X6 switch help
8 posts / 0 new
nitro
nitro's picture
X6 switch help
Hey guys i need little help on my X6 host........its all built and working but does not work with the tailcap screwed all the way in ? but when i take the tailcap off and turn it to the side the lite comes on and when i keep doing that it switches through the modes
i checked to see if the tailcap is loose and its not
has to be getting ground since it does come on at the very last thread of the tailcap ??
i tried sanding the threads with VERY lite sand paper and still nothing any other ideas
wight
Last seen: 2 years 6 months ago
I think taking a look at this thread about SF tailcaps may help you: RWS34 – Solarforce Switch problems – erratic when screwed down
I don’t really understand what you are saying though. The X6 uses anodized threads: anything other than fully tightened should be locked out. You seem to be saying that if you unscrew the tailcap almost all the way it works.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Rufusbduck
Rufusbduck's picture
Try flipping the battery tube end for end. Even though the threads are the same pitch at both ends it only works one way.
Scott
nitro
nitro's picture
wight wrote:
I think taking a look at this thread about SF tailcaps may help you: "RWS34 - Solarforce Switch problems - erratic when screwed down":http://budgetlightforum.com/node/35781 I don't really understand what you are saying though. The X6 uses anodized threads: anything other than fully tightened should be *_locked out_*. You seem to be saying that if you unscrew the tailcap almost all the way it works.
that's correct if the tailcap is almost off it works and ill try that ^^^^
Bort
Bort's picture
Last seen: 4 hours 29 min ago
If you have a Convoy S2 there were some threads on BLF that said the caps are interchangeable
The Journal of Alternative Facts
"It is critical that there is a credible academic source for the growing and important discipline of Alternative Facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists."
nitro
nitro's picture
Rufusbduck you was right,Switched ends and works perfect Cool Bort i read that also but i did not have one on hand
Rufusbduck
I feel smart now. H)
Scott
wight
Good job!
