I was going to comment on that too but I just could'nt get my head around it.
bild0046o.jpg - Click to see more photos
Store and share all of your images @ IMAGESHACK.com
It's not about "need". Does anyone need tens or hundreds of flashlights?
If you have 980L, you still WANT to have X9 (and a few dozen others)
I got mine today. 1.7 A on xtar 2600 at 4.18 v. Nice looking like but I am feeling underwhelmed. May as well have got a KD C8.
update: Maybe I was a little harsh. I do really like the design. I compared it with my trustfire c8 (not as good as the KD C8) and the hotspot is brighter. I expect it to throw further due to the larger head. I still wish I was getting higher tail readings. I was hoping to get 2.6 A +
[/quote]
How would you compare the difference in output with the jump to 2.8A over the average of 1.8A? I imagine the body still handles the heat transfer fairly well. Also, could you provide the link for the Ultrafire reverse clicky? Thanks
[/quote]
The output ist noticable brighter, I cannot compare to some other stock lights as all lights I have are modded :-)
Heat transfer ist good but thermal paste should be used to give more heat to head as the batterty tube ist heating up as well.
Right now I am using a clicky from a C8 but I have some of these on the way:
They should fit properly as the C8 switch is a bit too small in diameter and I hope for a more solid feeling.
Voltage | OEM driver battery amps (high setting) | Battery watts consumed | Modified with KD SKU. S009742 driver battery amps (high setting) | ||
3.50 | 0.70 | 2.45 | 2.45 | ||
3.60 | 1.15 | 4.14 | 2.7 | ||
3.70 | 1.25 | 4.625 | 2.8 | ||
3.80 | 1.55 | 5.89 | 2.8 | ||
3.90 | 1.70 | 6.63 | 2.8 | ||
4.00 | 2.00 | 8 | 2.8 | ||
4.10 | 2.15 | 8.815 | 2.8 | ||
4.20 | 2.50 | 10.5 | 2.8 | ||
5.00 | 3.00 | 15 |
I just bought the KD driver to upgrade my X9, could anybody show a pix of the driver with soldered wires just to give me idea what to do? Anyways, still have 3 weeks waiting for parts bought.
Hi Sparktastic
Thank you for that fine article.
I guess a bunch of us that bought the Ebay X9 flashlights are going to be in the same boat. That is, we have never done a driver mod before, but now we need to learn how.
I have seen the posts and pics on this forum about how to solder the stars to determine modes and how to solder to the + and -, however I have not seen inside the X9 to see how hard the removal and replacement will be.
I hope that someone with experience will do a tutorial that will make it possible for us to do the job.
Ian2381,
Scroll down in this thread to see a pic about how to wire the board:
https://budgetlightforum.com/t/-/918
Changing the driver is no harder than doing it on a p60 pill. The only difference is that the driver is going to need longer wires than what may come already on the replacement. You can just use the ones from the original driver if you want.
Now I'm just curious if its possible (by someone like me) to reflow a different LED on this "star" being so big and heavy. I really would love to have this thing in neutral, I'm just afraid the star will hold too much heat and damage the LED. I may just pull the star and fit a copper slug into the opening and mount a conventional 20mm star. I'll have to measure it, but it might just be easier to go that route.
L2T grip rings fit pretty fine :
I have contacted ITC if it is possible to get the grip rings as spare part, I hope the answer is yes or I have to look for the expensive Surefire ones
(added the link to the picture, I do not quite know how to add it directly, the "how to add"-thread was not helping me much)
Changing the Emitter to U2 bin is barely not noticeble in brightness, best improvement ist to change the driver.
This is absolutely true especially if the emitter is really a T6 bin XM-L. That being said, I have experienced an enormous difference in output between a DX purchased "T6" XM-L and a U2 XM-L from lckled despite the U2 being driven at 2.2A and the "T6" at just over 3A (in a bigger host as well).
Either way, I was suggesting the U2 if building the X9 up from a bare host not as an emitter upgrade. Might as well get the highest bin if get to chose.
I have to amend this because I ran into an issue.
With the new NANJG 105C driver I didn't have enough room for protected cells. The tailcap wouldn't screw on fully and the light would come on even when the switch was off (the negative end of cell was contacting the switch retaining ring). This can be solved, but you're going to have to find a washer or two to substitute for the large white spacer in the tailcap.
Also, you'll need to trim the nub off the inside of the boot. The boot is held in by the stainless trim ring, so that needs to be unscrewed. I just used my needlenose pliers in the indents of the ring to break it loose.
Fish
I like your style. Keep up the good work.
Foy
So..if I read correctly the X9 cannot take protected 18650s after replacement of said 2.8A driver?. This has me a little confused as it seams others on here have also modded the driver and made no mention of being unable to use protected 18650. If you don't mind Mitro...would you mind explaining to me why there is a difference in clearance between the stock driver and custom driver and the extent of that difference (i.e..is the replacement thicker then the stock one, or does it have to be mounted in a different location?).
The NANJG 105C has components on the contact side of the driver which makes it necessary to have a spring (included) and it takes away at least 3mm from the space in the battery tube. Maybe some people won’t have any problems, but it was very apparent with mine once I put a Callie’s Kustoms 3100 in it.
You guys make the light sound so good. Now all the ebay sellers are raising their prices. I can not get anyone to sell less than $37. Well I guess I have to wait.
price at $53.80, i think cheaper.
I refrained from installing the NANJG 105 because on my sample it would lead to the same issues that mitro has encountered.
Waiting for good unprotected batteries in hope of avoiding body rework that NANJG would call for.
At the moment, with stock driver, I'm getting 2.05A measured from an AW 2200 (computed about 2.2A in real use), which is quite bearable. The reflector size and quality make up for the lower power. Of course, we strive for both...
Will this upgrade going to be an issue using AW 2200mah and XTAR 18700 2600mah protected batteries? bought this driver to upgrade my X9 using these batteries.
OK Guys,
I am going to go ahead and order some drivers and try this:
1) Desolder the spring from the back of the driver and solder on a short wire
2) Cut out a plastic gasket/insulator the same diameter as the board and put a hole in it for the wire to go through
3) Solder the wire to a metal disk glued to the gasket. Battery + will contact the flat disk instead of a spring
What do you guys think?
I'm afraid it will, even with the AW 2200, which are the shortest protected 18650's I have. The XTAR are much longer.
