Test/Review of Efest IMR16340 550mAh (red) 2014
Official specifications:
  • Size: 16340.
  • Type: Li-Mn (High Drain)
  • Rated Capacity: 550mAh
  • Nominal Voltage: 3.7V
  • Peak Voltage: 4.2V
  • Cut-off Voltage: 3.0V
  • Dimensions: 16.41mm (Diameter) x 34mm (Length)
  • Rechargeable: Yes
  • Style: Flat Top
This is a small high current battery.
The battery works fine up to 2A, but above that the cells has problems.
Conclusion
This is fairly standard performance for a good 16340 IMR cell
Notes and links
The batteries was supplied by Efest for review
Comparison to other LiIon batteries
Thanks for the review.
Thanks for the great reviews!
always appreciated
0.70 Ohm must be a typo
No, but it is because it is calculated between 6A and 7A where the curve drops and I always uses the worst value from the two tested batteries.
Thank you for the review.
The previous Efest IMR16340 you tested were version 2 and they seem to perform better at the 2A.
So these V.1 look like they have similar performance to the Kinoko IMR16340 according to your comparator.
Btw, love the comparator, so very useful!
