As above, I just ran at 1.0A discharge, nothing else.
I have/had 2 lights that took the 26650’s. Gave one away at Christmas and still have the one with a head that pivots to a 90-degree angle….
Personally I see little or no difference in brightness between the 18650 Sanyo battery and this 26650.
I would expect it to run much longer with the 26650.
Should have guessed to rid of “by”. Found the seller finally. Price changed a little. Thanks for the tip to get rid of “by”. The problem gave me a pause to wait for the results of others actual “field” test.
Didn’t (Couldn’t) get the battery. Bedsides I am incapable of doing any testing except the one by eyeballs. I leave the real test to more learned members.
Thanks for the warning about “xxxxFire” batteries. But I consider ‘Trust’ is far better than the ‘Sure’ even though it’s certainly not as good as the name brands. I am considering the Trustfire 26650 because of positive reports from 3daysofdarkness (08/16/2014) and now dno36. Considering this battery basically to check out the 26650 lights, and will be actually used only a couple of times. For that I don’t want to spend a lot of $$$.
$12 might be a bit scant, but what the heck, the worst they can say is ‘no’.
If I recall there were a couple of other sellers in the mid-$14 range.
Let us know what you discover.
Does that how Make Offer typically work? I made a bid of $14. ebay says seller’s response may take up to 48 hours. If that’s not accepted, that may be a good excuse for me to forgo the battery altogether for now.
Yes, “make an offer” is like bargaining. Buyer offers a lower price than they want to pay. Seller offers a higher price than they want to pay. Somewhere along the lines of the bargaining / negotiation these prices meet in the middle.
“Bargaining” is considered very honorable in the Asian sector….The worst that can happen is that they reject the offer and do not counter-offer. If they counter, you can take it or counter-offer back. Go get ’em!
I made an offer and received a counter on this light:
TrustFire-7-CREE-XM-L-T6-8500LM-LED-Flashlight-2pcs-Rechargeable-26650-Battery
Details about TrustFire 7*CREE XM-L T6 8500LM LED Flashlight + 2pcs Rechargeable 26650 Battery
| Add to watch list
Seller information
ttmallzone365 (98390 )
99.2% Positive feedback
I made an offer adding a third 26650 battery to the deal and they came back $2.40 above my offer. I went back to them at $0.50 less than their counter-offer…….we’ll see what happens
Where to begin is the big question. In Mexico I don’t hear about honor in bargaining, but it’s expected. And you hear people bragging about getting deals at 50% off. Wonder if that’s not taken as an insult.
The $14 was rejected, and ebay, not the seller, gave a chance for another Make Offer. Thought about quitting, then considered the fact that getting more capacity battery at 18650 price. Made $15 offer and I fully expect that will be accepted.
Greetings O-L,
I have been exposed to the Ult-Crap batteries from China just like most of us here.
I get a nice chuckle from time-to-time when testing them, but have seen TrustFires test fairly well, so…
I have purchased 4 pairs of Trustfire 26650’s from 2 different sellers recently.
All of them came shrink-wrapped in pairs with the TF hologram label on them.
I tested them all with my iMax B6 at a 1.0A discharge, had to move my time up to 360 minutes because at 330 mins, they were hitting the timer cutoff.
The WORST one of the eight I had was over 5300mAh.
Am I doing something wrong?
I have tested well over 100 different batteries on this iMax and they all seem to make sense to me, except maybe these TF 26650’s.
In series with the battery. You connect the red 4mm charger connector to the 10A terminal on the DMM and the common terminal on the DMM to the + on the battery. The DMM has to be in the 10A range.
The black 4mm charger connector goes to battery minus as usual.
My DMM showed and seemed to rhythmically shift between -0.97 & -0.98 as it discharged. I went ahead and tried 2 other different batteries as well and the results were identical.
I have a basic DMM, but when I got it, compared it to the results to my friends company provided Fluke, my side-by-side results were spot-on with his. So I have reasonable trust in my DMM results.
It is kind of a 'pain' to just test 1 battery at a time with my iMax-B6, but I have gotten along running many tests overnight. I have been looking at some of the multi-function chargers like the Opus 3400, as a better all-in-one type alternative. The resistance results seems to a bit poor in all of these type charger/analyzers.....Maybe to do I-R testing I'll just need to made one of the suggested set-ups and do the math myself.
Thanks again for all your help and the work you do here for all of us!!
