17mm & 20/26/27mm single-sided DD/FET driver release: A17DD-SO8 / A20DD-SO8 / etc
Fortunately for my sanity Eagle doesn’t seem to have an hours counter on my files. You’re right, I have a significant time investment into that layout. There’s approximately one component too many involved: I was easily able to create nice symmetrical layouts when I accidentally left a component out. :wink:
You’re right of course. This entire design was done with two considerations in mind:
  1. diagonally opposed LED+/- at the board edge
  2. some semblance of symmetry
So I can’t get away with moving the OTC there. This final iteration (there were many in between v030 and v041 - I only iterate version numbers when I save, and I only saved during that process when there was an idea I wanted to preserve) started with a component in that position and a hard battle was fought before R1 and R2 lined up at 90 degrees vs the rest to allow everything to fit. More hard battles were fought after that of course since everything failed the DRC if I recall correctly. :wink:
If enough space can be freed up to get the via centered and larger that can probably be done. In the meantime there’s no reason not to drill it out: just be sure to solder the top (component side) when you feed the 22AWG wire through the drilled hole.
Great! I do really appreciate pics of people’s builds, from the driver to the rest of the light.
… and BTW here is an unattractive (to me) v044 - OSH Park ~
As you can see, the central via has been moved again in order to center it on one axis in relation to the silk and exposed copper. The entire central medallion area is still skewed with relation to the B+/LED+ vias. IIRC those guide rings are for 11mm, 8mm, and 5mm… or something.
I plan to take that back to the drawing board and:
  • continue to think about how the central via can be handled
  • fix the skew on the bottom
  • re-do the spring pad like v043, but with a thin, solid combo guide ring for 6mm /5mm in the middle of the 8mm pad.
Today I had time at home with the family away, and was in a bold mood, so I went on building a A17DD-S08 driver, for use in a triple XP-L X6 build. I know Dale has built tons of them but being an electronically challenged person it was quite a task for me (and I failed in the end). Here's the inside story of a clumbsy and chaotic electronics noob, making all kinds of random assumptions leading to wrong decisions:
I had ordered a couple of v024 boards earlier, so then I had to get the parts, which was not easy without spending tons of shipping costs. I got an assortment of resistors and caps from ebay, in the meantime finding out that there is several sizes, and for the first time understanding what the heck '805' meant that pops up in several threads on BLF.
Cereal_Killer had sent me some parts for building a few drivers a few months ago, the nicest was that he sent me some Attiny MCU's on which he programmed my favorite custom UI with off-time mode-switching. From his parts I also used the diode (I know now what SOD23 means), and the 4K7 resistor, the 22K resistor I found in the ebay-assortment. In the meantime I have learned (I had to..) the smd resistor code, and that there is at least two widespread versions of them. Also I looked up again how the polarity of the diode can be found out (the stripe is facing the minus). Unfortunately C_K forgot to add the 4.7 uF cap, and my cap assortment only went up to 1 uF (I used one as off-time cap), so I had to scavenge the C1 from an old NANJG-driver, I picked it up from a 101-AK ().
I am allowing myself one Mouser order every year, and I wanted some XHP70's for trsting and some Rebels anyway so this was the time, and a good opportunity to order some of those PSMN3R030YLD FETS too, and Zener diodes (it took me half an hour to find a thread on BLF that did not just talk about zener diodes, but also contained a part code for it, thanks Ouchyfoot for asking that same question before) and 200 Ohm resistors (could not remember what those were for).
So now I was sorted, I'm a reflow pro, so the actual placing of the parts and reflow on my heatblock went fast and smooth. The morale here is: information is everything, it took me months of figuring how, and arranging parts, the actual build was 30 minutes.
I soldered an old XM-L2 on a board to the driver and pressed the battery against the driver. It fired up alright, but the mode-switching was all funky as well, something was not right (had to do a random number of half-presses to get to high and when on high, after two seconds I got 3 flashes followed by a output step-down, this all was not what C_K had programmed for me). Then I put the driver back on the heat block and swapped the custom-Attiny with a qlite Attiny. Still weird mode-behaviour. Then I swapped again to the 101-AK Attiny. Still modes were acting weird. I thought that it might have been my scavenged C1 cap since it did not come from the 105C but from the 101-AK, so swapped that to one from a disposed 105C. Still funky mode changing. Then I realised that the off-time cap was still there, so I removed it. Now I got a familiar working driver at least.
I decided to make another of these drivers because perhaps the custom-Attiny was not at fault, but the wrong C1 cap. So I re-used the custom-Attiny and made me another A17DD-S08, with the correct C1-cap. And mode-switching worked smooth on this one. I thought victory!
Encouraged by succes I went on to zener-mod the first driver (with the 101-AK-Attiny) in the workaround way that was tested out for v024 . Lucky for me Dale posted a picture of his build a bit north of this post, because else I would have had put in the zener backwards. I got it soldered in nicely with the cap cosy against the zener (I can solder well) and fired the driver up, nothing. Then I realised that also the diode had to be replaced by a resistor. Hoping that I had not destroyed the driver I replaced it with a 220K resistor (Dale's picture showed 2000 on the resistor, and with my newly acquired knowledge that had to be 200K-Ohm ). Still nothing. Then I decided that I was no good in this and rebuilt the driver to single-li-ion without zener-mod. When the zener was removed, C1-cap in original position, and RVP-diode back in, the driver was dead!!
Still happy with the second driver, I started playing with it, and now it appeared that mode-changing was indeed very smooth, but that in high mode the flashes plus step-down after just 2 seconds was still present in high mode, horrible! I did not test it long enough before on high to notice (test-ledboard was not attached to anything). What I am beginning to think now is that C_K has made some errors in his UI-programming. And also just now I read back in Ouchyfoots thread that the resistor to replace the LVP-diode in the zener-mod should have been 200 Ohm, not 220K (ah, that is why I orderded those :-( ), so it could have worked after all.
The morale of this story is that if you do not have much clue about real electronics and just go ahead with making these drivers, it really is hard, especially if you are a bit chaotic like me! The information is scattered all over the place because folks who really know their stuff (understandably) do not repeat the simple established things all over again (it took me back to a thread from 2010 to finally find out which pin on the ATTiny is pin5, it will be somewhere else as well, but I could not find it).
Sooo, after a whole day and two faulty drivers I'm a little wiser, so the next go at making these drivers will be easier. I may recover one of the drivers with a qlite-Attiny (with no mode-switching unfortunately), but because I will never be able to flash firmware to Attiny's (no windows computer, no skills, afraid of programming software) I am looking for a new source of programmed Attiny's that do allow off-time mode-switching.
BTW, I did make a video of the second reflow, and because I still think that reflowing looks like magic, here it is :-) :
Wow, thanks for taking the time to make this big writeup djozz. I think it’s full of great insight/perspective for those of us who “know this stuff”. I’ll probably re-read it a couple more times to really get it to sink in.
I couldn’t help but smile when I noticed that you didn’t mention the part # of the Zener, just the effort required to find it. :wink: For others it’s this info:
I can’t explain the behavior of the Zener build with the reverse voltage protection diode in place (it’s not supposed to work, but I’d have expected that configuration to damage the Zener pretty quickly). After placing the 220k resistor I expect that the Zener was unable to drop enough voltage “(current too low)”:What is a Zener Diode | REUK.co.uk and thus the MCU was fried due to the battery voltage.
EDIT: My personal advice would be to discard the MCU and the Zener used in that failed Zener mod and use new components for your next effort. The other components should be just fine.
i thought i for got something in my mouser kart :( CRCW0805200RFKEB,j guess i have to wait for my next order im not going to pay another $5 for shipping
How many do you need? I can send some your way. Those resistors are cheap.
Thanks for providing the zener link, should have done that :-)
Btw, I wrote the story to give a lttle insight in how these builds are for the 'less gifted' ;-) , but it by no means is a plea to do things different than how they are done now. I think all these developements are great!
Nitro remember that the 200ohm resistor is only necessary for Zener builds. Making a driver for an X6 triple doesn’t involve the Zener mod.
Sounds like you had one of MY days!
Get it right and you’ll be amazed at that triple! It’ll all be worth it then!
On a related tangent, due to some of the excitement lately, the Ledil Iris works pretty nice with the MT-G2 in an X6. :wink:
If you make a Quad 2S2P you can use 2 cells with the Zener mod. :slight_smile:
might have a 2x18650 body made for my x6 or 1x26650 i cant decide what i want
So I need both the zener and the 200ohm resistor? I just ordered some zeners from RMM but somehow didn’t catch that I need the resistor too… Ugh
Yes, you must use a limiting resistor or you’ll damage the Zener.
… huh… apparently Radio Shack is selling 20pcs of 200ohm for ~$1 USD… that’s interesting/convenient…
Hmm I pick door #2: radioshack
me too, ill stop by mine and see if they have it and buy 10 and get 50% off since there closing
Is these a good FET for this driver http://www.ebay.com/itm/PSMN1R2-25YL-NXP-MOSFET-N-CH-25V-100A-LFPAK-QTY-5PCS-/271721280721?pt=LH_DefaultDomain_0&hash=item3f43d9b4d1
and
http://www.ebay.com/itm/PH4030AL-NXP-Trans-MOSFET-N-CH-30V-100A-5-Pin-4-Tab-LFPAK-10PCS-LOT-/281542597064?pt=LH_DefaultDomain_0&hash=item418d3f19c8
Also can i use y5v capacitor instead of x5r?
Do not use Y5V instead of X5R. You may use X7R. Which capacitor are you having trouble finding? You should have no trouble with that.
At a glance, either FET looks acceptable to me. On the first page of this thread we talked a little about both FETs you linked to. (At the time I mentioned that PSMN1R2-25YL might not work well with Zener mods, but I don’t remember why. Maybe I was concerned about Qg. Anyway it’s probably fine, I wouldn’t worry about that.)
Yeah i’m not having trouble finding the capacitors, i just want to buy the parts from one seller. the capacitors and FET from the same ebay seller. He has the x5r but it’s 0603 http://www.ebay.com/itm/0603-SMD-Ceramic-capacitor-MLCC-CL10A475KQ8NNNC-4-7uF-6-3V-10-X5R-0603-100PCS-/281542593537?pt=LH_DefaultDomain_0&hash=item418d3f0c01
He doesn’t have the 1uf so i’ll have to find it from other ebay seller.
What is the reason not to use Y5V?
How about this FETs
PSMN1R5-25YL
SIR850DP-T1-GE3
That’s the only FET i find at our local electronics store.
Thanks djozz for the build writeup,
The threshold to really know all the ins and out to know everything needed is very high, i am trying to assemble all the knowledge the last couple of months to get started with this driver building also, the problem is i have to learn about everything else needed about flashlights at the same time :slight_smile: :weary:
Now i am probably making this more complicated than i really have to :-), but i started from 0 flashlights before October last year so this whole hobby is a lot to learn and comprehend to do all the fun mods you guys are doing.
Y5V sucks. IIRC it’s not temp stable, tolerances are wide, turns terrible over time, etc.
I looked at PSMN1R5-25YL very briefly just now. It looks like it might be a great choice, but I did not look closely. I did not look at the other FET.
EDIT: If you can deal with 0603 size then just buy those, they should fit OK on the 0805 pads…
