I haven’t picked one out (and I will not be doing so immediately).
Please use these instructions to help find one. See what you come up with by focusing on these things, mostly in this order:
I’d stick to 20-30v rated stuff
high current rating
a fairly low gate threshold voltage since it will be powered by no more than whatever the MCU gets as input. Take a look at the graphs in the datasheet for PSMN3R0-30YLD which show Rds(on) vs either Vgs and Rds(on) vs Id. Remember that our Vgs will be lower than battery voltage… it’s battery voltage minus the voltage drop in the diode and in the MCU. I usually eyeball the performance around Vgs = 3.3v.
gate charge – don’t let it be too high. Look at the other selections we’ve been discussing, but I think you should be fine with <50nC or <100nC or something.
Cutter Electronics has them but both price and shipping are high.
Both are taller than Carclo quad optics and don’t fit the same peg radius as Carclo 25mm quad even though the led locations are the same. On some mcpcb’s all that’s needed is to open the peg holes to the edge of the board.
Thanks, that’s what I was afraid of (the cost in dollars, not the peg layout).
How about:
PSMN4R2-30MLD
or SiS414DN
I’d call SiS414DN the clear winner for this application except for the fact that it’s in a flat-no-leads package. I expect that it will be very difficult to solder for most people. (Actually reflow only for most people I think…). It’s also “Package Limited” to 20A, but I don’t think that’s very relevant here. PSMN4R2-30MLD has more exposed leads and should be a bit easier to hand solder.
EDIT: Clearly I made a mistake. PSMN4R2-30MLD is not that great.
EDIT 2: Clearly I can’t read a datasheet. SiS414DN isn’t that great. I made an error with units (ohms vs milliohms).
I have not evaluated the following FETs beyond Rds(on). Listed in order of Rds(on) performance at our voltage levels:
PSMN2R4-30MLD
PSMN2R8-25MLC
PSMN3R0-30MLC
PSMN3R9-25MLC
Possibly functional, but not characterized well by the datasheet (for our purposes):
PSMN1R5-30YL
PSMN1R5-25YL
Not considered due to high Vgs threshold:
PSMN4R0-40YS
PSMN3R3-40YS
PSMN2R6-40YS
Ok I just added some PSMN2R4-30MLD to my order. hopefully they end up working for our purposes. Just to confirm, other than the FET and the 22k resistor, everything else is stock from a 105c, correct?
I was wondering when/if anyone would incorporate the smaller LFPAK size but resisted suggesting it because of the tight pin spacing(I barely get by on attiny’s and 7135’s). Curious to see how much better it might be than the 2502 or it’s successor(you listening Dale?).
I agree, the pin spacing is very tight. Fortunately only one pin actually needs to be separated from it’s neighbors. Still, if a person is a beginner at reflow soldering I’d say that this is not the place to start their journey. The same thing applies doubly to hand soldering.
PSMN2R4-30MLD vs AO3400? Single LED performance is what matters for this driver I think, and that should restrict us to looking at higher Vgs numbers vs triples & etc. At 3v Vgs it seems like we’d have around a >20milliohm difference in favor of the PSMN2R4-30MLD, which translates to maybe a 0.08v difference in voltage dropped over the FET. To me that looks like approximately half an amp. As you know, all this napkin math doesn’t get us very far. We’ll have to wait for them to be built and tested. (of course it should beat the 2502 by a wider margin)
You’re trying to make me rebuild the Texas Poker yet again, aren’t you?
I would order a stencil if I were to do this one, I’ve been finding the re-flow is so much neater with a stencil and Kester E256 paste.
Edit: I don’t have many (if any) 15mm driver lights. The TP is 10mm and I’m pretty happy with the way it’s performing. That said, I do have a little stainless steel light on the way that I believe uses a 15mm driver…
With stencils I’ve found it very helpful to have a piece of cardboard or something the same thickness as the board or mcpcb with a hole to drop the board into. This lets the stencil lay in place flat and is easier to keep aligned.
