Also fit the Olight M22 filters http://www.fasttech.com/p/1311103
I am thinking of building a triple led flashlight. Is this a good host for it? Any build example?
Seems like a decent plan! You’re thinking of installing a 35mm triple? You’ll need a spacer of course. The stock flashlight uses a glass 37mm lens, so you may be forced to butt the triple optic up against the glass lens so it doesn’t fall out. I’ve been thinking about trying a triple with one of these myself. I can’t think of any build threads for F13 triples, but it should be similar to DBCstm’s Eagle Eye X6 triple builds.
Note that these should be the latest version of the F13 (same as the previous group buy on the same units from GearBest), they do not have a separate pill. I don’t necessarily agree with freeme’s conclusions, but the pics and information are all accurate and worth your time: freeme - UltraFire F13 mod issue ~ mini review included
EDIT: I have just measured the lens opening on an Ultrafire F13 from the previous Gear Best group buy. I got 33.8mm; IMO that should be plenty to keep the 35mm optic from falling out without leaving the glass in place.
Got mine when it was $9.99 a few months ago— great flashlight.
I ordered 2 more. With a little work it should be able to mount the Cute triple XML optic that everyone is using for the EE X6.
I am considering it, since a 26650 would be nice for a triple……anybody considering this?
I would consider it if someone offered the correct spacer for sale. I have no way to fabricate my own
Awesome, great job! Gotta love the ingenuity of making a stinkpad, if for just making it a DTP (direct thermal path) star vs one with the pcb substrate under the emitter thermal slug
Forum tip: highlight the post #, right click, copy link location, post that link location and it will take you directly to the post in question
pilotdog68 wrote:
I ordered one of these as well.
If this doesn’t fit that AA battery holder, does anybody know of a light that will fit it?
It think most 26650 lights take 4AAA holders. I usually solder a piece of copper tubing with a little disk to the holder or to the driver to make up the vertical difference. Much less capacity, but at least you get the voltage up a bit for better performance.
Yes, this light will run 4xAAA with much better output than 3xAAA. See my review of the original F13.
-Garry
Thanks for your input. Yes, I will follow DBCstm’s Eagle Eye X6 triple build (35mm optic, 3 XP-Ls, and 32mm noctigon). I will order one of your FET driver boards from OSH Park (maybe 17mm FET+7135 driver, so I can use it for other lights) and figure out how to make a spacer.
Thanks OL! Ordered one.
Thank you OL
BLF member ‘can’ directed me to this thread and I appreciate it. Just ordered a couple of them. Back when I first got into 26650 flashlights (which is about the time I learned what a 26650 battery was ) I was torn between the TF A8 and an F13. Both were recommended here on BLF. I ended up getting the A8 (actually two of them because my wife took my first one) and it has become my favorite flashlight. Purchased both for $17 each (one on Amazon and the other Ebay) as I wasn’t yet familiar with websites like GB/DX/FT etc. So for the price of one A8 I can now get two F13’s and I’ll be able to compare them. And nice to have a second 26650 light as back up.
Thank you again.
Gotta love OL, “or clone”.
Has anybody ran this with 3xAAA or such?
This is one of the reasons I like my TF A8 in that it can use three different battery options (26650/18650/3xAAA). I’m glad to know this one can do so as well. I think options are important.
Thanks for the heads up!
The F13 is a good budget light at this price.
http://www.fasttech.com/product/1424810-trustfire-tr-a9-2-cree-xm-l2-t6-5-mode-800-lumen
This TR-A9-2 would easily fit that 3xAA Carrier from Gearbest. The Lumintop SD10 4xAA Carrier would probably fit in the TR-A9-2 also. I think the TR-A9-2 had a bad pill thermal design though. Too bad.
Got my F13 today. Wow, very nice light for the money. Thanks for the code OL!
Had a bit of a panic when I opened it up. The star clearly had XML-U2 written on it.
Closer inspection revealed that the emitter was XM-L2 after all. They must have been using up old stars. Phew!
Hmmm me thinks I’ll put a bit more solder on that positive joint.
The writing on stars should never be trusted. Most of us ignore it as a point.
As long as you’re in there soldering stuff, you may as well remove the star and add some thermal grease under it if there isn’t any there already.
Thanks for the pic, looks like a nice solid shelf. Although the anodizing on the shelf isn’t great.
Look forward to getting mine.
They are good lights right off the shelf and better when they have a good copper star and a nicer driver put in. 5 amps is not unreasonable, since they transfer heat well. Glad y'all are having fun with them.
That’s strange… Got mine today too. But on the outside it says “XML-T6” - and that’s what’s inside - so it seems. It is only an older XML with green top, 3 bond wires and 6 stripes. On a grey star with no other text than +/- signs on it. Let’s see what the customer service has to say about that…
