Thanks for testing. Is there a way to test the amps after 5 mins on high? I want to see how much amps both those cells dropped and see if the 32650s are really more superior over the kp 26650s from voltage sag
Hi blueb8llz,
There wasn’t much difference after 5 minutes as seen below. But I simply look at it, the 32650 is just a much larger fuel tank and should yield longer run times.
Trustfire unprotected 32650
Start amps - 2.98a
5 minute HIGH - 3.04a
KeepPower IMR26650
Start amps - 3.10a
5 minute HIGH - 3.18a
what if your j20 was highly modded, and pumping out 14000 lumens….would the lights benefit from the 32650s now? ie…keep the lumens going longer and not dropping as fast due to voltage vs using the 26650 kp’s? or will it just be runtime still?
Remember that with the stock boost driver the amps will actually be lower initially with a better cell with less voltage sag. The amps actually climb as the input voltage decreases to maintain the same output.
Aside from sag due to heat, I’d have to say that for sure. Member, RMM, would be able to easily boost the output to 14,000 lumens for you.
Hey guys been a while since anyone posted. This looks like an awesome floody light. Considering going for it. I already have a BTU shocker and a Ebay HID light and I love both of them. But both of them are more throwers and I thought it would be nice to have a strong flooder to round out the collection.
Any updates on the modding going on and maybe new beamshots of the modded TR J20 ?
Mine is still in the works. I’ll report back once it’s finished. But there are lots of other flooders out there that aren’t so chunky. Many are coke style lights. Lots of new ones are being released that’s gotten even more tiny.
Richard at RMM built me a FET driver but I havent had the time to mod my TR-J20 yet. Just to much going on at the moment…
Overlooking their mediocre build quality, the problem with most other large multi-emitter flooders is that they have fairly horrible heat sinking, which makes the TR-J20 an order of magnitude better.
@blueb8llz - what mods are you doing to your J20?
To me one of the big advantages of the TR-J20 should be run time at high output levels if you use 26650 or 32650 batteries in it. Also big enough and with good enough heat dissipation so it can be run at high levels longer after hop up. Any one have a USA source for good 32650 batteries? So far as I know all 32650 batteries are Chinese origin. So far very few lights seem to use this size.
Alright I ordered it along with 4 TF 26650 batteries and a nitecore i4 charger.
Looking forward to it.
And yes the main reason im considering this over others is the awesome build quality and heat sinking as Flashpilot pointed out.
I've got some genuine Trustfire 32650 batteries sitting in Seattle, but I won't be able to offer them for a few weeks. The protection circuit on them isn't that great and trips at around 5A. I ended up pulling them off for use in my 9A MT-G2 Maglite.
Those 32650’s batteries just might be perfect for the group buy on the SD10.
18sixfifty is doin the mod. He is installing a true direct side switch driver. He will be drilling a hole and adding a side switch for me. Changing out all emitters to u3’s. And whatever else that he does to his crazy mods
Do you know which driver mod (if any)?
The tiny ones cannot put out anywhere near maximum for very long unless they have temperature sensor controlled output and are used in situations that give excellent cooling. A windy cold night for example. I have a Supfire L1 that RMM did for me that is putting out 7000 Lumens max per his measurement but has a timer for step down from maximum. He also just returned a TrustFire TR-S700 that now has warmer XM-L2 LEDs on Noctigons installed, much thicker wires and the current sensor resistors bypassed. Not too sure of the output but per RMM it should be able to run at maximum output continuously. A big beast with a good heat dissipation path. Due to the switch design and continuously variable output the driver cannot be replaced which limits output possible. I really like the continuously variable output without either strobe or SOS as to me this is basically a single mode light, idiot proof.
Also talking with RMM about a hopped up TR J-20 with about 10,000 to 11,000 Lumens warmer output. He indicated that he has done several and no one has had switch problems YET! If you want a true high output light that can do it for long then it seems to me like you need the mass and heat dissipation of a massive light with a good heat path. At the moment the TR-J20 seems to be the best candidate.
Rich is right, the smaller hosts just can't handle the heat produced by 12 emitters direct drive, even for a short period of time.
It’s a side switch direct drive blf fet driver. It came from cereal killer
@12.5A at the tail, that thing must be an absolute flood monster! Although declining lumens from turn-on, Im surprised you can get half an hour in DD from those cells before a PC trips. Id call that some excellent brute performance for such a simple mod, and probably the only budget host made that can handle that amount of thermal torment so well. You must be very pleased. :bigsmile:
The Evva protection circuits are beasts, but I'm not sure how long they'll last pulling them at 12A+. Evva tells me around 7.5A-8A continuous is all they're rated for.
Beam shots during those tests?
