Review / Measurement: Charger module with TP4056 controller
I’ve just received 2 boards from Chip_Partner and they have no logo on the TP4056 chip.
I’ve noticed that MP1405 based boards are offered as widely as TP4056.
It says that they have protection built-in. That might be very useful for small DIY projects. Did anyone here test them. Are they as good as TP4056 based boards?
Anyone found a datasheet on this chip? I did some searching and couldn’t find anything.
Can someone positively identify the 6 solder points on this board so I dont stuff it up. Thanks.
-/+ on the USB side = extra inputs
OUT-/OUT+ are the leads connected to the load
B-/B+ are the leads going to the battery (thru the protection circuit IC)
Thanks. I dont understand what the out + and - is if B + and - go to the battery.
charger out directly connected to B+ & B-
out- & out+ is via protection circuit. purpose is over discharge protection.
USBPort~~TP4056>Battery outprotection circuit~~>Load(OUT)
Thanks again.
Ordered one of these today:
Only now I’ve noticed that there are two BAT- connections. What for? Also, R and G connections are for external LEDs, right? And what is the EN connection for?
Hello,
I need to know where i can buy the TP4056 as chip only.
I want to integrate it on one of my boards.
I do not need the full populate pcb as it is too big
Any link to buy outside of China ?
I am actually in Canada.
Ebay sellers do not need to apply, due to the facts that they are more expensive than the full assembled PCB.
I bought the full PCB for 0.9USD
I haven’t seen this type of board before, I like the idea of integrating charging and protection in the same board! does someone know what kind of protection does it have? over discharge only? or it also has over current protection? if so, how many amps? (I assume It doesn’t have overcharge, being a charger supposed to stop by itself, but if it has also a separate controller for protection with overcharge too, this is a great find!)
I have used this board for a while, i found it when checking out some test/reviews on youtube on tp4056 boards
I might have some ideas. How many are you looking to buy?
On second though, I don’t have any bright ideas. I took a quick look at ebay and in the US, you can get them shipped for $0.50USD/chip in lots of 5, or$0.15USD/each for 100. Yeah, they ship from china, but that’s the source.
http://www.dx.com/p/tp4056-1a-li-ion-battery-charging-module-blue-4v-8v-215797
I doubt it. I just got 5 I ordered from Banggood that were pictured with the TP-logoed IC. What I got was this:
(click to zoom)
well I ordered from ebay, got 4 fake ones with “Topower” letters in spite of asking the seller in advance if it is a genuine chip and providing image.
Now I asked few more sellers on ebay to provide pictures… wonder what will come out of that.
I hope it is even possible to find some honest ebay or other free shipping sellers of these
I believe it’s the equivalent protection IC’s that are round and on the bottom of 18650’s (more or less) example possibly 2A output (I believe for more they use more chips)
I would like to know if reverse polarity protection built in with the protection IC or if you put them in backwards will it smoke the protection IC as well
Datasheet for the 8205A IC
so, out of 6 enquiries This one is the most promising answer, for this item:
_
_
for this item:
http://www.ebay.ca/itm/5V-Micro-USB-1A-Lithium-Battery-Charging-Board-Charger-Module-/400698052359?ssPageName=ADME:X:RTQ:CA:1123
ordered one to check it out
