Review: Zeusray FL05518 Domed & De-Domed
I wouldn’t soak the whole pill, but I have soaked one or two with the star with no problems.
I did it without the brown reflector and Chicken Drumstick said his got slightly damaged when he did it without taking of the reflector, and i you do the entire pill, please remember to take of the o ring, mine got damaged by the gas because i didn’t remove it.
I did the dedome on this light easily ! Just let it run on high for 5 minutes with a fresh battery and then use a wood toothpick to lightly lift the dome off all-around the LED !
The throw is rather nice for such a small lens (just a few millimetres larger than SK68) but a C8 size reflector light is much better at everything, expect flood of-course.
You can’t use it on high for very long or it will burn your hand ! Even worst if you use copper DTP star. But for the price and the good build quality (except the cheap anodizing) its an incredible value.
Interesting, i want try something like that on my next dedome.
You said on coppar it is even hotter? i bought some diffrent xp-l & xm-l2 on noctigon from hank that i had planned to try in the zeusray when i get some better driver for it.
Did you take the stock led and put in on a coppar mcpcb?
I don’t have a cell in my C8.
As Cereal Killer said, that is what modes are for.
The LED will be cooler but the flashlight body will be hotter much faster with noctigon.
I did it with the stock LED, its easier to do it with a aluminium star because you want the LED dome to be very hot so it become soft.
You should try XP-G2 1D for dedome, better tint and better throw. There won’t be much change compared to stock with another XM-L2 or XP-L.
Thanks for the answer Omega_17,
The plan is to get some A17DD-SO8 or BLF17DD drivers, and upgrade the switch to an omten and use one of the newer lumens bins XP-L V6 or XM-L2 U3 in some different hue bins to test what hue i like the most, i am rather new at this so i don’t have a preference yet. i also upgraded the lens to a glass one, it is not perfect in focus but almost so i will probably leave it like that.
I got the XP-L V6 3D among others because i think it is the warmest of the highest lumens bins.
So my plan is to max it out to the best of my abilities :slight_smile: the one thing i don’t know yet is what i like in hue, but thats where the different xp-l and xm-l2 comes in.
I know you said there is not much to gain from an similar led but Tom E upgraded his with the XM-L2 U3 on noctigon + omten + braided spring upgrade and got a pretty respectable lumens boost even before the FET driver upgrade, ~300 lumens extra.
This was Tom E’s post about it from the consolidated zeusray thread
“Post above has latest lumens measured with the U3 1A. The original #1 stock ZeusRay did 782 OTF stock w/tail of 3.6A. The 918 OTF lumens # was before the tailswitch replacement, afterwards, I measured 1081 OTF lumens. Also I found out later the XM-L2 U2 1A I had and tested in there was defective - it had that weird doggy image on the dye? I didn’t think it effected max lumens, but the XM-L2 U3-1A definiteily did better - bout another 220 lumens bump.”
Video Review:
Nice video review :slight_smile:
And surprisingly good camera work in the dark with lots of different flashlights to keep track of :wink:
What is the effect in terms of lifespan on the pill after de-doming it?
I would happily convert all my pills but if it kills the life it’s not a good trade.
I think you have a point Wentil. Cree has come out with an almost domeless version, but it has some left to protect the LED. I think the life span effect must be negligible as long as you keep the light indoors.
I don’t think it’s a weather issue, as after all the interior of the flashlight’s head, including the collaminator, is pretty much waterproof, given its O-ring design and tight threading.
I’m more concerned that by removing the dome, the lifetime of the emitter surface will be adversely affected. It may burn much more brightly, but at what cost? Surely the engineers at CREE didn’t waste their time and money engineering, manufacturing and applying that dome atop each LED emitter surface for no purpose.
— Wentil
THe purpose of dome is to extract more lumen, make the LED more efficient, so its not wasting their time and money. WE dedome it, is to either get more throw or to change the tint, its like trading for lumen & efficiency.
If have dedomed and dome version, you can compare it. The light is more gradual and even across the illumination area with dome version, where as dedomed version have different tint (colour), different brightness, different throw distance, etc. There are a thread sharing all about dedome facts, but i forgot where is it ~
It seemed to me (in the photos of the review, above) that far more lumens were being generated by the pills with their domes removed.
My interest is mainly in getting the most lumens possible, it doesn’t matter to me whether the tint of the light is cooler or warmer.
However, if removing the dome significantly shortens the life of the pill, that’s something I want to know in advance. :slight_smile:
I’m not sure I understand what you are saying. When you say “pill” do you mean driver? If all else is equal, a domed LED will produce more output than a de-domed LED. If output is all that you care about, leave the dome on.
Used in rain and dust, even though it starts off sealed, I would expect that the LED will likely need wiping off some time. Without the dome, that means wiping off the bond wires as well as the dust and mud.
https://www.google.com/search?q=led+phosphor+seal+volatile
I’m sure domed emitters last longer, but they last a lot of hours anyway. They won’t be the first things to go out on your flashlight, unless, of course, they get fried and go poof, but de-doming won’t change that anyway. I’m not a huge fan of de-doming, but I’m in the minority, and haven’t done much of it.
My only goal is to increase lumen output of the flashlight, so if de-doming accomplishes that — and does not massively reduce the emitter’s lifespan — I’ll give it a shot. I have a large number of LED flashlights to experiment with. :slight_smile:
Yes, lumen output is my main goal. So de-doming will not increase output. Thanks, I’ll leave my LEDs domed. :slight_smile:
