I think all my Pannies are double wrapped but none have gotten stuck in flashlight tubes. My Callie’s Customs came with very think labels, so they came off immediately; my KeepPower labels started fraying, but still fit and come out easily. My XTAR 2600 cells are probably the tightest of them all, and even these tolerate labels. I am pretty sure these are all double wrapped.
I guess the worst case is when a label is put on a double wrap over the protection lead.
I might just have to order this light and see for myself. Not too much trouble to chuck it up in the lathe if it turns out to be on the smallish side.
Yas, mine is green boot. Didn’t realize that there was a different s2+ with black boot, I just saw it at Simon’s site. There it says that “the inner diameter has been changed to18,7 to avoid rattling of batts”, so my guess is that its fit is as tight as mine or tighter. I can tell you, a protected pannie does not rattle for sure: have seen looser condoms.
Convoy may have bitten a big one with that ID mod.
I just measured my new EvvaTech 3400 mah cells (MMR) and it comes in at 18.66mm at the jumper lead under the cover and no label over it.
My KeepPower 3400mah cells at 18.62mm. My older XTAR 2600 measure in at 18.59mm
And Simon, if you are reading this, you might also note:
In rigid mounted bicycle flashlights, minimal solder on the springs is a real problem and potentially hazardous.
I have had spring solder joints like this crack and could be dangerous is it shorted the cell by the spring touching the housing or other components. I have learned to resolder the springs on my bicycle mounted flashlights. I make sure the solder is all the way around. No more failures.
Also, having the spring on both ends is important for bicycle mounted flashlights. This is what prevents mode shifting from bumps. This is one very good thing about your flashlights.
i have to rectify: the one i just received from FT with a tight fit has BLACK swith so I guess it is the new version which explains the surgeon glove- fitting
Once again, please provide this as a host in other colors than red. There was some info about blue version, not being sold yet.
The metal switch cover instead of silicone looks nice and I think many of us would appreciate it being available with other color options as well. Heck even sell a black version of this tail with the metal switch cover.
I love a nice deep blue purple. :party: I’d take standard blue too.
Unfortunately Simon (convoy-flashlight) hasn’t been online on BLF for 10 weeks. We can message him through aliexpress though.
I’d buy one if it wasn’t red. As I have a S2 2.8A XML U2 I’m not sure that I’d notice much difference in brightness. Is the S2+ a better host than the S2?
