**P60 design**
What about doing a quad version? Quad XPL + DD?
I like the silver plated ones that was produced just awhile back but all that copper is too heavy. I’d be interested in some aluminum ones.
L2T is one of my favorite host from Solarforce. I believe the P1 has lots of plastic and may not be the best choice for a hot drop in.
Correct, for those who want that shape the P1D is the way to go. Same lines, but in solid aluminum.
As far as a quad XP-L, I think the general idea is the same here as the problem with the X6 quads… better to build an EE X6 w/ Cute-3 and domed XP-L emitters. You’ll get more light [by skipping the dedome which is required for 24mm quads], less heat, and it’s apparently a solid host.
Nitro is either going to have to pick a height or produce a sandwich. All these different optics have different heights:
  • reflector
  • 20mm Carclo triple / 24mm Carclo quad
  • 20mm Khatod triple (deeper)
  • 20mm single
  • 26.5mm single
My vote is for either one of the carlco triple or quad
Let's have a re-interest in the p60 lights.. they seem to have lost their love recently.
I'm still wanting that blue l2p
These will be pretty much the same as the ones Mattaus did recently I assume?
yea i just read his thread but something just like it
I’ll be watching this post because I also looking for a reasonable price for custom P60 dropin.
Can’t wait to see the progress :slight_smile:
PS:
AFAIK, there’s a little difference on Solarforce host vs Surefire one.
That’s why Solarforce’s dropin need a spring to be attached.
I don’t understand what you are saying. Solarforce and Surefire both normally use a spring. Here is Surefire’s P60: http://www.surefire.com/p60lamp.html
Here’s the case, sometimes the big/outter spring need to be removed/added to fit Surefire host.
I don’t know the problem is in the dropin or in the host, I only have one Surefire host and already sold my Solarforce host. So I can’t check it for comparison.
I’m sorry for putting a link to other forum here.
The link to CPF is fine, nobody minds.
I skimmed the thread. From what I can see, most of those folks are discussing Surefire dropins being small (and thus not working in 18650-bored lights like the Solarforce). That doesn’t prevent larger dropins from working in a Surefire though. Only jp2515 mentions the “remove the spring” thing.
I remember that I still keep an L2 body (body only) at home.
I’ll check it and post it here later.
FYI there’s a great deal here http://www.solarforceflashlight-sales.com/product_detail.php?t=FB&s=1&id=19
Just $9.9, I hope it’s still available.
I think it would be cool if someone with access to or have the resources of CNC milling machine to make and sell an affordable (this is BUDGET Light Forum after all) custom P60 dropin module that houses around a 20mm optic (single or multiple) so that we can build our own high quality dropin like a Malkoff M60. Maybe someone could put together a group buy for something like that?
im working on it that's the point of this thread ;) i try to keep it budget but like the x6 u got to buy the copper material (expensive) and paying the machine shop for labor ext...........once my solarforce hosts gets here im ready to make them
Alright, now we’re talking… Count me in if you do. Though honestly I wouldn’t mind having some made in Aluminum or Brass (like the Malkoff M60) if they’re more cost effective.
I would definitely be interested in one of these. I have an empty L2N host that is screaming for a de-domed triple XP-L with a FET driver.
im looking to have around 100 made plus looking for a good design for a quad build
are you talking about doing a triple or single emitter style for this p60 shell ? or both? I know bushwhacked just did a copy run of Mattaus triples with center holes but those are gone. It seems hard to find single emitter with sides holes, like malkoff style I guess I would call it?
Mattaus for reference:
well doing a single emitter will not be hard to have made im talking about a quad using 4 led's so the inside will have to be bored out to have a quad optic work/fit
Well the 20/24mm quad boards are no longer available now….
There are these available.
http://www.cutter.com.au/proddetail.php?prod=cut1367
These are used with carclo 106 optics.
