Thanks. I really do think its an excellent value. I love budget lights and feel you get a lot more lumens and features from other offerings but this little bugger has a long track record of reliability. In some ways I feel your backup should be your most reliable light. If all else fails it will be the one you'll need to put your faith in.
I use to carry a stainless steel ITP A1 on my keychain so everything after that feels weightless :P. It really doesnt add much. Youll forget you even have it on. As I said, I dont think this light should be your main torch. It should be the "**** hits the fan/ last resort" light. So if the situation arises, my keys getting uncomfortable for me to hold will be the last of my worries.
Sorry I didnt go more into detail about the emitter. I kind of glazed over it real quick. It doesnt use a traditional reflector and doesnt need a lens because it utilizes a potted 5mm nichia LED. Heres a picture that I should have included in the original post but forgot.
BTW, you dont need to worry about scratching the emitter at all. Its actually done on purpose by many users (me being one). You take some steel wool and rub around the emitter with it. It diffuses the beam slightly and lessens the angry blue tint.
Dsoto, do you by any chance own an ITP A3 EOS or the newer Olight I3? I'd be interested in knowing how either of these compares with the Fenix E01. Obviously the ITP/Olight costs quite a bit more than the E01, but it's drastically brighter on high while still offering a great low mode. Also has a pocket clip. Almost identical size. Seems like close competition.
Well, as far as Nichia vs Cree XP-G R5 goes, there's pretty much no comparison. The Cree is incredibly more powerful. But as the reviewer mentioned, there's a lot more to the equation that just lumens.
The A3 is about 5 mm shorter I believe...I measured my A3 and compared to the reviewed measurements.
I have an Ultrafire single AA that is a little longer and heavier that sounds about like the reviewed Fenix (except that the Ultrafire is about 60 lumens and costs $15).
I would think the advantage of the Fenix would be toughness and long runtime.
The nitecore T0 looks nice. Think i might get one.
These small AAA are tougher than most think. I could not get my Tank007 TK-703 to quit. XP-E and 1-mode though, probably direct drive. Will last quite a while with AAA Alkalines.
The A3 obsoletes the E01 for the reasons you already came up with.
Although, for gifting, the A3/i3 R5 models are quite equivalent to an E01 because people will have to suffer with only two lumens since they will forget about the modes and it will always start in low.
I carry my A3 on my keychain since it is smaller and lighter weight. Mine is the older MLH vs. The advantages of the EO1 has is durability, knurling, tailstanding, and arguably runtime. The Maratac vs. negates some of these.
Very nice review, Dsoto87! Thanks. I tend to place more of an emphasis on brightness, but then again, I usually use the light I have on my keychain at least once or twice a day, which is why I've been carrying the Skyray for a while now.
Having said that, I think I'll pick up a E01 now. The Skyray is likely to stay on my keychain because it can take 10440s, but you can never have enough flashlights, can you? :)
I used to be in the same boat: I had way too many keys, most of which I rarely needed and I hated the added weight in my front pocket. At the time, I just didn't have any space for a keychain light other than a DX fauxton.
So, one day, I bought a dozen or so small clip-on keychain carabiner thingies from the dollar store. My car key looks like this:
I permanently keep my house key and my Skyray S1 attached to my car key. All the other keys have one of the aforementioned clip-on carabiners attached to them. Before I leave the house in the morning, I clip whatever keys and RFID tokens I'm going to need for the day on the car key. That way, I don't need to carry a ton of keys I won't need and I don't have a bunch of stuff flopping in the wind when I'm out riding my bike, but I don't need to worry about loose keys and crypto tokens.
Runtime? The old model is rated 50 hours on low, the newer i3 at 20 hours on low. I and many others have come to the conclusion that the A3 is durable enough for tough usage in the real world. I dropped mine 3-4 meters onto a concrete floor and only the eneloop inside it lost some paint, the light wasn't damaged. The i3 can also tailstand.
I've dropped mine several times too. My ITP has been pretty solid, but I have had some glitchy contacts with one of my Maratac's causing flickering.
The EO1 gets 8 hours of regulation (8-10 lumen) and another 8 hours of dimming on a battery. This seems pretty good for ceiling bounce applications when the power is out, plus it will run a battery further down.
It's probably just measured differently. I think they have to use the included alkaline battery for the measurement according to ANSI, the old runtime test was made using 1000 mAh NiMH.
I think they just increased the brightness of the low mode on the Olight. It's 2.5 lumens compared to like 1.5 on ITP or 1.8 on the Upgrade Edition with an XP-G.
I think they also increased the low's output slightly, which make it easier for me to hold off getting one. If I remember correctly, the 50 hour runtime in low was a little exaggerated (35-40 hours on alkaline).
