Review: Fenix E01 A Quick Overview
It's probably just measured differently. I think they have to use the included alkaline battery for the measurement according to ANSI, the old runtime test was made using 1000 mAh NiMH.
I think they just increased the brightness of the low mode on the Olight. It's 2.5 lumens compared to like 1.5 on ITP or 1.8 on the Upgrade Edition with an XP-G.
I think they also increased the low's output slightly, which make it easier for me to hold off getting one. If I remember correctly, the 50 hour runtime in low was a little exaggerated (35-40 hours on alkaline).
I did a runtime test on low with my Q5 A3 and got 18:20h with eneloops.
e01 left, a3 right (high)
Thanks, that helps. What do you reckon it would give with Alkalines? Alkaline usually lasts longer (going slowly dimmer) on the low mode.
I did not test runtime with alkalines yet. I will buy some fresh alkalines tomorrow and then we'll find out.
According to this thread Link the A3 gave 24+ hours of light on "????"
I have both, and the hotspot is very similar...almost UV purple and oblong in shape. The Coast light is noticeably brighter with more spill and a very ringy beam, plus a forward clicky. Of course, the EO1 is noticeably smaller and can tailstand and is a twisty. Both are nice quality small lights.
Im glad I got some of you interested in this light. Theres a lot of comparison questions raised and unfortunately I dont own any of the lights in question. Im not really into AAA lights as a feel AA is a far superior platform for just a little bit more size. I feel the E01 serves its intended purpose though.
I will say this, I dont own the ITP/Olight alternative but after using my A1 for quite a long time, Im not too fond of ITPs mode switching. I had constant problems trying to get to the right mode. It was very finicky. On top of that I also owned an SA1 (XPG) that I wasnt fond of at all. The quality was decent and you get a lot for your money but I probably wont buy any more ITPs.
For those interested in buying it, please remember... This is the furthest thing from a barn burner/pocket rocket you can possibly get. Do not buy this light to impress people. Buy this light because you want a rock solid backup.
All iTP/Maratac/Olight/4sevens lights are not equal, there is no problem at all with my iTP A3, it's mostly people with SS/Titanium/4sevens-lights that have had problems.
Olight have further improved the threading to avoid contact problems in the Olight i-series.
Here are some pics of the two together. To my surprise the A3 (15g) weighs a gram more than the E01(14g) even through it is smaller. Both weights without a cell in it and not on my small scales as I appear to have mislaid them but on the DX cheap kitchen scales with a low battery.
I think the error margin is 2 grams on those scales...
Too bad they didn't use a better emitter and just power it for 10 lumens. I wouldn't mind a cheap tough light like that.
I already have the A3 (3 mode) and a tough Ultrafire 602 c (single AA-one mode) with an output of 65 lumens.
Give or take 20g. Or thereabouts:)
But I'd be utterly certain the A3 weighs more than the E01. How much more is another matter....
I believe the E01 is rated at 11 lumens.
Though my own measurements with a dead alkaline AAA would say half of that.
The EO1 is regulated for the first 5-8 hours and then has about the same of diminishing output.
I’m waiting on opinions of the new Nitecore AAA light. Hopefully the tint is better.
So we've learned that it's 11 lumens rather than 10 and that when you use a dead battery it's 5.5 lumens :)
I have the ORIGINAL Fenix E01 which is an ARC AAA.
Too bad they still aren't available. A definite classic.
Thanks Don for the side-by-side comparison!
I did not notice that either, only 15h ?! http://www.candlepowerforums.com/vb/showthread.php?322538-Review-of-Olight-i3-EOS-with-measurements-and-outdoor-beamshots
But for the runtime again:
How about DQG tiny II with 30,5mA draw on low? Would give something around 23 - 33h on low with regulation.
I´m not sure about lumens but it is definitely much less than E01´s. Compared to generic nichia CR2032 keychain, it is a lot dimmer. Compared to SC51w, it is between L1 and L2, I would estimate ~1 lumen.
Another good things in DQG:
Better tint, smaller, no glass to break (TIR), 2 modes if ever needed with great efficiency, magnet at tail, SS...
Cons: Price. You get almost 3 E01´s for the price :| Watertightness perhaps? Looks to be quite tight but I´ve not tested. Not as bright on low as E01.
I would like to see "A new E01" with new generation LED driven properly low with good efficiency, simple structure and 1-mode simple UI. I believe it would get good runtime, better tint yet be a good backup. The question is, could it reach the same low price?
My itp a3 q5 runtime test on low with alkalines ended after 24 hours. battery voltage @ 0,9v.
Far from the advertised 50 hours.
I will try the drained battery in my e03 now and see how much juice is left in there.
