My Zip Code is 43452 everyone can check the postage here http://postcalc.usps.com/
Let me no how u did it like priority box or padded envelope if u order 1 copper it will not be over a pound
Yes ill be offering them as a package but it will be extra from the prices of the heatsinks, The xp32 triple mcpcbare $10 for 2 pieces so if u want 1 it will be $5 extra plus the cost of the optic witch i think its $2 ? so it will be the cost of the heatsink +$7+S/H
Just posting that ill be gone for a few days to a week (leaving now to a funeral) but ill post here and there since ill be down in the woods with no internet................ BYE FORUM
I also prefer ordering the package deal for the Triple with MCPCB and Optics if you make the package deal available, by adding:
Quantity 2 - C1074 Cute-3 SS Triple Optic —- 2 x $2.00 = $4.00
Quantity 2 - Noctigon XP32 MCPCB (Intl-Outdoor Store) —- 2 x $5.00 = $10.00
Shipping from your zip to my zip in Pennsylvania via padded envelope is $6.10
Total of preferred order is $35.50 plus $6.10 shipping.
if it turns out you order a run of the heat sinks in only one metal, I will take Quantity 2 of the Triple design in whatever metal you choose, copper or aluminum.
I am confused, i thought it was the LEDIL C11333_CUTE-3-SS that is 16,5mm deep that was the correct optic for the triple build and not the 15mm C1074 Cute-3 SS that is 1,5mm shorter? or are they interchangeable?
It’s taller because the legs at the mcpcb are long, they’ll need to be sanded or filed down. I put my optic on the copper board then used 220 grit sandpaper to get rid of the excess leg that came through the board. Then fine sanded with 320, 400, and 800 grit. Ready to go! (Sounds more time consuming than it is)
Edit: Mouser lists 11333 and 10754 both as 15mm tall. The 10754 is specifically made to fit XM-L emitters so it works well with the XP-L and it’s dome. I got the SS and W and the W is shorter, the legs don’t over penetrate the copper mcpcb like they do with the SS version, for whatever reason. The shoulder on the leg above the mcpcb is correct.
The optic on the far left is the wide version, the two beside it (middle and right) are both SS versions. Notice the leg below the shoulder is shorter on the Wide optic. Beats me…
So….yikes, now we have 3 names each for two different components many people dont have a grasp on yet and its pretty confusing… 10754 = ledil cute-3 = W = better for XPLs? 11333 = ?? = SS …but cajampa listed both as ss so…
What are the advantages of the wider optic and narrower optic for the triple…? Tell me if I’m right, but I’m looking for least work and best fitting for the XPL so that means W right?
Sorry, but this gets pretty confusing to those of us who have never actually done this before and may not even know the terminology of what components are necessary to buy. If you give names to something I’ve not experienced I’m curiously following, but if you give me 3 names for it and then start using them all, I’m lost.
These “packages” should be everything except the EE X6 and the XPLs… right?
We all need to specify one each of the optics with 3 different names, mcpcb and then choose only heat sink material since the configuration of heat sink is set based on you going for 3x or 4x right?
The Ledil CUTE-3 35mm is the one to get if you’re building a triple. This will fit the XP-L in the 10754 and 11333 versions. There are SS (soft spot) and W (wide) variants, but I found the wide one to be too much diffusion and a lot of lumens lost.
Triple X6 35mm optic [Ledil CUTE-3 Data Sheet](file:///C:/Users/DBCstm/Downloads/Cute-Oslon%20SSL%2080-Ledil-datasheet%20(1).pdf)
These are the options, with the Ledil Medium not available anywhere I looked. This is subject to change as they may be restocked at various dealers unknown to me.
Thanks, Dale, that is some great news i got some 10754,10755,10756 but i thought i made a mistake buying those and the C10446_CUTE-4-SS and C10447_CUTE-4-M is also 15mm, very nice that mean one less thing to fix
I got my 10755 medium from a very nice ebay seller
Are there copper mcpcb’s available for the CUTE-4 series? Or would you have to use small individual stars and align them under the optics?
Interesting…
I used a 50mm Tuija in a Mag build with XM-L2’s and aligned 16mm Noctigons under it, works pretty well. So yeah, this is interesting. Now I’ve gotta find the best place to get a 4-up Ledil….
Edit: Best I can tell, the CUTE-4 is made for XR-E emitters, XP-L’s would have to be de-domed or the optics modified for the larger dome of the larger emitter.
I couldn’t say for sure why they made the wide optic so much shorter than the others but given the same shape of the TIR section below the lens I’m speculating that a sanded/polished wide lens will have almost the same beam as a sanded/polished SS lens but with a shorter stack height.
Sorry to hear about Gramms Nitro. Let us know when you are back and I’ll be ordering 1ea of the 35 triple Cu and Alu sinks.
I'd like 1 of the copper triple heatsinks, plus 1 of the xp32 Noctigons and 1 of the CUTE-3 optics. Basically one complete set. I'm in the US. Thanks, and sorry to hear about your loss.
No known square quad 32mm copper dtp unfortunately, the plan is to use 10mm sinkpads in a square on the spacer under the cute-4 optic.
One nice thing about the C10446_CUTE-4-SS is much lower viewing angle only 11° than 18° for the tightest cute-3 SS optic and that still quite wide, i am very curious how it will look.
Yeah there is a possibility that i have to modify either the XP-L or the optic, but Rufusbduck said in your “Interest in Intl-Outdoors 32mm Noctigon” thread when i asked about the cute-4 optic “I think the dome radii are similar enough between xr and xpl or even XML that fit is not a problem but the xr series is about 1mm taller from the solder point to the top of the dome so the focus wouldn’t be the same even if the die sizes were. The leg pins would somehow need to be shortened to allow the optic to drop down over the dome more. From Dales pics though it doesn’t seem to be much of an issue but instead just a possible point of refinement. some here thought it could possibly work as is also.”
So i hope that it should fit, fingers crossed
Dale i have to say that i would really like to see you build the cute-4 x6, i think it is just to interesting not to attempt it myself, but i can’t get all the part needed for quite a while yet, and you are the resident Eagle Eye X6 wizard here and i think it would be nice with a second option for a quad x6 that is not based on the limited production run quad mcpcb that Richard sells.
I look forward to see your build and your debugging of the idea, the great thing for me is that you know you can do it, i can only plan to do my best because i haven’t tried anything this complicated a mod yet.
Yeah i can’t wait to build it, i plan to build the cute-3 also but the cute-4 feels like a possible step up with the tighter angle and hopefully a bit more throwy optic and more lumens what not to like , i hope you confirm my suspicions.
Unfortunately Banggood pulled the sale of the hosts after djozz hosts shipping issue, and i never had time to order those yet, i hope kronological works it out with Neal so we get at least the lens and non shipping damaged reflector soon.
EDIT
I missed that the 7 led 35mm was a serial and not parallel mcpcb
