was made for it.
i have 4 host and they all check out the same size, i was thinking once the sample is done i can send out through out u guys to check to see if it fits your guys lite and see how u like them ?
