Do not use Y5V instead of X5R. You may use X7R. Which capacitor are you having trouble finding? You should have no trouble with that.
At a glance, either FET looks acceptable to me. On the first page of this thread we talked a little about both FETs you linked to. (At the time I mentioned that PSMN1R2-25YL might not work well with Zener mods, but I don’t remember why. Maybe I was concerned about Qg. Anyway it’s probably fine, I wouldn’t worry about that.)
Thanks djozz for the build writeup,
The threshold to really know all the ins and out to know everything needed is very high, i am trying to assemble all the knowledge the last couple of months to get started with this driver building also, the problem is i have to learn about everything else needed about flashlights at the same time :weary:
Now i am probably making this more complicated than i really have to :-), but i started from 0 flashlights before October last year so this whole hobby is a lot to learn and comprehend to do all the fun mods you guys are doing.
What do you think of the PSMN1R5-25YL and SIR850DP-T1-GE3. Here i make a quick comparison, i included the PSMN3R0 / PSMN6R0 from previous page to compare it.
I can see that the PSMN1R5-25YL has a higher Gate Charge and Input Capacitance, is that bad? The SIR850DP-T1-GE3 has lower Gate Charge and Input Capacitance but higher Rds On (Max) @ Id and Vgs(th) (Max) @ Id.
I suspect that SiR850DP will not give the best performance for single-cell applications.
I’ve looked again at PSMN1R5-25YL. It still looks strong. The turn-on/off/etc delay is high, much higher than PSMN3R0-30YLD. This will probably affect the structure of your modes (I think that they may compress upwards? PWM frequency may need to be turned down? I dunno.)
I see no show-stoppers, I’d go with PSMN1R5-25YL if those were my choices.
Hmm, I did not notice the higher input capacitance. That’s probably related to the slow turn-on time. That could be a problem, but I don’t know. It might be OK.
At a glance it looks OK to me for 1s to 4s applications. (Only where the voltage divider bypasses the diode, otherwise you’ll have to tune your LVP settings extra. Most of my drivers are that way now, including this one.)
The price looks very good, less than half of what we are paying for ZLLS410.
This kind of information is great, where can we find all the components for the lowest free shipping price.
I hadn’t even searched ebay for this stuff before djozz build write up and he mentioned it, i just had assumed wrongly that it is mouser/digi-key/farnell and the likes that you find such specific parts.
I built one of these drivers using the original PCB and the parts list below and put it into a triple nichia 219 micro mag. I'm getting 4.7 amps at the tail with an Efest IMR 14500. The light maintains high mode for 5-20 seconds on a freshly charged cell then blinks three times and goes to a light level somewhere between medium and high. Anybody got an idea what's going on and how to fix it?
R1 = 22k
R2 = 4.7k
C1 = 10 uF cap
D1 = SOD323 schottky diode
MCU = ATTINY13A flashed with n-lite by RMM off a QLITE, moon activated
If after monitoring your voltage during the process you find that stepdown is happening at too high a voltage you may increasedecrease the resistance of R1.
