Test/Review of Keeppower IMR18650 2600mAh (Black) 2014
Official specifications:
  • KeepPower IMR18650 3.6V/3.7V 2600mAh High Drain Li-ion Rechargeable Battery
  • Min Capacity: 2500mAh
  • Typical Capacity: 2600mAh
  • Normal Voltage: 3.6V/3.7V
  • Quality Lithium Ion rechargeable cell made in Japan
  • Maximum Capacity and Reliability
  • Maximum Constant Discharge Current: 40A
  • Maximum Pulse Discharge Current: 60A
  • 4.2 volts max voltage and 3.6-3.7 volts nominal voltage
  • Button top: Yes
  • Cell: Made in Japan
  • Dimension: Max. (D) 18.40mm*(H) 65.60mm
  • Weight: Max. 48.0g
This is a high current battery, how high varies with where I look. With the battery I got a note saying 30A, as can be seen above Keeppower gives it a higher rating on their website. I did also find a datasheet with discharge curves up to 20A.
Very good tracking between the cells. Looking at these curves I would prefer to stay at 20A or below in current.
Conclusion
This is a very good high current battery, it has fairly high capacity and can deliver a lot of current.
Notes and links
The battery was supplied by Keeppower for review
Compare to 18650 and other batteries
Nice…excellent as always HKJ!
:beer:
Excellent indeed. Battery advancements in the real world :-)
Can I find any shop this battery???
Since you live in Europe, try nKon. It is a good and reliable store.
Thanks for the info—
Thank you Tapis
Based on the curves I see it looks to me more like 15 Amps is closer to optimum than anything above that. Things start to sag above 15 A.
That you got from the Sony VTC5, self you got and by the IMR KeepPower 2600.
The same battery is.
