Cool, cool, cool. Perfect gift for those who need it.
But I would like to buy such version of S3, it has more floody light (right?). Girls don’t need throwers, do they?
I tested yesterday my brand-new convoy s2+ as a helmet light while skating. Absolutely impressed with the performance of this little thing and, as a newcomer to the world of quality lights, delighted by the T6-4C tint - from now on, I won’t be able to stand flashing ultrawhite lights that blind and blur the tracks. I don’t know about the s3, but s2+ is the opposite to a thrower light, as a matter of fact I would describe it as an almost perfect flooder producing a quite uniform spill with practically no evident hotspot. My only con would be that a protected 3400 ah panasonic fits very tightly (I need to unscrew both head and tail and push it out, not really a problem).
hmmmm there is no label, just a clear wrap and if removed the side protection circuit stays exposed. I think I’ll keep pushing them, it is not too bad :bigsmile:
It turns out that my words that S3 has more floody light applies only to S3/S2 comparison, but not S3/S2+ comparison. They said, that S2+ is more floody than S2:
And I found out S2+ and S3 have the same reflectors. So I can’t find any real difference between S2+ and S3 for now (except S3 has unscrewing bezel). Does anybody know the difference?
Thank you for the clarification. I still might buy one and try to press out the stainless steel ring. I guess I’d also need to bore our the diameter of the switch hole to make room for a “normal” 16mm boot.
That would be problematic. I certainly don’t need stuck batteries on an every day basis. I wonder if Convoy knows about this or if it is prevalent in this model or build.
Is this the red S2+ being offered here or one you already had?
It sounds like Iker has one of those double-wrapped batteries: Panasonic’s wrap, then a strip to connect the protection PCB to BAT+, then another, clear wrap. Some protected cells simply have the bare cell, a strip insulated with Kapton tape and then a single outer wrap.
Yes, the batteries are as wight describes, panasonic NCR18650B which are among the largest 18650 out there with 18.4 mm diameter. Nightspy, this is not the red 2+ presented here but a grey one received from fastech 2 days ago. Probably identical in diameter though but this should be confirmed. It is really not that big of a deal, just that the battery does not slip out by itself but needs a little pushing. The convoy is not to be blamed, these batteries are a tight fit in other devices as well, including a convoy m2 which is much larger than the s2+.
